I have a new nvidia Jetson Xavier board brought from Nvidia.
Installed JetPack 4.1.1 as per the JetPack installation guide.
Setup:
Ubuntu 18.04 Host Machine - to compile and do remote cuda-dbg on the board jetson xavier
- Host PC ubuntu 18.04 has all of cuda and all other packages from JetPack 4.1.1 installed
Jetson Xavier - all of JetPack 4.11 , OS flash and other cuda … etc installed on the Jetson Xavier
I have taken the cuda sample examples and copied to ~/NVIDIA_samples.
All the libraries and settings of nsight - are done as per the Jetson TX2 described in a nvidia doc
- the link to this document - https://devblogs.nvidia.com/cuda-jetson-nvidia-nsight-eclipse-edition/
- the only comprehensive document found by me for Jetson TX2 ( this I have used
successfully and I already have a Jetson TX2 with cuda 9.0 installed and nsight running well -
able to debug main arm core and cuda code ).
I have tried numerous examples like box_filter , matrix_mul , convolution_texture but all have the same problem and errors described below: please adise or help on debug this nsight problem.
Description of the error:
- With no breakpoint set , the cod’e runs and gives results - but the MIPS is in GFLOPS ( not sure it is at full speed )
- With one normal breakpoint set at main - it comes upto the main breakpoint and if I say run or resume in night it hangs with the errors doc attached ( 3 console messages 1.gdb.txt , 2.remoteshell.txt , 3.gdbtraces.txt , host Machine - g++ version and cuda version - g++.txt , nvcc–version.txt) . Also I have attached an eclipsensight.odf - screen snapshot of the nsight debugger.( the rest I copied , I dont know how to copy an .odf image here )
- If I seta break point on the kernek i.e in the right corner cuda window - enable breakpoin on all application kernel launches - it still hangs .
Please take a look and help to debug this issue.
Regards
francis j
—gdb.txt-----
Coalescing of the CUDA commands output is off.
warning: “remote:” is deprecated, use “target:” instead.
warning: sysroot set to “target://”.
Reading /lib/ld-linux-aarch64.so.1 from remote target…
warning: File transfers from remote targets can be slow. Use “set sysroot” to access files locally instead.
Reading /lib/ld-2.27.so from remote target…
Reading /lib/.debug/ld-2.27.so from remote target…
0x0000007fb7fd31c0 in ?? () from target:/lib/ld-linux-aarch64.so.1
$1 = 0xff
The target endianness is set automatically (currently little endian)
Reading /lib/aarch64-linux-gnu/librt.so.1 from remote target…
Reading /lib/aarch64-linux-gnu/libpthread.so.0 from remote target…
Reading /lib/aarch64-linux-gnu/libdl.so.2 from remote target…
Reading /usr/lib/aarch64-linux-gnu/libstdc++.so.6 from remote target…
Reading /lib/aarch64-linux-gnu/libgcc_s.so.1 from remote target…
Reading /lib/aarch64-linux-gnu/libc.so.6 from remote target…
Reading /lib/aarch64-linux-gnu/libm.so.6 from remote target…
Reading /lib/aarch64-linux-gnu/librt-2.27.so from remote target…
Reading /lib/aarch64-linux-gnu/.debug/librt-2.27.so from remote target…
Reading /lib/aarch64-linux-gnu/47f37309461cc15fb1915bc198d718017a1f87.debug from remote target…
Reading /lib/aarch64-linux-gnu/.debug/47f37309461cc15fb1915bc198d718017a1f87.debug from remote target…
Reading /lib/aarch64-linux-gnu/libdl-2.27.so from remote target…
Reading /lib/aarch64-linux-gnu/.debug/libdl-2.27.so from remote target…
Reading /usr/lib/aarch64-linux-gnu/ec888879161599d09ef86dc9b55f5096935334.debug from remote target…
Reading /usr/lib/aarch64-linux-gnu/.debug/ec888879161599d09ef86dc9b55f5096935334.debug from remote target…
Reading /lib/aarch64-linux-gnu/866070a0bdee074a8459fae7b95155fdd12861.debug from remote target…
Reading /lib/aarch64-linux-gnu/.debug/866070a0bdee074a8459fae7b95155fdd12861.debug from remote target…
Reading /lib/aarch64-linux-gnu/libc-2.27.so from remote target…
Reading /lib/aarch64-linux-gnu/.debug/libc-2.27.so from remote target…
Reading /lib/aarch64-linux-gnu/libm-2.27.so from remote target…
Reading /lib/aarch64-linux-gnu/.debug/libm-2.27.so from remote target…
Temporary breakpoint 1, main (argc=1, argv=0x7ffffff4e8) at …/src/matrixMul.cu:277
277 int main(int argc, char **argv) {
Reading /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1 from remote target…
Reading /usr/lib/aarch64-linux-gnu/tegra/libnvrm_gpu.so from remote target…
Reading /usr/lib/aarch64-linux-gnu/tegra/libnvrm.so from remote target…
Reading /usr/lib/aarch64-linux-gnu/tegra/libnvrm_graphics.so from remote target…
Reading /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.31.1.0 from remote target…
Reading /usr/lib/aarch64-linux-gnu/tegra/libnvos.so from remote target…
Reading /usr/lib/aarch64-linux-gnu/tegra/libcuda.so.1.1.debug from remote target…
Reading /usr/lib/aarch64-linux-gnu/tegra/.debug/libcuda.so.1.1.debug from remote target…
Reading /usr/lib/aarch64-linux-gnu/tegra/libnvrm_gpu.so.debug from remote target…
Reading /usr/lib/aarch64-linux-gnu/tegra/.debug/libnvrm_gpu.so.debug from remote target…
Reading /usr/lib/aarch64-linux-gnu/tegra/libnvrm.so.debug from remote target…
Reading /usr/lib/aarch64-linux-gnu/tegra/.debug/libnvrm.so.debug from remote target…
Reading /usr/lib/aarch64-linux-gnu/tegra/libnvrm_graphics.so.debug from remote target…
Reading /usr/lib/aarch64-linux-gnu/tegra/.debug/libnvrm_graphics.so.debug from remote target…
Reading /usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.debug from remote target…
Reading /usr/lib/aarch64-linux-gnu/tegra/.debug/libnvidia-fatbinaryloader.so.debug from remote target…
Reading /usr/lib/aarch64-linux-gnu/tegra/libnvos.so.debug from remote target…
Reading /usr/lib/aarch64-linux-gnu/tegra/.debug/libnvos.so.debug from remote target…
---- remote shell .txt -------------
Last login: Mon Mar 18 16:10:40 2019
echo $PWD’>’
/bin/sh -c “cd "/tmp/nsight-debug";export LD_LIBRARY_PATH="/usr/local/cuda-10.0/lib64":${LD_LIBRARY_PATH};export NVPROF_TMPDIR="/tmp";"/usr/local/cuda-10.0/bin/cuda-gdbserver" --cuda-use-lockfile=0 :2345 "/tmp/nsight-debug/matrix_mul"”;exit
nvidia@jetson-0423818077348:~$ echo $PWD’>’
/home/nvidia>
nvidia@jetson-0423818077348:~$ /bin/sh -c “cd "/tmp/nsight-debug";export LD_LIBBRARY_PATH="/usr/local/cuda-10.0/lib64":${LD_LIBRARY_PATH};export NVPROF_TMPDIIR="/tmp";"/usr/local/cuda-10.0/bin/cuda-gdbserver" --cuda-use-lockfile=0 :23345 "/tmp/nsight-debug/matrix_mul"”;exit
Process /tmp/nsight-debug/matrix_mul created; pid = 7546
Listening on port 2345
Remote debugging from host 192.168.10.220
Warning: Adjusting return value of linux_common_core_of_thread (pid=32, tid=32).
core = 4 >= num_cores = 4!
Warning: Adjusting return value of linux_common_core_of_thread (pid=33, tid=33).
Warning: Adjusting return value of linux_common_core_of_thread (pid=34, tid=34).
Warning: Adjusting return value of linux_common_core_of_thread (pid=35, tid=35).
Warning: Adjusting return value of linux_common_core_of_thread (pid=36, tid=36).
Warning: Adjusting return value of linux_common_core_of_thread (pid=37, tid=37).
Warning: Adjusting return value of linux_common_core_of_thread (pid=38, tid=38).
core = 5 >= num_cores = 4!
Warning: Adjusting return value of linux_common_core_of_thread (pid=39, tid=39).
Warning: Adjusting return value of linux_common_core_of_thread (pid=40, tid=40).
Warning: Adjusting return value of linux_common_core_of_thread (pid=41, tid=41).
Warning: Adjusting return value of linux_common_core_of_thread (pid=42, tid=42).
Warning: Adjusting return value of linux_common_core_of_thread (pid=44, tid=44).
core = 6 >= num_cores = 4!
Warning: Adjusting return value of linux_common_core_of_thread (pid=45, tid=45).
Warning: Adjusting return value of linux_common_core_of_thread (pid=46, tid=46).
Warning: Adjusting return value of linux_common_core_of_thread (pid=47, tid=47).
Warning: Adjusting return value of linux_common_core_of_thread (pid=48, tid=48).
Warning: Adjusting return value of linux_common_core_of_thread (pid=50, tid=50).
core = 7 >= num_cores = 4!
Warning: Adjusting return value of linux_common_core_of_thread (pid=51, tid=51).
Warning: Adjusting return value of linux_common_core_of_thread (pid=52, tid=52).
Warning: Adjusting return value of linux_common_core_of_thread (pid=53, tid=53).
Warning: Adjusting return value of linux_common_core_of_thread (pid=54, tid=54).
Warning: Adjusting return value of linux_common_core_of_thread (pid=685, tid=685).
Warning: Adjusting return value of linux_common_core_of_thread (pid=687, tid=687).
Warning: Adjusting return value of linux_common_core_of_thread (pid=692, tid=692).
Warning: Adjusting return value of linux_common_core_of_thread (pid=693, tid=693).
Warning: Adjusting return value of linux_common_core_of_thread (pid=694, tid=694).
Warning: Adjusting return value of linux_common_core_of_thread (pid=714, tid=714).
Warning: Adjusting return value of linux_common_core_of_thread (pid=799, tid=799).
Warning: Adjusting return value of linux_common_core_of_thread (pid=818, tid=818).
Warning: Adjusting return value of linux_common_core_of_thread (pid=961, tid=961).
Warning: Adjusting return value of linux_common_core_of_thread (pid=962, tid=962).
Warning: Adjusting return value of linux_common_core_of_thread (pid=965, tid=965).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1095, tid=1095).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1134, tid=1134).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1205, tid=1205).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1226, tid=1226).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1229, tid=1229).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1350, tid=1350).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1351, tid=1351).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1353, tid=1353).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1356, tid=1356).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1357, tid=1357).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1359, tid=1359).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1362, tid=1362).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1398, tid=1398).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1401, tid=1401).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1410, tid=1410).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1416, tid=1416).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1419, tid=1419).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1431, tid=1431).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1456, tid=1456).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1466, tid=1466).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1467, tid=1467).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1527, tid=1527).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1550, tid=1550).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1591, tid=1591).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1610, tid=1610).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1670, tid=1670).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1672, tid=1672).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1695, tid=1695).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1704, tid=1704).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1845, tid=1845).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1847, tid=1847).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1849, tid=1849).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1851, tid=1851).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1900, tid=1900).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1903, tid=1903).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1907, tid=1907).
Warning: Adjusting return value of linux_common_core_of_thread (pid=1968, tid=1968).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2019, tid=2019).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2058, tid=2058).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2087, tid=2087).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2088, tid=2088).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2226, tid=2226).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2227, tid=2227).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2238, tid=2238).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2248, tid=2248).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2252, tid=2252).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2253, tid=2253).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2254, tid=2254).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2255, tid=2255).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2256, tid=2256).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2257, tid=2257).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2258, tid=2258).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2259, tid=2259).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2262, tid=2262).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2266, tid=2266).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2267, tid=2267).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2268, tid=2268).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2269, tid=2269).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2270, tid=2270).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2271, tid=2271).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2272, tid=2272).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2273, tid=2273).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2275, tid=2275).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2277, tid=2277).
Warning: Adjusting return value of linux_common_core_of_thread (pid=2422, tid=2422).
Warning: Adjusting return value of linux_common_core_of_thread (pid=4479, tid=4746).
Warning: Adjusting return value of linux_common_core_of_thread (pid=4479, tid=5276).
Warning: Adjusting return value of linux_common_core_of_thread (pid=4776, tid=4776).
Warning: Adjusting return value of linux_common_core_of_thread (pid=4820, tid=4820).
Warning: Adjusting return value of linux_common_core_of_thread (pid=4861, tid=4861).
Warning: Adjusting return value of linux_common_core_of_thread (pid=4899, tid=4930).
Warning: Adjusting return value of linux_common_core_of_thread (pid=4942, tid=4942).
Warning: Adjusting return value of linux_common_core_of_thread (pid=4958, tid=4958).
Warning: Adjusting return value of linux_common_core_of_thread (pid=4975, tid=4975).
Warning: Adjusting return value of linux_common_core_of_thread (pid=5029, tid=5029).
Warning: Adjusting return value of linux_common_core_of_thread (pid=5248, tid=5248).
Warning: Adjusting return value of linux_common_core_of_thread (pid=5322, tid=5322).
Warning: Adjusting return value of linux_common_core_of_thread (pid=5412, tid=5542).
Warning: Adjusting return value of linux_common_core_of_thread (pid=5556, tid=5556).
Warning: Adjusting return value of linux_common_core_of_thread (pid=5626, tid=5626).
Warning: Adjusting return value of linux_common_core_of_thread (pid=5627, tid=5627).
[Matrix Multiply Using CUDA] - Starting…
GPU Device 0: “Xavier” with compute capability 7.2
MatrixA(320,320), MatrixB(640,320)
------------------ gdbtraces.txt --------------------
491,605 1-gdb-set cuda break_on_launch none
491,606 2-gdb-set cuda kernel_events none
491,607 1^done
491,610 (gdb)
491,610 2^done
491,610 (gdb)
491,643 3-gdb-set cuda coalescing off
491,644 4-gdb-set cuda single_stepping_optimizations on
491,644 5-gdb-set cuda memcheck off
491,644 6-gdb-set cuda software_preemption on
491,644 ~“Coalescing of the CUDA commands output is off.\n”
491,644 7-gdb-set cuda value_extrapolation off
491,646 3^done
491,646 (gdb)
491,646 4^done
491,646 (gdb)
491,646 5^done
491,646 (gdb)
491,646 6^done
491,646 (gdb)
491,646 7^done
491,646 (gdb)
491,666 8-gdb-set cuda api_failures ignore
491,666 8^done
491,666 (gdb)
491,668 9-gdb-set cuda kernel_events none
491,669 9^done
491,669 (gdb)
491,671 10-environment-cd /home/cose/cuda-workspace/matrix_mul
491,671 10^done
491,671 (gdb)
491,676 11-gdb-set breakpoint pending on
491,676 11^done
491,676 (gdb)
491,677 12-gdb-set breakpoint conditional-pending on
491,677 12^done
491,677 (gdb)
491,682 13-gdb-set detach-on-fork on
491,682 13^done
491,682 (gdb)
491,684 14-enable-pretty-printing
491,684 14^done
491,684 (gdb)
491,687 15-gdb-set python print-stack none
491,688 15^done
491,688 (gdb)
491,690 16-gdb-set print object on
491,690 16^done
491,690 (gdb)
491,692 17-gdb-set print sevenbit-strings on
491,693 17^done
491,693 (gdb)
491,694 18-gdb-set host-charset UTF-8
491,695 18^done
491,695 (gdb)
491,697 19-gdb-set target-charset UTF-8
491,697 19^done
491,697 (gdb)
491,702 20-gdb-set target-wide-charset UTF-32
491,702 20^done
491,702 (gdb)
491,706 21source .cuda-gdbinit
491,707 &“source .cuda-gdbinit\n”
491,707 &“.cuda-gdbinit: Aucun fichier ou dossier de ce type.\n”
491,707 21^error,msg=“.cuda-gdbinit: Aucun fichier ou dossier de ce type.”
491,708 (gdb)
491,710 22-gdb-set target-async off
491,710 22^done
491,710 (gdb)
491,713 23-gdb-set auto-solib-add on
491,713 23^done
491,713 (gdb)
491,718 24-gdb-set sysroot remote://
491,718 &“warning: "remote:" is deprecated, use "target:" instead.\n”
491,718 &“warning: sysroot set to "target://".\n”
491,719 24^done
491,719 (gdb)
491,730 25-file-exec-and-symbols /home/cose/cuda-workspace/matrix_mul/Debug/matrix_mul
491,749 25^done
491,749 (gdb)
491,751 26-target-select remote 192.168.10.153:2345
491,760 27-cuda-info-kernels
491,765 =tsv-created,name=“trace_timestamp”,initial=“0”\n
491,773 =thread-group-started,id=“i1”,pid=“7546”
491,774 =thread-created,id=“1”,group-id=“i1”
491,776 28-list-thread-groups --available
491,785 ~“Reading /lib/ld-linux-aarch64.so.1 from remote target…\n”
491,785 &“warning: File transfers from remote targets can be slow. Use "set sysroot" to access fil
es locally instead.\n”
491,822 ~“Reading /lib/ld-linux-aarch64.so.1 from remote target…\n”
491,847 =library-loaded,id=“/lib/ld-linux-aarch64.so.1”,target-name=“/lib/ld-linux-aarch64.so.1”,hos
t-name=“target:/lib/ld-linux-aarch64.so.1”,symbols-loaded=“0”,thread-group=“i1”
491,849 ~“Reading /lib/ld-2.27.so from remote target…\n”
491,850 ~“Reading /lib/.debug/ld-2.27.so from remote target…\n”
491,900 ~“0x0000007fb7fd31c0 in ?? () from target:/lib/ld-linux-aarch64.so.1\n”
491,900 *stopped,frame={addr=“0x0000007fb7fd31c0”,func=“??”,args=,from=“target:/lib/ld-linux-aarch
64.so.1”},thread-id=“1”,stopped-threads=“all”,core=“1”
491,902 29-list-thread-groups
491,915 26^connected
491,915 (gdb)
491,915 27^done,InfoCudaKernelsTable={nr_rows=“0”,nr_cols=“10”,hdr=[{width=“1”,alignment=“1”,col_nam
e=“current”,colhdr=" “},{width=“6”,alignment=“1”,col_name=“kernel”,colhdr=“Kernel”},{width=“6”,align
ment=“1”,col_name=“parent”,colhdr=“Parent”},{width=“3”,alignment=“1”,col_name=“device”,colhdr=“Dev”}
,{width=“4”,alignment=“1”,col_name=“grid”,colhdr=“Grid”},{width=“6”,alignment=“1”,col_name=“status”,
colhdr=“Status”},{width=“8”,alignment=“1”,col_name=“sms_mask”,colhdr=“SMs Mask”},{width=“7”,alignmen
t=“1”,col_name=“gridDim”,colhdr=“GridDim”},{width=“8”,alignment=“1”,col_name=“blockDim”,colhdr=“Bloc
kDim”},{width=“10”,alignment=”-1",col_name=“invocation”,colhdr=“Invocation”}],body=}
491,916 (gdb)
491,922 30-gdb-show language
492,114 28^done,groups=[{id=“1”,type=“process”,description=“/sbin/init”,user=“root”,cores=[“2”]},{id
=“2”,type=“process”,description=“[kthreadd]”,user=“root”,cores=[“3”]},{id=“3”,type=“process”,descrip
tion=“[ksoftirqd/0]”,user=“root”,cores=[“0”]},{id=“4”,type=“process”,description=“[kworker/0:0]”,use
r=“root”,cores=[“0”]},{id=“5”,type=“process”,description=“[kworker/0:0H]”,user=“root”,cores=[“0”]},{
id=“6”,type=“process”,description=“[kworker/u16:0]”,user=“root”,cores=[“2”]},{id=“7”,type=“process”,
description=“[rcu_preempt]”,user=“root”,cores=[“1”]},{id=“8”,type=“process”,description=“[rcu_sched]
“,user=“root”,cores=[“2”]},{id=“9”,type=“process”,description=”[rcu_bh]”,user=“root”,cores=[“0”]},{i
d=“10”,type=“process”,description=“[migration/0]”,user=“root”,cores=[“0”]},{id=“11”,type=“process”,d
escription=“[lru-add-drain]”,user=“root”,cores=[“0”]},{id=“12”,type=“process”,description=“[watchdog
/0]”,user=“root”,cores=[“0”]},{id=“13”,type=“process”,description=“[cpuhp/0]”,user=“root”,cores=[“0”
]},{id=“14”,type=“process”,description=“[cpuhp/1]”,user=“root”,cores=[“1”]},{id=“15”,type=“process”,
description=“[watchdog/1]”,user=“root”,cores=[“1”]},{id=“16”,type=“process”,description=“[migration/
1]”,user=“root”,cores=[“1”]},{id=“17”,type=“process”,description=“[ksoftirqd/1]”,user=“root”,cores=[
“1”]},{id=“18”,type=“process”,description=“[kworker/1:0]”,user=“root”,cores=[“1”]},{id=“19”,type=“pr
ocess”,description=“[kworker/1:0H]”,user=“root”,cores=[“1”]},{id=“20”,type=“process”,description=“[c
puhp/2]”,user=“root”,cores=[“2”]},{id=“21”,type=“process”,description=“[watchdog/2]”,user=“root”,cor
es=[“2”]},{id=“22”,type=“process”,description=“[migration/2]”,user=“root”,cores=[“2”]},{id=“23”,type
=“process”,description=“[ksoftirqd/2]”,user=“root”,cores=[“2”]},{id=“24”,type=“process”,description=
“[kworker/2:0]”,user=“root”,cores=[“2”]},{id=“25”,type=“process”,description=“[kworker/2:0H]”,user="
root",cores=[“2”]},{id=“26”,type=“process”,description=“[cpuhp/3]”,user=“root”,cores=[“3”]},{id=“27”
,type=“process”,description=“[watchdog/3]”,user=“root”,cores=[“3”]},{id=“28”,type=“process”,descript
ion=“[migration/3]”,user=“root”,cores=[“3”]},{id=“29”,type=“process”,description=“[ksoftirqd/3]”,use
r=“root”,cores=[“3”]},{id=“30”,type=“process”,description=“[kworker/3:0]”,user=“root”,cores=[“3”]},{
id=“31”,type=“process”,description=“[kworker/3:0H]”,user=“root”,cores=[“3”]},{id=“32”,type=“process”
,description=“[cpuhp/4]”,user=“root”,cores=[“3”]},{id=“33”,type=“process”,description=“[watchdog/4]”
,user=“root”,cores=[“3”]},{id=“34”,type=“process”,description=“[migration/4]”,user=“root”,cores=[“3”
]},{id=“35”,type=“process”,description=“[ksoftirqd/4]”,user=“root”,cores=[“3”]},{id=“36”,type=“proce
ss”,description=“[kworker/4:0]”,user=“root”,cores=[“3”]},{id=“37”,type=“process”,description=“[kwork
er/4:0H]”,user=“root”,cores=[“3”]},{id=“38”,type=“process”,description=“[cpuhp/5]”,user=“root”,cores
=[“3”]},{id=“39”,type=“process”,description=“[watchdog/5]”,user=“root”,cores=[“3”]},{id=“40”,type=“p
rocess”,description=“[migration/5]”,user=“root”,cores=[“3”]},{id=“41”,type=“process”,description=“[k
softirqd/5]”,user=“root”,cores=[“3”]},{id=“42”,type=“process”,description=“[kworker/5:0]”,user=“root
“,cores=[“3”]},{id=“43”,type=“process”,description=”[kworker/5:0H]”,user=“root”,cores=[“0”]},{id=“44
“,type=“process”,description=”[cpuhp/6]”,user=“root”,cores=[“3”]},{id=“45”,type=“process”,descriptio
n=“[watchdog/6]”,user=“root”,cores=[“3”]},{id=“46”,type=“process”,description=“[migration/6]”,user="
root",cores=[“3”]},{id=“47”,type=“process”,description=“[ksoftirqd/6]”,user=“root”,cores=[“3”]},{id=
“48”,type=“process”,description=“[kworker/6:0]”,user=“root”,cores=[“3”]},{id=“49”,type=“process”,des
cription=“[kworker/6:0H]”,user=“root”,cores=[“0”]},{id=“50”,type=“process”,description=“[cpuhp/7]”,u
ser=“root”,cores=[“3”]},{id=“51”,type=“process”,description=“[watchdog/7]”,user=“root”,cores=[“3”]},
{id=“52”,type=“process”,description=“[migration/7]”,user=“root”,cores=[“3”]},{id=“53”,type=“process”
,description=“[ksoftirqd/7]”,user=“root”,cores=[“3”]},{id=“54”,type=“process”,description=“[kworker/
7:0]”,user=“root”,cores=[“3”]},{id=“55”,type=“process”,description=“[kworker/7:0H]”,user=“root”,core
s=[“0”]},{id=“56”,type=“process”,description=“[kdevtmpfs]”,user=“root”,cores=[“0”]},{id=“57”,type=“p
rocess”,description=“[netns]”,user=“root”,cores=[“2”]},{id=“58”,type=“process”,description=“[kworker
/u16:1]”,user=“root”,cores=[“3”]},{id=“62”,type=“process”,description=“[kworker/u16:2]”,user=“root”,
cores=[“3”]},{id=“84”,type=“process”,description=“[kworker/u16:3]”,user=“root”,cores=[“3”]},{id=“231
“,type=“process”,description=”[irq/100-mc_stat]”,user=“root”,cores=[“0”]},{id=“343”,type=“process”,d
escription=“[kworker/u16:4]”,user=“root”,cores=[“1”]},{id=“685”,type=“process”,description=“[khungta
skd]”,user=“root”,cores=[“3”]},{id=“686”,type=“process”,description=“[oom_reaper]”,user=“root”,cores
=[“2”]},{id=“687”,type=“process”,description=“[writeback]”,user=“root”,cores=[“3”]},{id=“689”,type="
process",description=“[kcompactd0]”,user=“root”,cores=[“1”]},{id=“690”,type=“process”,description=“[
ksmd]”,user=“root”,cores=[“3”]},{id=“691”,type=“process”,description=“[khugepaged]”,user=“root”,core
s=[“1”]},{id=“692”,type=“process”,description=“[kworker/7:1]”,user=“root”,cores=[“3”]},{id=“693”,typ
e=“process”,description=“[crypto]”,user=“root”,cores=[“3”]},{id=“694”,type=“process”,description=“[k
integrityd]”,user=“root”,cores=[“3”]},{id=“695”,type=“process”,description=“[bioset]”,user=“root”,co
res=[“3”]},{id=“696”,type=“process”,description=“[kblockd]”,user=“root”,cores=[“0”]},{id=“714”,type=
“process”,description=“[ata_sff]”,user=“root”,cores=[“3”]},{id=“731”,type=“process”,description=“[kw
orker/6:1]”,user=“root”,cores=[“2”]},{id=“747”,type=“process”,description=“[irq/489-max7762]”,user="
root",cores=[“1”]},{id=“788”,type=“process”,description=“[irq/467-30c0000]”,user=“root”,cores=[“0”]}
,{id=“795”,type=“process”,description=“[kworker/1:1]”,user=“root”,cores=[“1”]},{id=“799”,type=“proce
ss”,description=“[devfreq_wq]”,user=“root”,cores=[“3”]},{id=“818”,type=“process”,description=“[watch
dogd]”,user=“root”,cores=[“3”]},{id=“836”,type=“process”,description=“[nvmap-bz]”,user=“root”,cores=
[“0”]},{id=“960”,type=“process”,description=“[kworker/3:1]”,user=“root”,cores=[“3”]},{id=“961”,type=
“process”,description=“[rpciod]”,user=“root”,cores=[“3”]},{id=“962”,type=“process”,description=“[xpr
tiod]”,user=“root”,cores=[“3”]},{id=“965”,type=“process”,description=“[host_low_prio_w]”,user=“root”
,cores=[“3”]},{id=“966”,type=“process”,description=“[irq/71-host_syn]”,user=“root”,cores=[“1”]},{id=
“967”,type=“process”,description=“[irq/72-host_sta]”,user=“root”,cores=[“0”]},{id=“1010”,type=“proce
ss”,description=“[kswapd0]”,user=“root”,cores=[“2”]},{id=“1012”,type=“process”,description=“[vmstat]
“,user=“root”,cores=[“3”]},{id=“1095”,type=“process”,description=”[nfsiod]”,user=“root”,cores=[“3”]}
,{id=“1134”,type=“process”,description=“[kthrotld]”,user=“root”,cores=[“3”]},{id=“1145”,type=“proces
s”,description=“[kworker/0:1]”,user=“root”,cores=[“0”]},{id=“1146”,type=“process”,description=“[kwor
ker/2:1]”,user=“root”,cores=[“2”]},{id=“1148”,type=“process”,description=“[kworker/1:2]”,user=“root”
,cores=[“1”]},{id=“1205”,type=“process”,description=“[kworker/4:1]”,user=“root”,cores=[“3”]},{id=“12
26”,type=“process”,description=“[irq/87-pva-isr]”,user=“root”,cores=[“3”]},{id=“1229”,type=“process”
,description=“[irq/88-pva-isr]”,user=“root”,cores=[“3”]},{id=“1274”,type=“process”,description=“[teg
radc.0/a]”,user=“root”,cores=[“3”]},{id=“1275”,type=“process”,description=“[tegradc.0/b]”,user=“root
“,cores=[“0”]},{id=“1276”,type=“process”,description=”[tegradc.0/c]”,user=“root”,cores=[“0”]},{id=“1
278”,type=“process”,description=“[tegradc.0/d]”,user=“root”,cores=[“0”]},{id=“1279”,type=“process”,d
escription=“[tegradc.0/e]”,user=“root”,cores=[“0”]},{id=“1281”,type=“process”,description=“[tegradc.
0/f]”,user=“root”,cores=[“0”]},{id=“1285”,type=“process”,description=“[tegradc.0/sl]”,user=“root”,co
res=[“0”]},{id=“1287”,type=“process”,description=“[irq/76-15200000]”,user=“root”,cores=[“1”]},{id=“1
337”,type=“process”,description=“[kworker/5:1]”,user=“root”,cores=[“0”]},{id=“1346”,type=“process”,d
escription=“[irq/475-gk20a_s]”,user=“root”,cores=[“0”]},{id=“1348”,type=“process”,description=“[bios
et]”,user=“root”,cores=[“1”]},{id=“1349”,type=“process”,description=“[bioset]”,user=“root”,cores=[“0
“]},{id=“1350”,type=“process”,description=”[bioset]”,user=“root”,cores=[“3”]},{id=“1351”,type=“proce
ss”,description=“[bioset]”,user=“root”,cores=[“3”]},{id=“1352”,type=“process”,description=“[bioset]”
,user=“root”,cores=[“3”]},{id=“1353”,type=“process”,description=“[bioset]”,user=“root”,cores=[“3”]},
{id=“1354”,type=“process”,description=“[bioset]”,user=“root”,cores=[“0”]},{id=“1355”,type=“process”,
description=“[bioset]”,user=“root”,cores=[“1”]},{id=“1356”,type=“process”,description=“[bioset]”,use
r=“root”,cores=[“3”]},{id=“1357”,type=“process”,description=“[bioset]”,user=“root”,cores=[“3”]},{id=
“1358”,type=“process”,description=“[bioset]”,user=“root”,cores=[“3”]},{id=“1359”,type=“process”,desc
ription=“[bioset]”,user=“root”,cores=[“3”]},{id=“1360”,type=“process”,description=“[bioset]”,user=“r
oot”,cores=[“1”]},{id=“1361”,type=“process”,description=“[bioset]”,user=“root”,cores=[“0”]},{id=“136
2”,type=“process”,description=“[bioset]”,user=“root”,cores=[“3”]},{id=“1363”,type=“process”,descript
ion=“[bioset]”,user=“root”,cores=[“3”]},{id=“1375”,type=“process”,description=“[irq/297-1520000]”,us
er=“root”,cores=[“1”]},{id=“1398”,type=“process”,description=“[bioset]”,user=“root”,cores=[“3”]},{id
=“1401”,type=“process”,description=“[bioset]”,user=“root”,cores=[“3”]},{id=“1404”,type=“process”,des
cription=“[bioset]”,user=“root”,cores=[“0”]},{id=“1407”,type=“process”,description=“[bioset]”,user="
root",cores=[“1”]},{id=“1410”,type=“process”,description=“[bioset]”,user=“root”,cores=[“3”]},{id=“14
13”,type=“process”,description=“[bioset]”,user=“root”,cores=[“3”]},{id=“1416”,type=“process”,descrip
tion=“[bioset]”,user=“root”,cores=[“3”]},{id=“1419”,type=“process”,description=“[bioset]”,user=“root
“,cores=[“3”]},{id=“1426”,type=“process”,description=”[kworker/u17:0]”,user=“root”,cores=[“2”]},{id=
“1430”,type=“process”,description=“[scsi_eh_0]”,user=“root”,cores=[“0”]},{id=“1431”,type=“process”,d
escription=“[scsi_tmf_0]”,user=“root”,cores=[“3”]},{id=“1456”,type=“process”,description=“[nvme]”,us
er=“root”,cores=[“3”]},{id=“1466”,type=“process”,description=“[irq/57-c260000.]”,user=“root”,cores=[
“3”]},{id=“1467”,type=“process”,description=“[spi1]”,user=“root”,cores=[“3”]},{id=“1521”,type=“proce
ss”,description=“[kworker/u16:5]”,user=“root”,cores=[“0”]},{id=“1527”,type=“process”,description=“[i\
xgbe]”,user=“root”,cores=[“3”]},{id=“1550”,type=“process”,description=“[vfio-irqfd-clea]”,user=“root
“,cores=[“3”]},{id=“1591”,type=“process”,description=”[irq/437-ccg_irq]”,user=“root”,cores=[“3”]},{i
d=“1601”,type=“process”,description=“[kworker/4:2]”,user=“root”,cores=[“0”]},{id=“1610”,type=“proces
s”,description=“[irq/99-tegra_rt]”,user=“root”,cores=[“3”]},{id=“1670”,type=“process”,description=“[
cfinteractive]”,user=“root”,cores=[“3”]},{id=“1672”,type=“process”,description=“[read_counters_w]”,u
ser=“root”,cores=[“3”]},{id=“1695”,type=“process”,description=“[irq/54-mmc0]”,user=“root”,cores=[“3”
]},{id=“1704”,type=“process”,description=“[irq/55-mmc1]”,user=“root”,cores=[“3”]},{id=“1790”,type=“p
rocess”,description=“[irq/102-c150000]”,user=“root”,cores=[“3”]},{id=“1800”,type=“process”,descripti
on=“[irq/70-d230000.]”,user=“root”,cores=[“0”]},{id=“1815”,type=“process”,description=“[kworker/3:2]
“,user=“root”,cores=[“3”]},{id=“1835”,type=“process”,description=”[kworker/3:3]”,user=“root”,cores=[
“3”]},{id=“1838”,type=“process”,description=“[kworker/3:4]”,user=“root”,cores=[“3”]},{id=“1841”,type
=“process”,description=“[kworker/3:5]”,user=“root”,cores=[“3”]},{id=“1845”,type=“process”,descriptio
n=“[irq/254-3400000]”,user=“root”,cores=[“3”]},{id=“1847”,type=“process”,description=“[bioset]”,user
=“root”,cores=[“3”]},{id=“1848”,type=“process”,description=“[mmcqd/0]”,user=“root”,cores=[“2”]},{id=
“1849”,type=“process”,description=“[bioset]”,user=“root”,cores=[“3”]},{id=“1850”,type=“process”,desc
ription=“[mmcqd/0boot0]”,user=“root”,cores=[“0”]},{id=“1851”,type=“process”,description=“[bioset]”,u
ser=“root”,cores=[“3”]},{id=“1852”,type=“process”,description=“[mmcqd/0boot1]”,user=“root”,cores=[“0
“]},{id=“1853”,type=“process”,description=”[bioset]”,user=“root”,cores=[“1”]},{id=“1854”,type=“proce
ss”,description=“[mmcqd/0rpmb]”,user=“root”,cores=[“0”]},{id=“1893”,type=“process”,description=“[kwo
rker/u16:6]”,user=“root”,cores=[“1”]},{id=“1900”,type=“process”,description=“[tmp451]”,user=“root”,c
ores=[“3”]},{id=“1903”,type=“process”,description=“[kworker/u17:1]”,user=“root”,cores=[“3”]},{id=“19
07”,type=“process”,description=“[irq/348-rt5659]”,user=“root”,cores=[“3”]},{id=“1956”,type=“process”
,description=“[kworker/6:2]”,user=“root”,cores=[“0”]},{id=“1968”,type=“process”,description=“[kworke
r/5:2]”,user=“root”,cores=[“3”]},{id=“2019”,type=“process”,description=“[ipv6_addrconf]”,user=“root”
,cores=[“3”]},{id=“2021”,type=“process”,description=“[krfcommd]”,user=“root”,cores=[“0”]},{id=“2058”
,type=“process”,description=“[scsi_eh_1]”,user=“root”,cores=[“3”]},{id=“2059”,type=“process”,des
crip
tion=“[scsi_tmf_1]”,user=“root”,cores=[“0”]},{id=“2087”,type=“process”,description=“[kworker/6:3]”,u
ser=“root”,cores=[“3”]},{id=“2088”,type=“process”,description=“[kworker/6:4]”,user=“root”,cores=[“3”
]},{id=“2226”,type=“process”,description=“[irq/113-b950000]”,user=“root”,cores=[“3”]},{id=“2227”,typ
e=“process”,description=“[irq/113-b950000]”,user=“root”,cores=[“3”]},{id=“2230”,type=“process”,descr
iption=“[irq/113-b950000]”,user=“root”,cores=[“0”]},{id=“2238”,type=“process”,description=“[irq/69-b
c00000.]”,user=“root”,cores=[“3”]},{id=“2248”,type=“process”,description=“[irq/79-tegra_dp]”,user=“r
oot”,cores=[“3”]},{id=“2252”,type=“process”,description=“[tegradc.1/a]”,user=“root”,cores=[“3”]},{id
=“2253”,type=“process”,description=“[tegradc.1/b]”,user=“root”,cores=[“3”]},{id=“2254”,type=“process
“,description=”[tegradc.1/c]”,user=“root”,cores=[“3”]},{id=“2255”,type=“process”,description=“[tegra
dc.1/d]”,user=“root”,cores=[“3”]},{id=“2256”,type=“process”,description=“[tegradc.1/e]”,user=“root”,
cores=[“3”]},{id=“2257”,type=“process”,description=“[tegradc.1/f]”,user=“root”,cores=[“3”]},{id=“225
8”,type=“process”,description=“[tegradc.1/sl]”,user=“root”,cores=[“3”]},{id=“2259”,type=“process”,de
scription=“[irq/77-15210000]”,user=“root”,cores=[“3”]},{id=“2262”,type=“process”,description=“[irq/8
0-tegra_dp]”,user=“root”,cores=[“3”]},{id=“2266”,type=“process”,description=“[tegradc.2/a]”,user=“ro
ot”,cores=[“3”]},{id=“2267”,type=“process”,description=“[tegradc.2/b]”,user=“root”,cores=[“3”]},{id=
“2268”,type=“process”,description=“[tegradc.2/c]”,user=“root”,cores=[“3”]},{id=“2269”,type=“process”
,description=“[tegradc.2/d]”,user=“root”,cores=[“3”]},{id=“2270”,type=“process”,description=“[tegrad
c.2/e]”,user=“root”,cores=[“3”]},{id=“2271”,type=“process”,description=“[tegradc.2/f]”,user=“root”,c
ores=[“3”]},{id=“2272”,type=“process”,description=“[tegradc.2/sl]”,user=“root”,cores=[“3”]},{id=
“227
3”,type=“process”,description=“[irq/78-15220000]”,user=“root”,cores=[“3”]},{id=“2275”,type=“process”
,description=“[kworker/7:1H]”,user=“root”,cores=[“3”]},{id=“2276”,type=“process”,description=“[jbd2/
mmcblk0p1-]”,user=“root”,cores=[“3”]},{id=“2277”,type=“process”,description=“[ext4-rsv-conver]”,user
=“root”,cores=[“3”]},{id=“2351”,type=“process”,description=“/lib/systemd/systemd-journald”,user=“roo
t”,cores=[“2”]},{id=“2422”,type=“process”,description=“[kauditd]”,user=“root”,cores=[“3”]},{id=“2531
“,type=“process”,description=”[kworker/1:3]”,user=“root”,cores=[“1”]},{id=“3053”,type=“process”,desc
ription=“/lib/systemd/systemd-udevd”,user=“root”,cores=[“0”]},{id=“3141”,type=“process”,description=
“[kworker/2:2]”,user=“root”,cores=[“2”]},{id=“3191”,type=“process”,description=“[kworker/2:3]”,user=
“root”,cores=[“2”]},{id=“3237”,type=“process”,description=“/lib/systemd/systemd-resolved”,user=“syst
emd-resolve”,cores=[“0”]},{id=“3263”,type=“process”,description=“/lib/systemd/systemd-timesyncd”,use
r=“systemd-timesync”,cores=[“0”]},{id=“3267”,type=“process”,description=“/sbin/rpcbind -f -w”,user="
root",cores=[“0”]},{id=“3289”,type=“process”,description=“/usr/sbin/haveged --Foreground --verbose=1
-w 1024”,user=“root”,cores=[“1”]},{id=“4440”,type=“process”,description=“/usr/bin/dbus-daemon --sys
tem --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only”,user=“messagebus”,co
res=[“3”]},{id=“4471”,type=“process”,description=“/usr/sbin/NetworkManager --no-daemon”,user=“root”,
cores=[“1”,“2”]},{id=“4477”,type=“process”,description=“avahi-daemon: running [jetson-0423818077348.
local]”,user=“avahi”,cores=[“0”]},{id=“4479”,type=“process”,description=“/usr/lib/snapd/snapd”,user=
“root”,cores=[“0”,“1”,“2”,“3”]},{id=“4505”,type=“process”,description=“/usr/lib/accountsservice/acco
unts-daemon”,user=“root”,cores=[“2”]},{id=“4513”,type=“process”,description=“/usr/sbin/rsyslogd
-n”,
user=“syslog”,cores=[“1”,“2”]},{id=“4521”,type=“process”,description=“/usr/bin/python3 /usr/bin/netw
orkd-dispatcher --run-startup-triggers”,user=“root”,cores=[“1”]},{id=“4570”,type=“process”,descripti
on=“/usr/lib/udisks2/udisksd”,user=“root”,cores=[“0”,“1”,“2”,“3”]},{id=“4580”,type=“process”,descrip
tion=“/sbin/wpa_supplicant -u -s -O /run/wpa_supplicant”,user=“root”,cores=[“2”]},{id=“4624”,type=“p
rocess”,description=“/usr/sbin/ModemManager”,user=“root”,cores=[“0”,“3”]},{id=“4648”,type=“process”,
description=“/usr/sbin/cupsd -l”,user=“root”,cores=[“2”]},{id=“4683”,type=“process”,description=“/li
b/systemd/systemd-logind”,user=“root”,cores=[“3”]},{id=“4731”,type=“process”,description=“/usr/sbin/
cron -f”,user=“root”,cores=[“0”]},{id=“4776”,type=“process”,description=“avahi-daemon: chroot helper
“,user=“avahi”,cores=[“3”]},{id=“4820”,type=“process”,description=”[file-storage]”,user=“root”,cores
=[“3”]},{id=“4861”,type=“process”,description=“[kworker/4:3]”,user=“root”,cores=[“3”]},{id=“4899”,ty
pe=“process”,description=“/usr/lib/policykit-1/polkitd --no-debug”,user=“root”,cores=[“0”,“1”,“3”]},
{id=“4919”,type=“process”,description=“[kworker/0:1H]”,user=“root”,cores=[“0”]},{id=“4942”,type=“pro
cess”,description=“[loop0]”,user=“root”,cores=[“3”]},{id=“4958”,type=“process”,description=“/usr/lib
/cups/notifier/dbus dbus://”,user=“lp”,cores=[“3”]},{id=“4970”,type=“process”,description=“/usr/lib/
cups/notifier/dbus dbus://”,user=“lp”,cores=[“3”]},{id=“4971”,type=“process”,description=“[kworker/0
:2]”,user=“root”,cores=[“0”]},{id=“4972”,type=“process”,description=“/usr/lib/cups/notifier/dbus dbu
s://”,user=“lp”,cores=[“1”]},{id=“4974”,type=“process”,description=“/usr/lib/cups/notifier/dbus dbus
://”,user=“lp”,cores=[“2”]},{id=“4975”,type=“process”,description=“/usr/lib/cups/notifier/dbus dbus:
//”,user=“lp”,cores=[“3”]},{id=“4976”,type=“process”,description=“[kworker/0:3]”,user=“root”,cores=[
“0”]},{id=“4977”,type=“process”,description=“/usr/lib/cups/notifier/dbus dbus://”,user=“lp”,cores=["
3"]},{id=“4978”,type=“process”,description=“/usr/lib/cups/notifier/dbus dbus://”,user=“lp”,cores=[“2
“]},{id=“4981”,type=“process”,description=”/usr/lib/cups/notifier/dbus dbus://”,user=“lp”,cores=[“1”
]},{id=“4982”,type=“process”,description=“/usr/lib/cups/notifier/dbus dbus://”,user=“lp”,cores=[“0”]
},{id=“4985”,type=“process”,description=“[kworker/7:2]”,user=“root”,cores=[“0”]},{id=“4995”,type=“pr
ocess”,description=“/usr/lib/cups/notifier/dbus dbus://”,user=“lp”,cores=[“2”]},{id=“5029”,type=“pro
cess”,description=“[kworker/5:1H]”,user=“root”,cores=[“3”]},{id=“5142”,type=“process”,description=“/
usr/sbin/dhcpd -cf /opt/nvidia/l4t-usb-device-mode/dhcpd.conf -pf /opt/nvidia/l4t-usb-device-mode/dh
cpd.pid -lf /opt/nvidia/l4t-usb-device-mode/dhcpd.leases”,user=“root”,cores=[“3”]},{id=“5239”,type="
process",description=“[sugov:0]”,user=“root”,cores=[“0”]},{id=“5248”,type=“process”,description=“[kw
orker/6:1H]”,user=“root”,cores=[“3”]},{id=“5322”,type=“process”,description=“[kworker/7:3]”,user=“ro
ot”,cores=[“3”]},{id=“5412”,type=“process”,description=“/usr/bin/whoopsie -f”,user=“whoopsie”,cores=
[“2”,“3”]},{id=“5439”,type=“process”,description=“/usr/sbin/kerneloops --test”,user=“kernoops”,cores
=[“0”]},{id=“5479”,type=“process”,description=“/usr/sbin/sshd -D”,user=“root”,cores=[“0”]},{id=“5481
“,type=“process”,description=”/usr/sbin/kerneloops”,user=“kernoops”,cores=[“1”]},{id=“5556”,type=“pr
ocess”,description=“[kworker/5:3]”,user=“root”,cores=[“3”]},{id=“5626”,type=“process”,description=“[
irq/473-3610000]”,user=“root”,cores=[“3”]},{id=“5627”,type=“process”,description=“[irq/474-3610000]”
,user=“root”,cores=[“3”]},{id=“5840”,type=“process”,description=“/sbin/dhclient -d -q -sf /usr/lib/N
etworkManager/nm-dhcp-helper -pf /run/dhclient-eth0.pid -lf /var/lib/NetworkManager/dhclient-afdf28a
b-fa9f-3b94-a909-2e2772e45c65-eth0.lease -cf /var/lib/NetworkManager/dhclient-eth0.conf eth0”,user="
root",cores=[“0”]},{id=“5958”,type=“process”,description=“/usr/sbin/nvargus-daemon”,user=“root”,core
s=[“2”,“3”]},{id=“6019”,type=“process”,description=“/bin/login -f”,user=“root”,cores=[“0”]},{id=“602
7”,type=“process”,description=“/sbin/agetty -o -p – \u --keep-baud 115200,38400,9600 ttyGS0 vt220”
,user=“root”,cores=[“0”]},{id=“6053”,type=“process”,description=“[kworker/4:1H]”,user=“root”,cores=[
“0”]},{id=“6143”,type=“process”,description=“[kworker/1:1H]”,user=“root”,cores=[“1”]},{id=“6171”,typ
e=“process”,description=“/usr/sbin/nvphsd”,user=“root”,cores=[“0”]},{id=“6176”,type=“process”,descri
ption=“/usr/sbin/gdm3”,user=“root”,cores=[“0”,“1”,“2”]},{id=“6177”,type=“process”,description=“[nvgp
u_channel_p]”,user=“root”,cores=[“1”]},{id=“6179”,type=“process”,description=“/usr/sbin/nvphsd”,user
=“root”,cores=[“3”]},{id=“6283”,type=“process”,description=“[kworker/2:1H]”,user=“root”,cores=[“2”]}
,{id=“6432”,type=“process”,description=“gdm-session-worker [pam/gdm-autologin]”,user=“root”,cores=["
0",“1”,“3”]},{id=“6478”,type=“process”,description=“/lib/systemd/systemd --user”,user=“nvidia”,cores
=[“2”]},{id=“6508”,type=“process”,description=“(sd-pam)”,user=“nvidia”,cores=[“0”]},{id=“6573”,type=
“process”,description=“-bash”,user=“nvidia”,cores=[“3”]},{id=“6577”,type=“process”,description=“/usr
/bin/gnome-keyring-daemon --daemonize --login”,user=“nvidia”,cores=[“0”,“1”,“2”,“3”]},{id=“6581”,typ
e=“process”,description=“/usr/lib/gdm3/gdm-x-session --run-script /usr/lib/gnome-session/run-systemd
-session unity-session.target”,user=“nvidia”,cores=[“1”,“2”]},{id=“6583”,type=“process”,description=
“/usr/lib/xorg/Xorg vt1 -displayfd 3 -auth /run/user/1001/gdm/Xauthority -background none -noreset -
keeptty -verbose 3”,user=“root”,cores=[“1”,“2”]},{id=“6605”,type=“process”,description=“/usr/bin/dbu
s-daemon --session --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only”,user=
“nvidia”,cores=[“1”]},{id=“6608”,type=“process”,description=“/bin/sh /usr/lib/gnome-session/run-syst
emd-session unity-session.target”,user=“nvidia”,cores=[“1”]},{id=“6711”,type=“process”,description="
/usr/bin/ssh-agent /usr/bin/im-launch env LD_PRELOAD=libgtk3-nocsd.so.0 /usr/lib/gnome-session/run-s
ystemd-session unity-session.target",user=“nvidia”,cores=[“0”]},{id=“6802”,type=“process”,descriptio
n=“systemctl --user start --wait unity-session.target”,user=“nvidia”,cores=[“2”]},{id=“6813”,type=“p
rocess”,description=“/usr/lib/aarch64-linux-gnu/indicator-sound/indicator-sound-service”,user=“nvidi
a”,cores=[“0”,“1”,“2”,“3”]},{id=“6814”,type=“process”,description=“/usr/lib/aarch64-linux-gnu/indica
tor-session/indicator-session-service”,user=“nvidia”,cores=[“0”,“1”,“3”]},{id=“6815”,type=“process”,
description=“/usr/lib/aarch64-linux-gnu/indicator-datetime/indicator-datetime-service”,user=“nvidia”
,cores=[“0”,“1”,“3”]},{id=“6817”,type=“process”,description=“/usr/lib/aarch64-linux-gnu/indicator-ap
plication/indicator-application-service”,user=“nvidia”,cores=[“0”,“1”]},{id=“6818”,type=“process”,de
scription="/usr/lib/aarch64-linux-gnu/indicator-power/indicator-power-service"
