Hi Ramesh,
Thanks for the answer.
I’ve created an admin user “nicolas” that has sudo permission, but is different from the root user.
If I do (as you suggest):
$ ssh nicolas@jetson-ip /bin/sh -c “export LD_LIBRARY_PATH="/usr/local/cuda-10.0/lib64":${LD_LIBRARY_PATH};export NVPROF_TMPDIR="/tmp";"/usr/local/cuda-10.0/bin/nvprof" --query-cuda-info; export LD_LIBRARY_PATH="/usr/local/cuda-10.0/lib64":${LD_LIBRARY_PATH};export NVPROF_TMPDIR="/tmp";"/usr/local/cuda-10.0/bin/nvprof" --version”
I get this:
export DBUS_SESSION_BUS_ADDRESS=‘unix:path=/run/user/1001/bus’
export HOME=‘/home/nicolas’
export LANG=‘en_US.UTF-8’
export LC_ADDRESS=‘fr_FR.UTF-8’
export LC_CTYPE=‘en_US.UTF-8’
export LC_IDENTIFICATION=‘fr_FR.UTF-8’
export LC_MEASUREMENT=‘fr_FR.UTF-8’
export LC_MONETARY=‘fr_FR.UTF-8’
export LC_NAME=‘fr_FR.UTF-8’
export LC_NUMERIC=‘fr_FR.UTF-8’
export LC_PAPER=‘fr_FR.UTF-8’
export LC_TELEPHONE=‘fr_FR.UTF-8’
export LC_TIME=‘fr_FR.UTF-8’
export LOGNAME=‘nicolas’
export MAIL=‘/var/mail/nicolas’
export OLDPWD=‘/home/nicolas’
export PATH=‘/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games’
export PWD=‘/home/nicolas’
export SHELL=‘/bin/zsh’
export SHLVL=‘1’
export SSH_CLIENT=‘192.168.124.33 40778 22’
export SSH_CONNECTION=‘192.168.124.33 40778 192.168.124.34 22’
export USER=‘nicolas’
export XDG_RUNTIME_DIR=‘/run/user/1001’
export XDG_SESSION_ID=‘6’
export _=‘/bin/sh’
0/(NVIDIA Tegra X1 cc=5.3)
19595265/67108865,19595265/67108866,19595265/67108867,19595265/67108868,19595265/67108913,17825807/67108914,17825807/67108915,17825807/67108916,17825807/67108917,17825807/67108918,17825807/67108919,17825807/67108920,17825807/67108921,17825807/67108922,17825807/67108923,19595271/67108924,19595271/67108925,19595271/67108926,19595271/67108927,19595271/67108928,19595271/67108929,19595271/67108930,19595271/67108931,19595271/67108932,19595271/67108933,19595271/67108934,19595271/67108935,19595271/67108936,19595271/67108937,19595271/67108938,19595271/67108939,19595271/67108940,19595271/67108941,19595271/67108942,19595271/67108943,19595271/67108944,19595271/67108945,19595271/67108946,19595271/67108948,19595271/67108949,19595271/67108947,19595271/67108950,19595271/67108951,19595271/67108952,19595271/67108953,19595271/67108954,19595271/67108955,19595271/67108956,19595271/67108957,19595271/67108958,19595271/67108959,19595270/67108873,19595270/67108874,19595270/67108877,19595270/67108878,19595270/67108881,19595270/67108885,19595270/67108889,19595270/67108893,19595270/67108905,19595270/67108909,19595270/67108897,19595270/67108901,19595270/67108882,19595270/67108886,19595270/67108890,19595270/67108894,19595270/67108906,19595270/67108910,19595270/67108898,19595270/67108902,
2001,2002,2003,2004,2005,2006,2007,2008,2009,2010,2011,2012,2013,2014,2016,2017,2018,2019,2020,2022,2029,2030,2031,2032,2033,2034,2041,2048,2049,2050,2051,2052,2053,2054,2055,2056,2057,2058,2059,2060,2061,2062,2063,2064,2065,2066,2067,2068,2069,2070,2071,2074,2084,2085,2086,2087,2088,2089,2090,2091,2092,2093,2094,2095,2096,2097,2098,2099,2100,2104,2105,2106,2107,2108,2109,2110,2111,2112,2113,2114,2115,2116,2117,2118,2119,2120,2121,2122,2123,2124,2125,2126,2127,2128,2131,2132,2133,2134,2135,2136,2137,2138,2139,2140,2144,19136513,19136514,19136515,19136516,19136517,19136518,19136519,19136520,19136521,19136522,19136523,19136524,19136525,19136526,19136528,19136529,19136532,19136533,19136534,19136535,19136536,19136537,19136538,19136539,19136541,19136542,19136549,19136550,19136552,19136553,19595269,19595270,19595274,19595275,19595276,19595277,19595278,19595279,19595280,1073741827,1073741831,1073741832,
nvprof: NVIDIA (R) Cuda command line profiler
Copyright (c) 2012 - 2018 NVIDIA Corporation
Release version 10.0.166 (21)
It appears no errors is triggered there. Does that help you figure out where the problem is coming from ?
