I am unable to remotely profile any application (even CUDA samples) using Nvidia Visual Profiler. Neither through NVVP
application nor NSight
The error message is:
My host is Ubuntu 18.04 (VirtualBox) and the device is Jetson TX2 with Jetpack 4.3. It is worth mentioning that previously I was able to profile using the host, which had been used to flash the Jetpack. However, I changed the computer and now it gives me the abovementioned error message.
The only way that I am currently able to profile an application is to use nvprof
on the device and then display it in NVVP
on the host, but this process is cumbersome.
I am starting the profiling session as a root user.
The result of command:
ssh root@[Jetson’s IP] /bin/sh -c “export LD_LIBRARY_PATH=”/usr/local/cuda-10.0/lib64":${LD_LIBRARY_PATH};export NVPROF_TMPDIR=“/tmp”;“/usr/local/cuda-10.0/bin/nvprof” --query-cuda-info; export LD_LIBRARY_PATH=“/usr/local/cuda-10.0/lib64”:${LD_LIBRARY_PATH};export NVPROF_TMPDIR=“/tmp”;“/usr/local/cuda-10.0/bin/nvprof” --version"
is:
export DBUS_SESSION_BUS_ADDRESS=‘unix:path=/run/user/0/bus’
export HOME=‘/root’
export LANG=‘en_US.UTF-8’
export LC_ADDRESS=‘pl_PL.UTF-8’
export LC_IDENTIFICATION=‘pl_PL.UTF-8’
export LC_MEASUREMENT=‘pl_PL.UTF-8’
export LC_MONETARY=‘pl_PL.UTF-8’
export LC_NAME=‘pl_PL.UTF-8’
export LC_NUMERIC=‘pl_PL.UTF-8’
export LC_PAPER=‘pl_PL.UTF-8’
export LC_TELEPHONE=‘pl_PL.UTF-8’
export LC_TIME=‘pl_PL.UTF-8’
export LOGNAME=‘root’
export MAIL=‘/var/mail/root’
export PATH=‘/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games’
export PWD=‘/root’
export SHELL=‘/bin/bash’
export SHLVL=‘1’
export SSH_CLIENT=‘192.168.137.1 61294 22’
export SSH_CONNECTION=‘192.168.137.1 61294 192.168.137.46 22’
export USER=‘root’
export XDG_RUNTIME_DIR=‘/run/user/0’
export XDG_SESSION_ID=‘31’
export _=‘/bin/sh’
0/(NVIDIA Tegra X2 cc=6.2)
20643841/83886185,20643841/83886186,20643841/83886081,20643841/83886082,20643841/83886083,20643841/83886084,20643841/83886133,20643841/83886188,20643844/83886093,20643844/83886094,20643844/83886097,20643844/83886098,20643844/83886101,20643844/83886105,20643844/83886109,20643844/83886113,20643844/83886125,20643844/83886129,20643844/83886117,20643844/83886121,20643844/83886102,20643844/83886106,20643844/83886110,20643844/83886114,20643844/83886126,20643844/83886130,20643844/83886118,20643844/83886122,20054033/83886134,20054033/83886135,20054033/83886136,20054033/83886137,20054033/83886138,20054033/83886139,20054033/83886140,20054033/83886141,20054033/83886142,20054033/83886143,20054031/83886166,20054031/83886144,20054031/83886145,20054031/83886146,20054031/83886147,20054031/83886148,20054031/83886149,20054031/83886150,20054031/83886151,20054031/83886152,20054031/83886153,20054031/83886154,20054031/83886155,20054031/83886156,20054031/83886165,20054031/83886157,20054031/83886158,20054031/83886167,20054031/83886168,20054031/83886169,20054031/83886170,20054031/83886171,20054031/83886172,20054031/83886173,20054031/83886174,20054031/83886161,20054031/83886162,20054031/83886163,20054031/83886164,20054031/83886175,20054031/83886176,20054031/83886177,20054031/83886178,20054031/83886179,20054031/83886180,20054031/83886181,20054031/83886159,20054031/83886160,
19922945,19922946,19922947,19922948,19922949,19922950,19922951,19922952,19922953,19922954,19922955,19922956,19922957,19922958,19922959,19922960,19922961,19922962,19922963,19922964,19922965,19922968,19922969,19922970,19922971,19922972,19922973,19922974,19922975,19922980,19922981,19922982,19922983,19922984,19922985,19922986,19922987,19922988,19922989,19922990,19922991,19922992,19922993,19922994,19922995,19922996,19922997,19922998,19922999,19923000,19923001,19923002,19923003,19923004,19923007,19923008,19923009,19923010,19923011,19923012,19923013,19923014,19923015,19923016,19923017,19923018,19923019,19923020,19923021,19923022,19923023,19923024,19923025,19923026,19923027,19923028,19923029,19923030,19923031,19923032,19923033,19923034,19923035,19923036,19923053,19923054,19923055,19923056,19923057,19923081,19923082,19923083,19923084,19923085,19923086,19923087,19923088,19923089,19923090,19923091,19923092,19923093,19923094,19923095,19923096,19923097,19923100,19923101,19923102,19923103,19923104,19923105,19923108,19923109,19923110,19923111,19923112,19923113,19923114,19923115,19923116,19923117,19923118,19923119,19923121,19923122,19923123,19923124,19923125,19923126,19923127,19923128,19923129,19923131,19923132,19923133,19923134,19923135,19923136,19923137,19923138,19923139,19923140,20643847,20643848,20643852,
nvprof: NVIDIA (R) Cuda command line profiler
Copyright (c) 2012 - 2018 NVIDIA Corporation
Release version 10.0.326 (21)
