Sorry, I’m new to Nvidia so I apologize in advance for any questions on this topic that might have already been answered but, I received the Jetson TX1 board from another department and while I have been able to compile and run programs, I can’t seem to find “nvvp” or NSight profilers to visually profile the program I’ve developed. I’ve also looked on Nvidia website to try and download but I don’t see a downloadable package that runs on the Jetson board.
Can someone direct me where I can find, install the profilers for the Jetson TX1 development board?
On my system I can find nvvp and nsight in /usr/local/cuda/bin/ , you might want to give that a try.
My Tegra system Profiler is instead under ~/Installs/NVIDIA_Tegra_System_Profiler/
Jetpack is run on a PC running Ubuntu and it connects to the TX1 via either USB for flashing or Ethernet for package installation or remote profiling.
I have used the Tegra System Profiler and found it very useful. On the Ubuntu PC, the System Profiler is installed from Jetpack when it installs the other host tools. Once you run the System Profiler on the PC, you can connect it to the TX1 via Ethernet and profile TX1 applications remotely (there are some environment variables that must be set up on the TX1 first).
On that note is there good notes/instructions somewhere on how to get the Jetpack programming and profile working. I have seen the one for the TK1 but it is dated and I haven’t been able to get the instructions to work even taking into account slight modifications to account for the TK1 vs TX1 setup. Seems like there is no real guide for the TX1.
I am facing a similar issue. I am not able to figure out how to run system profiler on x86_64 host machine. I have searched everywhere on my file system for the right executable but I am unable to find. It would be a great help if you can mention where or how to run the profiler on host machine.
I have installed jetpack 3.0 using x86_64 host machine on my jetson TX1 running L4T.
