Hi there
I’m trying to do remote (SSH) profiling with NSight Systems on Jetson TX2, by attaching the tool to a process. Once I start the profiling, the session ends up pretty quickly with the warnings from below:
Event requestor failed: Source ID=
Type=ErrorInformation (18)
Properties:
OriginalSource (145)=EventRequestor
Error information:
InternalError (105)
Properties:
ErrorText (100)=The operation was aborted.
ServiceName (200)=AnalysisService
MethodName (201)=GetData
Events fetch failed: Source ID=
Error information:
ProcessEventsError (4005)
Properties:
ErrorText (100)=/build/agent/work/20a3cfcd1c25021d/QuadD/Host/Analysis/SymbolAnalyzer/SymbolAnalyzer.cpp(324): Throw in function void QuadDSymbolAnalyzer::SymbolAnalyzer::HandleKernelSymbols(const QuadDTimestamp&, uint64_t, uint64_t, const boost::filesystem::path&, QuadDSymbolAnalyzer::ISymbolResolver::Continuator, QuadDSymbolAnalyzer::StateMap*, const Ptr&)
Dynamic exception type: boost::exception_detail::clone_impl
std::exception::what: GetKernelSymbolsError
[QuadDCommon::tag_error_text*] = /build/agent/work/20a3cfcd1c25021d/QuadD/Host/Analysis/SymbolAnalyzer/SymbolAnalyzer.cpp(324): The operation was aborted.
Any idea on how can I fix these?
Thanks,
B.
Thank you for reporting the issue. Do you use the latest JetPack? Could you please help us know
- Version of Nsight Systems you use — see Help→About
- Version of software on your Jetson — run "head -1 /etc/nv_tegra_release" on Jetson
I am new to using the jetson tx2. I am facing problem in installing Nsight systems for profiling the jetson tx2.
My Host machine is Windows 7 with i5 processor.
I have installed the Nsight system using the latest version NVIDIA_Nsight_Systems_Windows_2020.3.1.72.msi and the directories created in the installed path are:
- documentation
- host-windows-x64
- target-linux-x64
- target-windows-x64
When I launched the nsight-sys.exe and try to connect to the TX2 through the SSH the error message is :
NVIDIA Nsight Systems
2020.3.1.72-e5b8014 Windows-x64
- nvidia@10.60.69.50:229:
[Error] Target is not supported.
This version of Nsight Systems does not support profiling on the selected target.
Missing directory with target binaries:
C:\Program Files\NVIDIA Corporation\Nsight Systems 2020.3.1\target-linux-armv8
So what can be the issue? Is there anything required to install in order to get the directory named target-linux-armv8.
Which version has the support to armv8 ?
Is there going to be a solution to this, I am having the same problem, seems like nsight is not installing all the directories it needs.
