23:03:31 DEBUG: NVIDIA Nsight Systems - host: using adapter to install NV_L4T_NVIDIA_NSIGHT_SYSTEMS_HOST_COMP@host to /media/sky/soft/nvidia_sdk/JetPack_4.4.1_Linux
23:03:31 INFO: NVIDIA Nsight Systems - host: exec_command: sudo -E apt-get install -y --allow-downgrades ‘/media/sky/DOC/nvidia/NsightSystems-linux-public-2020.4.2.18-f0b18f6.deb’
23:03:31 INFO: NVIDIA Nsight Systems - host: Reading package lists…
23:03:31 INFO: NVIDIA Nsight Systems - host: Building dependency tree…
23:03:32 INFO: NVIDIA Nsight Systems - host: Reading state information…
23:03:32 INFO: NVIDIA Nsight Systems - host: The following NEW packages will be installed:
23:03:32 INFO: NVIDIA Nsight Systems - host: nsight-systems-2020.4.2
23:03:34 INFO: NVIDIA Nsight Systems - host: Get:1 /media/sky/DOC/nvidia/NsightSystems-linux-public-2020.4.2.18-f0b18f6.deb nsight-systems-2020.4.2 amd64 2020.4.2.18-f0b18f6 [182 MB]
23:03:35 INFO: NVIDIA Nsight Systems - host: Selecting previously unselected package nsight-systems-2020.4.2.
23:03:36 INFO: NVIDIA Nsight Systems - host: (Reading database … (Reading database … 5% (Reading database … 10% (Reading database … 15% (Reading database … 20% (Reading database … 25% (Reading database … 30% (Reading database … 35% (Reading database … 40% (Reading database … 45% (Reading database … 50% (Reading database … 55% (Reading database … 60% (Reading database … 65% (Reading database … 70% (Reading database … 75% (Reading database … 80% (Reading database … 85% (Reading database … 90% (Reading database … 95% (Reading database … 100% (Reading database … 338370 files and directories currently installed.)
23:03:36 INFO: NVIDIA Nsight Systems - host: Preparing to unpack …/NsightSystems-linux-public-2020.4.2.18-f0b18f6.deb …
23:03:36 INFO: NVIDIA Nsight Systems - host: Unpacking nsight-systems-2020.4.2 (2020.4.2.18-f0b18f6) …
23:03:48 INFO: NVIDIA Nsight Systems - host: Processing triggers for gnome-menus (3.13.3-6ubuntu3.1) …
23:03:48 INFO: NVIDIA Nsight Systems - host: Processing triggers for desktop-file-utils (0.22-1ubuntu5.2) …
23:03:48 INFO: NVIDIA Nsight Systems - host: Processing triggers for bamfdaemon (0.5.3~bzr0+16.04.20180209-0ubuntu1) …
23:03:48 INFO: NVIDIA Nsight Systems - host: Rebuilding /usr/share/applications/bamf-2.index…
23:03:48 INFO: NVIDIA Nsight Systems - host: Processing triggers for mime-support (3.59ubuntu1) …
23:03:48 INFO: NVIDIA Nsight Systems - host: Setting up nsight-systems-2020.4.2 (2020.4.2.18-f0b18f6) …
23:03:48 INFO: NVIDIA Nsight Systems - host: update-alternatives: using /opt/nvidia/nsight-systems/2020.4.2/host-linux-x64/nsys-ui to provide /usr/local/bin/nsys-ui (nsys-ui) in manual mode
23:03:48 INFO: NVIDIA Nsight Systems - host: exec_command: dpkg-query -W -f=‘${db:Status-abbrev} ${Version}’ nsight-systems-2020.4.2
23:03:48 INFO: NVIDIA Nsight Systems - host: command finished successfully
23:03:48 SUMMARY: NVIDIA Nsight Systems - host: Install completed successfully.
23:33:29 INFO: *** Retrying to install. attempt number: 2
23:33:33 DEBUG: running command < true >
23:33:33 INFO: command finished successfully
23:33:33 DEBUG: running command < sudo rm -rf ‘/media/sky/soft/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2’ >
23:33:33 INFO: [host] [sudo] password for sky:
23:34:59 INFO: command finished successfully
23:35:00 INFO: File System and OS - target_image: verifying checksum of /media/sky/DOC/nvidia/Tegra_Linux_Sample-Root-Filesystem_R32.4.4_aarch64.tbz2
23:35:00 INFO: Drivers for Jetson - target_image: verifying checksum of /media/sky/DOC/nvidia/Jetson_Linux_R32.4.4_aarch64.tbz2
23:35:21 INFO: Drivers for Jetson - target_image: Found file /media/sky/DOC/nvidia/Jetson_Linux_R32.4.4_aarch64.tbz2 with correct checksum, skip downloading.
23:35:21 DEBUG: running command < true >
23:35:21 INFO: command finished successfully
23:35:21 DEBUG: Drivers for Jetson - target_image: using adapter to install NV_L4T_DRIVERS_T186_COMP@JETSON_TX2 to /home/sky/soft/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2
23:35:21 INFO: Drivers for Jetson - target_image: NV_L4T_DRIVERS_T186_COMP include 1 package
SDKM_logs_JetPack_4.4.1_Linux_for_Jetson_TX2_2021-04-13_23-33-29.zip (335.5 KB)
