Hi there
I’m trying to do remote (SSH) profiling with NSight Systems on Jetson TX2, by attaching the tool to a process. Once I start the profiling, the session ends up pretty quickly with the warnings from below:
Event requestor failed: Source ID=
Type=ErrorInformation (18)
Properties:
OriginalSource (145)=EventRequestor
Error information:
InternalError (105)
Properties:
ErrorText (100)=The operation was aborted.
ServiceName (200)=AnalysisService
MethodName (201)=GetData
Events fetch failed: Source ID=
Error information:
ProcessEventsError (4005)
Properties:
ErrorText (100)=/build/agent/work/20a3cfcd1c25021d/QuadD/Host/Analysis/SymbolAnalyzer/SymbolAnalyzer.cpp(324): Throw in function void QuadDSymbolAnalyzer::SymbolAnalyzer::HandleKernelSymbols(const QuadDTimestamp&, uint64_t, uint64_t, const boost::filesystem::path&, QuadDSymbolAnalyzer::ISymbolResolver::Continuator, QuadDSymbolAnalyzer::StateMap*, const Ptr&)
Dynamic exception type: boost::exception_detail::clone_impl
std::exception::what: GetKernelSymbolsError
[QuadDCommon::tag_error_text*] = /build/agent/work/20a3cfcd1c25021d/QuadD/Host/Analysis/SymbolAnalyzer/SymbolAnalyzer.cpp(324): The operation was aborted.
Any idea on how can I fix these?
Thanks,
B.
