Nsight eclipse
I have connected my jetson and my host computer by ssh, to develop on the host computer using nsight eclipse.
I can build and run code on the target (run as remote, build as remote)
Furthermore, I can debug (debug as remote) the CPU but I can’t debug GPU (my host computer doesn’t have cuda capabilities, but it should not be a problem). When I enter in glolab function, the debugger crash, impossible to terminate the debugging … Do you have an idea of the problem ?
Moreother, to profile, does the host computer need to have cuda capabilities ? Because I can’t profile the code.
Last question, can I use a windows host computer ?
Thank you !
Furthermore, I always have the following message when I debug :
Warning: Adjusting return value of linux_common_core_of_thread (pid=989, tid=989).
core = 5 >= num_cores = 4!
Warning: Adjusting return value of linux_common_core_of_thread (pid=990, tid=990).
And this is not a problem from the code, it a sample hello word, which doesn’t use GPU :
#include"iostream"
int main () {
std::cout << "Hello word 1 !" << std::endl ;
return 0 ;
Here are some information share with you first.
1. Profiling tool requires root authority.
Please login the device as root and here it the detail for setting:
2. There is a known issue in CUDA 10.0 or earlier.
The issue is related to debugger memory backend and is fixed in CUDA 10.1.
***Warning: Adjusting return value of linux_common_core_of_thread (pid=989, tid=989).***
***core = 5 >= num_cores = 4!***
Thank you for your answer.
I modified the sshd_config but it still doesn’t work. Here my sshd_config :
#$OpenBSD: sshd_config,v 1.101 2017/03/14 07:19:07 djm Exp $
#This is the sshd server system-wide configuration file. See
#sshd_config(5) for more information.
#This sshd was compiled with PATH=/usr/bin:/bin:/usr/sbin:/sbin
#The strategy used for options in the default sshd_config shipped with
#OpenSSH is to specify options with their default value where
#possible, but leave them commented. Uncommented options override the
#default value.
#Port 22
#AddressFamily any
#ListenAddress 0.0.0.0
#ListenAddress ::
#HostKey /etc/ssh/ssh_host_rsa_key
#HostKey /etc/ssh/ssh_host_ecdsa_key
#HostKey /etc/ssh/ssh_host_ed25519_key
#Ciphers and keying
#RekeyLimit default none
#Logging
#SyslogFacility AUTH
#LogLevel INFO
#Authentication:
#LoginGraceTime 2m
#PermitRootLogin prohibit-password
PermitRootLogin yes
#StrictModes yes
#MaxAuthTries 6
#MaxSessions 10
#PubkeyAuthentication yes
#Expect .ssh/authorized_keys2 to be disregarded by default in future.
#AuthorizedKeysFile .ssh/authorized_keys .ssh/authorized_keys2
#AuthorizedPrincipalsFile none
#AuthorizedKeysCommand none
#AuthorizedKeysCommandUser nobody
#For this to work you will also need host keys in /etc/ssh/ssh_known_hosts
#HostbasedAuthentication no
#Change to yes if you don’t trust ~/.ssh/known_hosts for
#IgnoreUserKnownHosts no
#Don’t read the user’s ~/.rhosts and ~/.shosts files
#IgnoreRhosts yes
#To disable tunneled clear text passwords, change to no here!
#PasswordAuthentication yes
PermitEmptyPasswords no
#Change to yes to enable challenge-response passwords (beware issues with
#some PAM modules and threads)
ChallengeResponseAuthentication no
#Kerberos options
#KerberosAuthentication no
#KerberosOrLocalPasswd yes
#KerberosTicketCleanup yes
#KerberosGetAFSToken no
#GSSAPI options
#GSSAPIAuthentication no
#GSSAPICleanupCredentials yes
#GSSAPIStrictAcceptorCheck yes
#GSSAPIKeyExchange no
#Set this to ‘yes’ to enable PAM authentication, account processing,
#and session processing. If this is enabled, PAM authentication will
#be allowed through the ChallengeResponseAuthentication and
#PasswordAuthentication. Depending on your PAM configuration,
#PAM authentication via ChallengeResponseAuthentication may bypass
#the setting of “PermitRootLogin without-password”.
#If you just want the PAM account and session checks to run without
#PAM authentication, then enable this but set PasswordAuthentication
#and ChallengeResponseAuthentication to ‘no’.
UsePAM yes
#AllowAgentForwarding yes
#AllowTcpForwarding yes
#GatewayPorts no
X11Forwarding yes
#X11DisplayOffset 10
#X11UseLocalhost yes
#PermitTTY yes
PrintMotd no
#PrintLastLog yes
#TCPKeepAlive yes
#UseLogin no
#PermitUserEnvironment no
#Compression delayed
#ClientAliveInterval 0
#ClientAliveCountMax 3
#UseDNS no
#PidFile /var/run/sshd.pid
#MaxStartups 10:30:100
#PermitTunnel no
#ChrootDirectory none
#VersionAddendum none
#no default banner path
#Banner none
#Allow client to pass locale environment variables
AcceptEnv LANG LC_*
#override default of no subsystems
Subsystem sftp /usr/lib/openssh/sftp-server
#Example of overriding settings on a per-user basis
#Match User anoncvs
#X11Forwarding no
#AllowTcpForwarding no
#PermitTTY no
#ForceCommand cvs server
Ok great. When cuda 10.1 will be available for jetson TX2 ? And will I need sdkmanager to update the jetson ?
Thank you !
To give more details, the profiler give the following message in the console :
======== Warning: OpenACC Profiling is not supported on the underlying platform.
[Vector addition of 50000 elements]
logout
I launched Addvector cuda example
I have updated the detail steps for VectorAdd on the below topic:
Let us check the following status on topic 116720 directly.
