Actually, I need to process some images with the jetson TX2.
I wanted to develop directly on the jetson TX2. So I began with codeblocks, but there is not a comprehensive system which allow to develop directly on the jetson. To perform my program, I have to use the GPU.
I need a tool which include debugger CPU/GPU, profile. A comprehensive tool !
The only seems to be nsight eclipse, and nsight eclipse doesn’t support jetson environment, so I have to use a host computer …
I have flashed the jetson from the host computer, and the environment development was installing in the same time in the host computer.
I tried a simple code :
#include<stdio.h>
global void cuda_hello(){
printf(“Hello World from GPU!\n”);
int main() {
cuda_hello<<<1,1>>>();
return 0;
I have the following error :
Incremental Build of configuration Debug for project Test_1
make all -C /home/jetson/Cuda_Target/Debug
make: Entering directory ‘/home/jetson/Cuda_Target/Debug’
Building file: …/main.cu
Invoking: NVCC Compiler
nvcc -G -g -O0 -ccbin aarch64-linux-gnu-g++ -gencode arch=compute_35,code=sm_35 -m64 -odir “.” -M -o “main.d” “…/main.cu”
subdir.mk:18: recipe for target ‘main.o’ failed
/bin/sh: 1: nvcc: not found
make: Leaving directory ‘/home/jetson/Cuda_Target/Debug’
make: [main.o] Error 127
I have nvcc, and I add the path in the host computer :
export PATH=/usr/local/cuda-10.0/bin:/usr/local/cuda-10.0/NsightCompute-1.0${PATH:+:${PATH}}
export LD_LIBRARY_PATH=/usr/local/cuda-10.0/lib64${LD_LIBRARY_PATH:+:${LD_LIBRARY_PATH}}
I don’t understand the error.
Furthermore, I already have installed all librairies in the jetson to communicate with a Gige camera. Do I have to install all the libraries on the host computer too ? And how link the librairies ? I didn’t find a comprehensive example.
I have an other question. Does the host need to require hardware and software specification ? To flash the jetson, the host computer has to run with ubuntu 16.04/18.04, and at least 8Go of RAM. But only to develop code and connect by ssh, can I use a host computer which runs in windows, with 6Go of RAM ?
Thank you for your help !
