what is the status on Jetson support in nvidia nsight ecclipse? On windows? On linux?
with nvidia nsight?
with nsight visual studio?
is it supported to run cuda-gdb directly on a jetson device as per today?
thanks
this windows cuda integration with visual studio doesn’t support jetson cross building/ remote debugging, does it?
You will need to use nsight EE on the Linux system for Jetson.
CUDA-gdb can work on Jetson:
@AastaLLL the url seems maybe outdated?
it doesn’t address the process of installing the EE / Nsight EE on linux, as there is neither download url no instruction there? Am I right?
The tool is integrated into the CUDA toolkit.
Suppose you already install the CUDA toolkit from JetPack for the host.
Then you can find it in /usr/local/cuda-10.2/bin.
