Hi folks,
It will be really helpful if anyone can help me in “How to install Nsight Eclipse in CUDA in Ubuntu 12.04 Platform”?? I have searched a lot in the Internet but couldn’t find any satisfactory answer.
Thanks-
Anik
Hi folks,
Thanks-
Anik
Get the CUDA 6 toolkit (download the RUN installer) for ubuntu 12.04 and install it:
https://developer.nvidia.com/cuda-downloads
After the toolkit is installed, type
nsight
at a terminal/command prompt.
http://docs.nvidia.com/cuda/pdf/CUDA_Getting_Started_Linux.pdf
http://docs.nvidia.com/cuda/nsight-eclipse-edition-getting-started-guide/index.html#abstract
Hi, i installed the CUDA toolkit 7.0 successed,(when i run nvcc -V, nvcc: NVIDIA ® Cuda compiler driver
Copyright © 2005-2015 NVIDIA Corporation Built on Fri_Oct_16_15:23:46_CDT_2015 Cuda compilation tools, release 7.0, V7.0.70) but when i run nsight or nvvp, there have nothing.
and i can’t find anything about nsight and nvvp in my computer fold!
is it mean uninstalled the nsight? how to install it?
i use the ubuntu14.04 on my jetson tx1.
I guess you have not installed CUDA 7 correctly.
You may need to reinstall your Jetson from JetPack
I didn’t install the JetPack, and i need’t use the cross compile, so i don’t want to use the jetPack.Is there any other way to install the nsight?
