I am a novice in applications development on Jetson TX1 developer kit. I need to develop and debug OpenCV and CUDA applications directly on the developer kit and not remote development.
Is there any IDE which I can install directly on the Ubuntu for Tegra that comes with the TX1?
I like using QT Creator. It works well with CMAKE and I really like the debugger.
You can try Eclipse too, especially if you are planning on programming in Python using the PyDev module, but if you are planning on developing solely in C++ I’d recommend QT Creator.
up at top of page on my chromium it says “nvidia accelerated computing” and clickable “Downloads” link that will take you to informative page on development. and QT Creator is my choice also plus it is included in tx1 install.
Thank you for your reply. But I read that Nsight Eclipse Edition comes with the CUDA toolkit only. So can you please tell me if I must install the CUDA toolkit on the Jetson TX1 to get Nsight?
Please note that I want to start developing directly on Jetson TX1 Board.
I installed the CUDA toolkit on my tx1 board successed, but i think it not installed the Nsight(although it installed if you install cuda by JetPack on your host pc). when i run “nsight”, there have nothing on my commond line.
So, i wonder how to install the Nsight on the TX1 directly?
If you look at a Jetson with CUDA installed you’ll see that “/var” contains a cuda-repo-version… subdirectory (and probably another directory with opencv4tegra-repo). Any “.deb” file there will be visible to “apt search” package management. If one of those installed nVidia repos contains nsight you will be able to find it with “apt search”. However, I do not know if there is an nsight for aarch64 native execution.
There have nothing refered with nsight in the cuda-repo-version and opencv4tegra-repo, and when i run “apt search nsight”, i can see:
ubuntu@tegra-ubuntu:~$ apt search nsight
Sorting... Done
Full Text Search... Done
carmetal/trusty 3.5.2+dfsg-1 all
dynamic geometry software with highly ergonomic UI
cmake/trusty,now 2.8.12.2-0ubuntu3 armhf [installed]
cross-platform, open-source make system
cobertura/trusty 1.9.4.1+dfsg-3 all
java tool that calculates the percentage of code accessed by tests
elastix/trusty 4.5-4 armhf
toolbox for rigid and nonrigid registration of images
elastix-doc/trusty 4.5-4 all
toolbox for rigid and nonrigid registration of images - docs
fonts-sil-andika/trusty 1.002-4 all
extended smart Unicode Latin/Greek font family for literacy
insighttoolkit3-examples/trusty 3.20.1+git20120521-5 all
Image processing toolkit for registration and segmentation - examples
insighttoolkit4-examples/trusty 4.5.0-3 all
libacme-bleach-perl/trusty 1.150-1 all
Perl module for really clean programs
libacme-eyedrops-perl/trusty 1.61-1 all
funny way for visual programming in Perl
libcobertura-java/trusty 1.9.4.1+dfsg-3 all
java library that calculates the percentage of code accessed by tests
libinsighttoolkit3-dev/trusty 3.20.1+git20120521-5 armhf
Image processing toolkit for registration and segmentation - development
libinsighttoolkit3.20/trusty 3.20.1+git20120521-5 armhf
Image processing toolkit for registration and segmentation - runtime
libpath-class-perl/trusty 0.33-1 all
module for cross-platform path specification manipulation
paml-doc/trusty 4.7-1 all
Documentation for PAML
perlprimer/trusty 1.1.21-2 all
Graphical design of primers for PCR
qiime/trusty 1.8.0+dfsg-2 armhf
Quantitative Insights Into Microbial Ecology
qiime-doc/trusty 1.8.0+dfsg-2 all
Quantitative Insights Into Microbial Ecology (tutorial)
ruby-rack-piwik/trusty 0.2.2-2 all
piwik Analytics racking in your Ruby-Rack based project
so, can i think it’s not support the jetson native?
Looks like nsight for arm64 is not visible to the package manager. I have not heard of any plans to make nsight available for native arm64, and it seems nsight was really meant for running on a higher powered desktop host instead, so I don’t know if it would make sense to port this to a Jetson. That’s up to the tools people though, so who knows?
Perhaps if we knew more about your use case and why you want to develop directly on the TX1 with nsight there might be some workaround, e.g., you could run nsight on a very cut down x86_64 machine with no monitor by doing remote display to the Jetson from the x86_64…more or less treating the Jetson as host so you wouldn’t need a complete system on the x86_64 side.
