Failed to execute MI command
Hi, all
I am trying to run nsight on host PC for xavier cuda profiling.
However, when I ran debug, I got the following error message.
Error in final launch sequence
Failed to execute MI command:
-target-select remote 143.248.139.94:2345
Error message from debugger back end:
Can't kill process
Can't kill process
What is the meaning of this error message? How can I handle this error?
======= Debug configuration ========
Remote executable: /usr/src/tensorrt/bin/trtexec
Debugger port: 2345
Program arguments: --onnx=/usr/src/tensorrt/model/alexnet.onnx
CUDA GDB executable: cuda-gdb
CUDA GDB init file: .cuda-gdbinit
Using CUDA-GDB Remote Debugging Launcher
The version of cuda-gdb on xavier:
nvidia@xavier:~$ cuda-gdb
NVIDIA (R) CUDA Debugger
10.2 release
Portions Copyright (C) 2007-2019 NVIDIA Corporation
GNU gdb (GDB) 7.12
The version of cuda-gdb on host PC:
9.1 release
Portions Copyright (C) 2007-2017 NVIDIA Corporation
GNU gdb (GDB) 7.12
I used JetPack4.3 for installation.
Do you link Xavier with root account?
Please noticed that you will need to login as root to get the authority for CUDA profiling.
A detail steps to achieve this can be found here:
Thank you for the reply.
I solved the error by permitting root login.
vi /etc/ssh/sshd_config
edit the line '#PermitRootLogin prohibit-password'
to 'PermitRootLogin yes'
However, I again faced another error message.
CUDA Device Not Recognized
One or more CUDA devices were not recognized. As a result, metrics and events may be unavailable for those devices.
CUDA IDE
Timed out query for the list of devices. It is likely hat the device is suspended on a breakpoint. Do you want to retry detecting the devices?
I checked that it is not problem to run a remote application, but debug remote application doesn’t work, showing above error message.
How can I handle this problem?
Any help will be very appreciated.
Thanks in advance.
Regards.
=========debug configuration=========
remote connection: root@xxx.xxx.xxx.xx
remote executable: /usr/src/tensorrt/bin/trtexec_debug
debugger port: 2345
program arguments: --deploy=/usr/src/tensorrt/data/caffe_model/alexnet/deploy.prototxt --output=prob --useDLACore=0
Toolkit path: /usr/local/cuda-10.2/bin
We will need to reproduce this issue first before giving a further suggestion.
Would you mind to share a detail steps to reproduce this with us?
