Hi Folks,
I am looking to diagnose my code with visual profiler. I am able to ‘launch and attach to’ my executable from profiler running on host. THe profiler is almost working. However I am not able to see my code symbols (function names) - I see addresses instead. I am suspecting that I am missing few components in system which supports symbol resolution. May be I am not compiling my executable with right profiling option.
- Is there a integrated list of prerequisites which need to be installed, on jetson tx2, in order to support profiler ? I see few components mentioned here -
https://www.youtube.com/watch?v=R_GzhZe8IcM
When I try to install these components I run into -
nvidia@tegra-ubuntu:~$ sudo apt-get install libstdc++6-4.8-dbg
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following package was automatically installed and is no longer required:
libuv1
Use 'sudo apt autoremove' to remove it.
The following additional packages will be installed:
gcc-4.8-base libgcc-4.8-dev libgcc1-dbg libstdc++-4.8-dev
Suggested packages:
libstdc++-4.8-doc
The following NEW packages will be installed:
gcc-4.8-base libgcc-4.8-dev libgcc1-dbg libstdc++-4.8-dev libstdc++6-4.8-dbg
0 upgraded, 5 newly installed, 0 to remove and 274 not upgraded.
1 not fully installed or removed.
Need to get 3,951 kB of archives.
After this operation, 36.6 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://ports.ubuntu.com/ubuntu-ports xenial/universe arm64 gcc-4.8-base arm64 4.8.5-4ubuntu2 [15.3 kB]
Get:2 http://ports.ubuntu.com/ubuntu-ports xenial/universe arm64 libgcc-4.8-dev arm64 4.8.5-4ubuntu2 [162 kB]
Get:3 http://ports.ubuntu.com/ubuntu-ports xenial/universe arm64 libstdc++-4.8-dev arm64 4.8.5-4ubuntu2 [1,052 kB]
Get:4 http://ports.ubuntu.com/ubuntu-ports xenial/main arm64 libgcc1-dbg arm64 1:6.0.1-0ubuntu1 [79.9 kB]
Get:5 http://ports.ubuntu.com/ubuntu-ports xenial/universe arm64 libstdc++6-4.8-dbg arm64 4.8.5-4ubuntu2 [2,642 kB]
Fetched 3,951 kB in 2s (1,695 kB/s)
Selecting previously unselected package gcc-4.8-base:arm64.
(Reading database ... 221791 files and directories currently installed.)
Preparing to unpack .../gcc-4.8-base_4.8.5-4ubuntu2_arm64.deb ...
Unpacking gcc-4.8-base:arm64 (4.8.5-4ubuntu2) ...
Selecting previously unselected package libgcc-4.8-dev:arm64.
Preparing to unpack .../libgcc-4.8-dev_4.8.5-4ubuntu2_arm64.deb ...
Unpacking libgcc-4.8-dev:arm64 (4.8.5-4ubuntu2) ...
Selecting previously unselected package libstdc++-4.8-dev:arm64.
Preparing to unpack .../libstdc++-4.8-dev_4.8.5-4ubuntu2_arm64.deb ...
Unpacking libstdc++-4.8-dev:arm64 (4.8.5-4ubuntu2) ...
Selecting previously unselected package libgcc1-dbg:arm64.
Preparing to unpack .../libgcc1-dbg_1%3a6.0.1-0ubuntu1_arm64.deb ...
Unpacking libgcc1-dbg:arm64 (1:6.0.1-0ubuntu1) ...
Selecting previously unselected package libstdc++6-4.8-dbg:arm64.
Preparing to unpack .../libstdc++6-4.8-dbg_4.8.5-4ubuntu2_arm64.deb ...
Unpacking libstdc++6-4.8-dbg:arm64 (4.8.5-4ubuntu2) ...
Setting up fluxgui (1:1.1.11~pre~20171222-gf22fdbf-1~xenial) ...
Unsupported platform: 'arm64'
fluxgui is NOT installed.
dpkg: error processing package fluxgui (--configure):
subprocess installed post-installation script returned error exit status 1
Setting up gcc-4.8-base:arm64 (4.8.5-4ubuntu2) ...
Setting up libgcc-4.8-dev:arm64 (4.8.5-4ubuntu2) ...
Setting up libstdc++-4.8-dev:arm64 (4.8.5-4ubuntu2) ...
Setting up libgcc1-dbg:arm64 (1:6.0.1-0ubuntu1) ...
Setting up libstdc++6-4.8-dbg:arm64 (4.8.5-4ubuntu2) ...
Errors were encountered while processing:
fluxgui
E: Sub-process /usr/bin/dpkg returned an error code (1)
- Do I need to necessarily compile code with -g option to support profiling ?
Please help.
