I can’t use cuda-gdb on my machine, whether I use sudo or not, here is the error message I get from cuda-gdb:
Could not find CUDA Debugger back-end. Please try upgrading/re-installing the GPU driver
The CUDA driver has hit an internal error.
Error code: 0x1012400000001c
Further execution or debugging is unreliable.
Please ensure that your temporary directory is mounted with write and exec permissions.
My system:
- arch linux 6.0.2-arch1-1
- /tmp has rwx permission
nvidia-smi
Fri Nov 25 16:32:11 2022
| NVIDIA-SMI 520.56.06 Driver Version: 520.56.06 CUDA Version: 11.8 |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 3050 Ti Mobile On | 00000000:01:00.0 Off | N/A |
| N/A 62C P8 11W / N/A | 2MiB / 4096MiB | 0% Default |
| | | N/A |
Any idea?
Hi @benjamin.rouxel1
Thank you for your report. Looks like your CUDA driver installation might be missing a debugger back-end library (introduced in CUDA 11.8). Could you please provide the following additional information:
- How did you install the GPU driver? Could you provide a link to the package/installer?
- Please share the output of the following command in the directory, where
libcuda.so.1 is located (e.g. /usr/lib/x86_64-linux-gnu but might be different on Arch):
ls -la libcuda*
Hi
ls -la libcuda*
lrwxrwxrwx 1 root root 12 19 oct. 00:50 libcuda.so -> libcuda.so.1
lrwxrwxrwx 1 root root 20 19 oct. 00:50 libcuda.so.1 -> libcuda.so.520.56.06
-rwxr-xr-x 1 root root 26M 19 oct. 00:50 libcuda.so.520.56.06
I installed the driver (and cuda) using the package manager pacman/yay, https://archlinux.org/packages/extra/x86_64/nvidia/.
Ok, looks like the installer is missing the newly added libcudadebugger.so.1 file. What you can do right now (untill Arch GPU Driver package is updated):
- Try running the debugger with
export CUDBG_USE_LEGACY_DEBUGGER=1 environment variable. This should use the debugger back-end in libcuda.so.
- Install GPU driver via official Nvidia installer Linux x64 (AMD64/EM64T) Display Driver | 520.56.06 | Linux 64-bit | NVIDIA
- Obtain the .run installer from the link above, un-pack it and copy the
libcudadebugger* libraries to a specific directory. Add this directory to the LD_LIBRARY_PATH when running the debugger session (dlopen("libcudadebugger.so.1") should work).
Thanks for you answer.
I get fatal: The CUDA driver initialization failed. (error code = CUDBG_ERROR_INITIALIZATION_FAILURE(0x14)
./NVIDIA-Linux-x86_64-520.56.06.run -x
ls -l /usr/local/lib/libcudadeb*
lrwxrwxrwx 1 root root 28 27 nov. 17:32 /usr/local/lib/libcudadebugger.so -> libcudadebugger.so.520.56.06
lrwxrwxrwx 1 root root 28 27 nov. 17:32 /usr/local/lib/libcudadebugger.so.1 -> libcudadebugger.so.520.56.06
-rwxr-xr-x 1 root root 11M 30 sept. 18:07 /usr/local/lib/libcudadebugger.so.520.56.06
echo $LD_LIBRARY_PATH
.... :/usr/local/lib: ....
export CUDBG_USE_LEGACY_DEBUGGER=0
I (strangely) get: fatal: No CUDA capable device was found. (error code = CUDBG_ERROR_NO_DEVICE_AVAILABLE(0x27)
I rebooted. For some reasons sometimes the driver or the GPU gets bloated, and I have to reboot. The second solution works perfectly.
Thank you.
Thank you for confirming that it worked for you!
