I try to implement a program in CUDA which I have done in C++ before. I wouldn’t call me a really experienced programmer, so it can be, that my problem is a basic understanding problem of the declaration.
The program I want to implement is quite complex, so, to not loose the overview, I would like to organize it in several files and functions. These functions include partly C (or C++) code or CUDA code.
I tried some basic function calls to get used how to define my functions, but I get error messages, which I don’t understand.
The code I post is not doing anything, I it just to test the function calls
This is my main.cu which should just call a C function whihch then calls the kernel
#include "function_host.cuh"
int main(){
function_host();;
Here the function which is called. And here is my first confusion, in the beginning I tried adding the extern “C” and the function name, to tell the compiler that it should be compiled as C code, However it just works without the extern “C”.
#include "test_kernel.cu"
void function_host(){
dim3 grid=1;
dim3 threads=1;
test_kernel<<<grid,threads>>>();
And here my kernel funtion test_kernel.cu.
#ifndef _TEST__KERNEL_CU_
#define _TEST_KERNEL_CU_
__global__ void test_kernel(){
int g[10];
for(int i =0; i<10; i++){
g[i]=i;
#endif
If I start it like that, I’ll get the error code ‘multiple definition of globfunc_Z11test_kernelv’. However if I change ‘global’ to ‘device’ it works fine. So even I don’t put a 'global 'to the ‘function_host’, it seemed to be considered as the kernel!? In the NVIDIA programming guide it is said that any function with no extra declaration is handled as host! So why does that happen?
Apart from that, when is it useful to integrate the definition of a function in a header file and when in the normal source file. In my C++ code I made a header file for each source file containing all the definitions, however I already realized, that this doesn’t work with CUDA.
So I guess this is really a basic understanding problem of how to define functions, but I already spent some hours in figuring it out and I don’t get it.
thanks for any help!!
tom
P:D: I am working on Linux Redhat 4.3, using Netbeans as IDE for C++ and Cuda.
