hello.
I’m developing using SDK 32.6.1 and found the following symptoms.
When changing the system time backwards, I noticed that the decoder sometimes freezes (reproducibility is not 100%).
After the issue is reproduced, changing the time back to the current time, the decoder works fine again.
At this point, the callstack looks like this
#0 0x0000007f712402a4 in futex_wait_cancelable (private=, expected=0, futex_word=0x428af08c) at …/sysdeps/unix/sysv/linux/futex-internal.h:88
#1 __pthread_cond_wait_common (abstime=0x0, mutex=0x428af030, cond=0x428af060) at pthread_cond_wait.c:502
#2 __pthread_cond_wait (cond=0x428af060, mutex=0x428af030) at pthread_cond_wait.c:655
#3 0x0000007f6e94dfdc in ?? () from /usr/lib/aarch64-linux-gnu/tegra/libnvos.so
#4 0x0000007f5006cbf0 in TegraV4L2_Poll_CPlane () from /usr/lib/aarch64-linux-gnu/tegra/libtegrav4l2.so
#5 0x0000007f500ab2e4 in plugin_ioctl () from /usr/lib/aarch64-linux-gnu/libv4l/plugins/nv/libv4l2_nvvideocodec.so
#6 0x0000007f7da32db0 in v4l2_ioctl () from /usr/lib/aarch64-linux-gnu/tegra/libv4l2.so.0
#7 0x0000000001f3ac04 in NvV4l2ElementPlane::dqBuffer (this=0x4187d718, v4l2_buf=…, buffer=buffer@entry=0x7f0524f348, shared_buffer=shared_buffer@entry=0x0, num_retries=num_retries@entry=0)
at Sample/samples/common/classes/NvV4l2ElementPlane.cpp:126
My guess is that it’s a related issue with pthread_cond_t used in pthread_cond_wait() , pthread_cond_timedwait() between threads when changing the system time to the past (using CLOCK_REALTIME instead of CLOCK_MONOTONIC, etc.), but it’s hard to confirm as the code is not publicly available.
In this regard, I would appreciate if you could share code from libtegrav4l2.so, libnvos.so, etc. or provide guidance.
