I’m trying to decode an RTSP stream created by an IP camera… I’m able to do so on a development PC, but not on the TX2.
Here’s the problem case of decoding the RTSP stream with GST_DEBUG=3 set:
logidelic@mytx2:~$ export GST_DEBUG=3
logidelic@mytx2:~$ gst-launch-1.0 rtspsrc location='rtsp://192.168.42.10/vid' ! rtph264depay ! h264parse ! omxh264dec ! nvoverlaysink
0:00:00.042800104 2976 0x588d80 WARN omx gstomx.c:2826:plugin_init: Failed to load configuration file: Valid key file could not be found in search dirs (searched in: /home/logidelic/.config:/etc/xdg as per GST_OMX_CONFIG_DIR environment variable, the xdg user config directory (or XDG_CONFIG_HOME) and the system config directory (or XDG_CONFIG_DIRS)
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://192.168.42.10/vid
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
Progress: (request) SETUP stream 0
Progress: (request) SETUP stream 1
Progress: (open) Opened Stream
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Progress: (request) Sending PLAY request
0:00:00.205467018 2976 0x7fa4035630 FIXME default gstutils.c:3766:gst_pad_create_stream_id_internal:<fakesrc0:src> Creating random stream-id, consider implementing a deterministic way of creating a stream-id
0:00:00.206109678 2976 0x7fa4035680 FIXME default gstutils.c:3766:gst_pad_create_stream_id_internal:<fakesrc1:src> Creating random stream-id, consider implementing a deterministic way of creating a stream-id
Progress: (request) Sent PLAY request
0:00:00.342464070 2976 0x7f90004370 WARN basesrc gstbasesrc.c:2948:gst_base_src_loop:<udpsrc3> error: Internal data flow error.
0:00:00.342520838 2976 0x7f90004370 WARN basesrc gstbasesrc.c:2948:gst_base_src_loop:<udpsrc3> error: streaming task paused, reason not-linked (-1)
0:00:00.350205761 2976 0x7f78003230 FIXME videodecoder gstvideodecoder.c:946:gst_video_decoder_drain_out:<omxh264dec-omxh264dec0> Sub-class should implement drain()
0:00:00.497926223 2976 0x7f900042d0 WARN basesrc gstbasesrc.c:2948:gst_base_src_loop:<udpsrc1> error: Internal data flow error.
0:00:00.497985296 2976 0x7f900042d0 WARN basesrc gstbasesrc.c:2948:gst_base_src_loop:<udpsrc1> error: streaming task paused, reason not-negotiated (-4)
ERROR: from element /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc1: Internal data flow error.
Additional debug info:
gstbasesrc.c(2948): gst_base_src_loop (): /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc1:
Execution ended after 0:00:00.293162251
Setting pipeline to READY ...
Setting pipeline to NULL ...
0:00:00.499698973 2976 0x5ca4f0 WARN rtspsrc gstrtspsrc.c:5510:gst_rtspsrc_try_send:<rtspsrc0> receive interrupted
0:00:00.499747069 2976 0x5ca4f0 WARN rtspsrc gstrtspsrc.c:7552:gst_rtspsrc_pause:<rtspsrc0> PAUSE interrupted
0:00:00.501402154 2976 0x5ca4f0 WARN rtspsrc gstrtspsrc.c:5483:gst_rtspsrc_try_send:<rtspsrc0> send interrupted
0:00:00.501447243 2976 0x5ca4f0 WARN rtspsrc gstrtspsrc.c:7020:gst_rtspsrc_close:<rtspsrc0> TEARDOWN interrupted
Freeing pipeline ...
Here’s an example of fetching and parsing (and saving) the RTSP stream on the TX2 without error:
logidelic@mytx2:~$ gst-launch-1.0 rtspsrc location='rtsp://192.168.42.10/vid' ! rtph264depay ! h264parse ! matroskamux ! filesink location=a.ts
^Chandling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 0:00:19.988372229
Any help would be greatly appreciated!
Thank you!
