I have an issue with the streammux configuration. After running three streams with an ingestion FPS of 20, I noticed that after about three days, the processing FPS for all three streams drops to around 17, even though the ingestion FPS remains at 20.
When I stop and restart the pipeline, the processing FPS returns to 20.
Could you please help me understand why this degradation occurs and how to prevent it?
Best regards,
config_mux_source3.txt (2.5 KB)
Amine
• DeepStream Version
• TensorRT Version
• Hardware Platform GPU
• DeepStream Version deepstream 8.0
Please provide details about the issue
I have 3 streams with an ingestion FPS of 20. After 4 days, the last camera becomes partially used, and the processing FPS drops to 17 for all 3 cameras, even though the ingestion FPS remains 20.
I am working on a people-counting task. The number of people detected in the first 2 sources is correct, but for the last source, the count becomes incorrect in certain cases when the processing FPS for all 3 cameras drops to 17.
Please provide the complete pipeline and configurations, it will be better if you can provide the source code for reproduce the issue.
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one. Thanks.
