Has been observing FPS drop in Deepstream pipeline during stream downtime
Example- If the pipeline is processing 10 stream at 10 Fps,in case of any one or two stream going down,the fps of the whole pipeline will be going down like 4 or 5 fps per stream
Appsrc→jpegparse→nvv4l2dec→mux→….down stream elements
• DeepStream Version
• TensorRT Version
Notcing you are testing a custom code, can you use DeepStream sample to reprodcue this issue? are you using old nvstreammux or new nvstreammux? Please refer to this faq How to set parameters reasonably to improve the efficiency of nvstreammux in live mode.
Testing with deepstream-app, I am not able to reproduce this issue, after one rtsp source was closed, the fps of other source did not change. Here is the log deepstream-app.txt (5.4 KB)
Hi! Since we haven’t heard back from you for a while, we’re assuming everything is resolved and will close this topic. If you need any further help, don’t hesitate to open a new topic. Thanks!
