I’m using only one video card both for CUDA computing and video output for my monitor. Is this a correct configuration?
What should I be careful?
Is there the risk that video memory used for video output could corrupt the memory I use in CUDA computing?
yes, there is a risk, since the OS video display task takes priority over a CUDA kernel.
Your kernels can be killed or memory taken by force… you need to always check error result codes.
BUT in practice this is not a problem. The display uses a fixed size of RAM and therefore never needs to override a CUDA context’s allocations.
The very rare but possible exception is when a user increases screen resolution or adds new display monitors while your CUDA context is active in a different process.
Bugs in the kernel may even cause a BSOD.
http://forums.nvidia.com/index.php?showtopic=94524
http://forums.nvidia.com/index.php?showtopic=91635
Other than that, I don’t see why it should be a big problem. It won’t damage the GPU.
