yes i moved on that folder now not getting any error it compiled successfully but when i get to access class id it can’t print in terminal what is the reason?
smart record event does not store in event instead of storing the frame every 10 seconds
- Copyright (c) 2020, NVIDIA CORPORATION. All rights reserved.
- Permission is hereby granted, free of charge, to any person obtaining a
- copy of this software and associated documentation files (the “Software”),
- to deal in the Software without restriction, including without limitation
- the rights to use, copy, modify, merge, publish, distribute, sublicense,
- and/or sell copies of the Software, and to permit persons to whom the
- Software is furnished to do so, subject to the following conditions:
- The above copyright notice and this permission notice shall be included in
- all copies or substantial portions of the Software.
- THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
- THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
- FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
- DEALINGS IN THE SOFTWARE.
#include <gst/gst.h>
#include <gst/app/gstappsrc.h>
#include <gst/app/gstappsink.h>
#include <glib.h>
#include <stdio.h>
#include <string.h>
#include <cuda_runtime_api.h>
#include “gstnvdsmeta.h”
#define MAX_DISPLAY_LEN 64
#define PGIE_CLASS_ID_VEHICLE 0
#define PGIE_CLASS_ID_PERSON 2
#define CUSTOM_PTS 1
/* Muxer batch formation timeout, for e.g. 40 millisec. Should ideally be set
- based on the fastest source’s framerate. */
#define MUXER_BATCH_TIMEOUT_USEC 33000
gint frame_number = 0;
/* Structure to contain all our information for appsrc,
- so we can pass it to callbacks */
typedef struct _AppSrcData
GstElement *app_source;
long frame_size;
FILE file; / Pointer to the raw video file /
gint appsrc_frame_num;
guint fps; / To set the FPS value /
guint sourceid; / To control the GSource */
} AppSrcData;
/* new_sample is an appsink callback that will extract metadata received
- tee sink pad and update params for drawing rectangle,
*object information etc. */
static GstFlowReturn
new_sample (GstElement * sink, gpointer * data)
GstSample *sample;
GstBuffer *buf = NULL;
guint num_rects = 0;
NvDsObjectMeta *obj_meta = NULL;
guint vehicle_count = 0;
guint person_count = 0;
NvDsMetaList *l_frame = NULL;
NvDsMetaList *l_obj = NULL;
unsigned long int pts = 0;
sample = gst_app_sink_pull_sample (GST_APP_SINK (sink));
if (gst_app_sink_is_eos (GST_APP_SINK (sink))) {
g_print (“EOS received in Appsink********\n”);
if (sample) {
/* Obtain GstBuffer from sample and then extract metadata from it. */
buf = gst_sample_get_buffer (sample);
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next) {
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
pts = frame_meta->buf_pts;
for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
l_obj = l_obj->next) {
obj_meta = (NvDsObjectMeta *) (l_obj->data);
if (obj_meta->class_id == PGIE_CLASS_ID_VEHICLE) {
vehicle_count++;
num_rects++;
if (obj_meta->class_id == PGIE_CLASS_ID_PERSON) {
person_count++;
num_rects++;
g_print ("Frame Number = %d Number of objects = %d "
"Vehicle Count = %d Person Count = %d PTS = %" GST_TIME_FORMAT "\n",
frame_number, num_rects, vehicle_count, person_count,
GST_TIME_ARGS (pts));
frame_number++;
gst_sample_unref (sample);
return GST_FLOW_OK;
return GST_FLOW_ERROR;
static gboolean
bus_call (GstBus * bus, GstMessage * msg, gpointer data)
GMainLoop *loop = (GMainLoop *) data;
switch (GST_MESSAGE_TYPE (msg)) {
case GST_MESSAGE_EOS:
g_print (“End of stream\n”);
g_main_loop_quit (loop);
break;
case GST_MESSAGE_ERROR:{
gchar *debug;
GError *error;
gst_message_parse_error (msg, &error, &debug);
g_printerr (“ERROR from element %s: %s\n”,
GST_OBJECT_NAME (msg->src), error->message);
if (debug)
g_printerr (“Error details: %s\n”, debug);
g_free (debug);
g_error_free (error);
break;
default:
break;
return TRUE;
/* This method is called by the idle GSource in the mainloop,
- to feed one raw video frame into appsrc.
- The idle handler is added to the mainloop when appsrc requests us
- to start sending data (need-data signal)
- and is removed when appsrc has enough data (enough-data signal).
static gboolean
read_data (AppSrcData * data)
GstBuffer *buffer;
GstFlowReturn gstret;
size_t ret = 0;
GstMapInfo map;
buffer = gst_buffer_new_allocate (NULL, data->frame_size, NULL);
gst_buffer_map (buffer, &map, GST_MAP_WRITE);
ret = fread (map.data, 1, data->frame_size, data->file);
map.size = ret;
gst_buffer_unmap (buffer, &map);
if (ret > 0) {
#if CUSTOM_PTS
GST_BUFFER_PTS (buffer) =
gst_util_uint64_scale (data->appsrc_frame_num, GST_SECOND, data->fps);
#endif
gstret = gst_app_src_push_buffer ((GstAppSrc *) data->app_source, buffer);
if (gstret != GST_FLOW_OK) {
g_print (“gst_app_src_push_buffer returned %d \n”, gstret);
return FALSE;
} else if (ret == 0) {
gstret = gst_app_src_end_of_stream ((GstAppSrc *) data->app_source);
g_print
(“gst_app_src_end_of_stream returned %d. EoS not queued successfully.\n”,
gstret);
return FALSE;
} else {
g_print (“\n failed to read from file\n”);
return FALSE;
data->appsrc_frame_num++;
return TRUE;
/* This signal callback triggers when appsrc needs data. Here,
- we add an idle handler to the mainloop to start pushing
- data into the appsrc */
static void
start_feed (GstElement * source, guint size, AppSrcData * data)
if (data->sourceid == 0) {
data->sourceid = g_idle_add ((GSourceFunc) read_data, data);
/* This callback triggers when appsrc has enough data and we can stop sending.
- We remove the idle handler from the mainloop */
static void
stop_feed (GstElement * source, AppSrcData * data)
if (data->sourceid != 0) {
g_source_remove (data->sourceid);
data->sourceid = 0;
int
main (int argc, char *argv)
GMainLoop *loop = NULL;
GstElement *pipeline = NULL, *nvvidconv1 = NULL, *caps_filter = NULL,
*streammux = NULL, *sink = NULL, *pgie = NULL, *nvvidconv2 = NULL,
*nvosd = NULL, *tee = NULL, *appsink = NULL;
GstElement *transform = NULL;
GstBus *bus = NULL;
guint bus_watch_id;
AppSrcData data;
GstCaps *caps = NULL;
GstCapsFeatures *feature = NULL;
gchar *endptr1 = NULL, *endptr2 = NULL, *endptr3 = NULL, *vidconv_format =
NULL;
GstPad *tee_source_pad1, *tee_source_pad2;
GstPad *osd_sink_pad, *appsink_sink_pad;
int current_device = -1;
cudaGetDevice(¤t_device);
struct cudaDeviceProp prop;
cudaGetDeviceProperties(&prop, current_device);
/* Check input arguments */
if (argc != 6) {
g_printerr
(“Usage: %s <format(I420, NV12, RGBA)>\n”,
argv[0]);
return -1;
long width = g_ascii_strtoll (argv[2], &endptr1, 10);
long height = g_ascii_strtoll (argv[3], &endptr2, 10);
long fps = g_ascii_strtoll (argv[4], &endptr3, 10);
gchar *format = argv[5];
if ((width == 0 && endptr1 == argv[2]) || (height == 0 && endptr2 == argv[3])
|| (fps == 0 && endptr3 == argv[4])) {
g_printerr (“Incorrect width, height or FPS\n”);
return -1;
if (width == 0 || height == 0 || fps == 0) {
g_printerr (“Width, height or FPS cannot be 0\n”);
return -1;
if (g_strcmp0 (format, “I420”) != 0 && g_strcmp0 (format, “RGBA”) != 0
&& g_strcmp0 (format, “NV12”) != 0) {
g_printerr (“Only I420, RGBA and NV12 are supported\n”);
return -1;
/* Initialize custom data structure */
memset (&data, 0, sizeof (data));
if (!g_strcmp0 (format, “RGBA”)) {
data.frame_size = width * height * 4;
vidconv_format = “RGBA”;
} else {
data.frame_size = width * height * 1.5;
vidconv_format = “NV12”;
data.file = fopen (argv[1], “r”);
data.fps = fps;
/* Standard GStreamer initialization */
gst_init (&argc, &argv);
loop = g_main_loop_new (NULL, FALSE);
/* Create gstreamer elements /
/ Create Pipeline element that will form a connection of other elements */
pipeline = gst_pipeline_new (“dstest-appsrc-pipeline”);
if (!pipeline) {
g_printerr (“Pipeline could not be created. Exiting.\n”);
return -1;
/* App Source element for reading from raw video file */
data.app_source = gst_element_factory_make (“appsrc”, “app-source”);
if (!data.app_source) {
g_printerr (“Appsrc element could not be created. Exiting.\n”);
return -1;
/* Use convertor to convert from software buffer to GPU buffer */
nvvidconv1 =
gst_element_factory_make (“nvvideoconvert”, “nvvideo-converter1”);
if (!nvvidconv1) {
g_printerr (“nvvideoconvert1 could not be created. Exiting.\n”);
return -1;
caps_filter = gst_element_factory_make (“capsfilter”, “capsfilter”);
if (!caps_filter) {
g_printerr (“Caps_filter could not be created. Exiting.\n”);
return -1;
/* Create nvstreammux instance to form batches from one or more sources. */
streammux = gst_element_factory_make (“nvstreammux”, “stream-muxer”);
if (!streammux) {
g_printerr (“nvstreammux could not be created. Exiting.\n”);
return -1;
/* Use nvinfer to run inferencing on streammux’s output,
- behaviour of inferencing is set through config file */
pgie = gst_element_factory_make (“nvinfer”, “primary-nvinference-engine”);
if (!pgie) {
g_printerr (“Primary nvinfer could not be created. Exiting.\n”);
return -1;
/* Use convertor to convert from NV12 to RGBA as required by nvdsosd */
nvvidconv2 =
gst_element_factory_make (“nvvideoconvert”, “nvvideo-converter2”);
if (!nvvidconv2) {
g_printerr (“nvvideoconvert2 could not be created. Exiting.\n”);
return -1;
/* Create OSD to draw on the converted RGBA buffer */
nvosd = gst_element_factory_make (“nvdsosd”, “nv-onscreendisplay”);
if (!nvosd) {
g_printerr (“nvdsosd could not be created. Exiting.\n”);
return -1;
/* Finally render the osd output. We will use a tee to render video
- playback on nveglglessink, and we use appsink to extract metadata
- from buffer and print object, person and vehicle count. */
tee = gst_element_factory_make (“tee”, “tee”);
if (!tee) {
g_printerr (“Tee could not be created. Exiting.\n”);
return -1;
if(prop.integrated) {
transform = gst_element_factory_make (“nvegltransform”, “nvegl-transform”);
if (!transform) {
g_printerr (“Tegra transform element could not be created. Exiting.\n”);
return -1;
sink = gst_element_factory_make (“nveglglessink”, “nvvideo-renderer”);
if (!sink) {
g_printerr (“Display sink could not be created. Exiting.\n”);
return -1;
appsink = gst_element_factory_make (“appsink”, “app-sink”);
if (!appsink) {
g_printerr (“Appsink element could not be created. Exiting.\n”);
return -1;
/* Configure appsrc */
g_object_set (data.app_source, “caps”,
gst_caps_new_simple (“video/x-raw”,
“format”, G_TYPE_STRING, format,
“width”, G_TYPE_INT, width,
“height”, G_TYPE_INT, height,
“framerate”, GST_TYPE_FRACTION, data.fps, 1, NULL), NULL);
#if !CUSTOM_PTS
g_object_set (G_OBJECT (data.app_source), “do-timestamp”, TRUE, NULL);
#endif
g_signal_connect (data.app_source, “need-data”, G_CALLBACK (start_feed),
&data);
g_signal_connect (data.app_source, “enough-data”, G_CALLBACK (stop_feed),
&data);
#ifndef PLATFORM_TEGRA
g_object_set (G_OBJECT (nvvidconv1), “nvbuf-memory-type”, 3, NULL);
#endif
caps =
gst_caps_new_simple (“video/x-raw”, “format”, G_TYPE_STRING,
vidconv_format, NULL);
feature = gst_caps_features_new (“memory:NVMM”, NULL);
gst_caps_set_features (caps, 0, feature);
g_object_set (G_OBJECT (caps_filter), “caps”, caps, NULL);
/* Set streammux properties */
g_object_set (G_OBJECT (streammux), “width”, width, “height”,
height, “batch-size”, 1, “live-source”, TRUE,
“batched-push-timeout”, MUXER_BATCH_TIMEOUT_USEC, NULL);
/* Set all the necessary properties of the nvinfer element,
- the necessary ones are : */
g_object_set (G_OBJECT (pgie),
“config-file-path”, “dstestsr_pgie_config.txt”, NULL);
/* we add a message handler */
bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
gst_object_unref (bus);
/* Set up the pipeline /
/ we add all elements into the pipeline */
gst_bin_add_many (GST_BIN (pipeline),
data.app_source, nvvidconv1, caps_filter, streammux, pgie,
nvvidconv2, nvosd, tee, sink, appsink, NULL);
gst_bin_add (GST_BIN (pipeline), transform);
GstPad *sinkpad, *srcpad;
gchar pad_name_sink[16] = “sink_0”;
gchar pad_name_src[16] = “src”;
sinkpad = gst_element_get_request_pad (streammux, pad_name_sink);
if (!sinkpad) {
g_printerr (“Streammux request sink pad failed. Exiting.\n”);
return -1;
srcpad = gst_element_get_static_pad (caps_filter, pad_name_src);
if (!srcpad) {
g_printerr (“Decoder request src pad failed. Exiting.\n”);
return -1;
if (gst_pad_link (srcpad, sinkpad) != GST_PAD_LINK_OK) {
g_printerr (“Failed to link caps filter to stream muxer. Exiting.\n”);
return -1;
gst_object_unref (sinkpad);
gst_object_unref (srcpad);
/* we link the elements together /
/ app-source → nvvidconv → caps filter →
- nvinfer → nvvidconv → nvosd → video-renderer */
if (!gst_element_link_many (data.app_source, nvvidconv1, caps_filter, NULL) ||
!gst_element_link_many (nvosd, transform, sink, NULL) ||
!gst_element_link_many (streammux, pgie, nvvidconv2, tee, NULL)) {
g_printerr (“Elements could not be linked: Exiting.\n”);
return -1;
else {
!gst_element_link_many (nvosd, sink, NULL) ||
return -1;
/* Manually link the Tee, which has “Request” pads.
- This tee, in case of multistream usecase, will come before tiler element. */
tee_source_pad1 = gst_element_get_request_pad (tee, “src_0”);
osd_sink_pad = gst_element_get_static_pad (nvosd, “sink”);
tee_source_pad2 = gst_element_get_request_pad (tee, “src_1”);
appsink_sink_pad = gst_element_get_static_pad (appsink, “sink”);
if (gst_pad_link (tee_source_pad1, osd_sink_pad) != GST_PAD_LINK_OK) {
g_printerr (“Tee could not be linked to display sink.\n”);
gst_object_unref (pipeline);
return -1;
if (gst_pad_link (tee_source_pad2, appsink_sink_pad) != GST_PAD_LINK_OK) {
g_printerr (“Tee could not be linked to appsink.\n”);
return -1;
gst_object_unref (osd_sink_pad);
gst_object_unref (appsink_sink_pad);
/* Configure appsink to extract data from DeepStream pipeline */
g_object_set (appsink, “emit-signals”, TRUE, “async”, FALSE, NULL);
g_object_set (sink, “sync”, FALSE, NULL);
/* Callback to access buffer and object info. */
g_signal_connect (appsink, “new-sample”, G_CALLBACK (new_sample), NULL);
/* Set the pipeline to “playing” state */
g_print (“Now playing: %s\n”, argv[1]);
gst_element_set_state (pipeline, GST_STATE_PLAYING);
/* Wait till pipeline encounters an error or EOS */
g_print (“Running…\n”);
g_main_loop_run (loop);
/* Out of the main loop, clean up nicely */
g_print (“Returned, stopping playback\n”);
gst_element_set_state (pipeline, GST_STATE_NULL);
g_print (“Deleting pipeline\n”);
gst_object_unref (GST_OBJECT (pipeline));
g_source_remove (bus_watch_id);
g_main_loop_unref (loop);
return 0;
it does not print where i have mentioned configuration file in this code and i am using resnet10caffeemodel
did you resolve this issue?
what do you want to print? how did you add the log? please highlight it.
“Vehicle Count = %d Person Count = %d PTS = %” GST_TIME_FORMAT “\n”,
this one is not printing in terminal
jetson@ubuntu:~/Documents/deepstream-appsrc-test$ ./deepstream-appsrc-test “rtsp://admin:Sieora123@192.168.1.108:554/cam/realmonitor?channel=3&subtype=0” 1920 1080 30 NV12
Now playing: rtsp://admin:Sieora123@192.168.1.108:554/cam/realmonitor?channel=3&subtype=0
Using winsys: x11
0:00:09.788276762 11884 0x55b74b9f50 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/home/jetson/Documents/deepstream-appsrc-test/resnet10.caffemodel_b1_gpu0_fp16.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:09.789947682 11884 0x55b74b9f50 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 1]: Use deserialized engine model: /home/jetson/Documents/deepstream-appsrc-test/resnet10.caffemodel_b1_gpu0_fp16.engine
0:00:09.827037414 11884 0x55b74b9f50 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 1]: Load new model:dstest_appsrc_config.txt sucessfully
Running…
this is my configuration file
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-file= resnet10.caffemodel
proto-file= resnet10.prototxt
model-engine-file = resnet10.caffemodel_b1_gpu0_fp16.engine
labelfile-path = labels.txt
int8-calib-file = cal_trt.bin
force-implicit-batch-dim=1
batch-size=1
network-mode=1
num-detected-classes=4
interval=0
gie-unique-id=1
output-blob-names=conv2d_bbox;conv2d_cov/Sigmoid
#scaling-filter=0
#scaling-compute-hw=0
cluster-mode=2
[class-attrs-all]
pre-cluster-threshold=0.2
topk=20
nms-iou-threshold=0.5
let’s focus on the original issue, if you meet a new issue, please open a new topic, Thanks!
