Dears,
I try to deeply onnx(Resnet50) model in deep stream
but I have error
‘This version of the ONNX parser only supports TensorRT INetworkDefinitions with an explicit batch dimension. Please ensure the network was created using the EXPLICIT_BATCH NetworkDefinitionCreationFlag’ ,
Note: I have Deep Dtream 5 , TensorRT-7.1.3.4
For more details about the error :
With tracker
(gst-plugin-scanner:7009): GStreamer-WARNING **: 08:33:08.082: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libtrtserver.so: cannot open shared object file: No such file or directory
Error: Could not parse custom library path
Failed to parse group property
** ERROR: <gst_nvinfer_parse_config_file:1158>: failed
Now playing: /home/Desktop/sample_720p.h264
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:1408 Deserialize engine failed because file path: /home/Desktop/deep_stream app/deepstream-AI-Engin/sbv.onnx_b1_fp32.engine open error
0:00:00.543875102 7008 0x5582e3516240 WARN nvinfer gstnvinfer.cpp:599:gst_nvinfer_logger: NvDsInferContext[UID 2]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1566> [UID = 2]: deserialize engine from file :/home/Desktop/deep_stream app/deepstream-AI-Engin/sbv.onnx_b1_fp32.engine failed
0:00:00.543898856 7008 0x5582e3516240 WARN nvinfer gstnvinfer.cpp:599:gst_nvinfer_logger: NvDsInferContext[UID 2]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1673> [UID = 2]: deserialize backend context from engine from file :/home/Desktop/deep_stream app/deepstream-AI-Engin/sbv.onnx_b1_fp32.engine failed, try rebuild
0:00:00.543905713 7008 0x5582e3516240 INFO nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger: NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1591> [UID = 2]: Trying to create engine from model files
Input filename: /home/Desktop/deep_stream app/deepstream-AI-Engin/sbv_1.onnx
ONNX IR version: 0.0.7
Opset version: 12
Producer name: keras2onnx
Producer version: 1.7.0
Domain: onnxmltools
Model version: 0
Doc string:
ERROR: ModelImporter.cpp:472 In function importModel:
[4] Assertion failed: !_importer_ctx.network()->hasImplicitBatchDimension() && “This version of the ONNX parser only supports TensorRT INetworkDefinitions with an explicit batch dimension. Please ensure the network was created using the EXPLICIT_BATCH NetworkDefinitionCreationFlag.”
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:390 Failed to parse onnx file
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:971 failed to build network since parsing model errors.
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:872 failed to build network.
0:00:00.656811664 7008 0x5582e3516240 ERROR nvinfer gstnvinfer.cpp:596:gst_nvinfer_logger: NvDsInferContext[UID 2]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1611> [UID = 2]: build engine file failed
0:00:00.656830383 7008 0x5582e3516240 ERROR nvinfer gstnvinfer.cpp:596:gst_nvinfer_logger: NvDsInferContext[UID 2]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1697> [UID = 2]: build backend context failed
0:00:00.656835562 7008 0x5582e3516240 ERROR nvinfer gstnvinfer.cpp:596:gst_nvinfer_logger: NvDsInferContext[UID 2]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1024> [UID = 2]: generate backend failed, check config file settings
0:00:00.656860811 7008 0x5582e3516240 WARN nvinfer gstnvinfer.cpp:781:gst_nvinfer_start: error: Failed to create NvDsInferContext instance
0:00:00.656864017 7008 0x5582e3516240 WARN nvinfer gstnvinfer.cpp:781:gst_nvinfer_start: error: Config file path: sbv_sgie1_config.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
Running…
ERROR from element secondary1-nvinference-engine: Failed to create NvDsInferContext instance
Error details: gstnvinfer.cpp(781): gst_nvinfer_start (): /GstPipeline:dstest2-pipeline/GstNvInfer:secondary1-nvinference-engine:
Returned, stopping playback
Deleting pipeline
