**• Hardware Platform (Jetson / GPU):jetson
**• DeepStream Version: 5.0
**• JetPack Version (valid for Jetson only): 4.4
**• TensorRT Version:7.1.3.0
Deepsort is a very popular object track algorithm.
I want to use it in Deepstream.
It seem that I need to custom my nvdsinferinitializeinputlayers and bbox functions.
I have found a tensorrt repos about deepsort in GitHub - kunyao2015/TensorRT_Yolo
What can I do in Deepstream?
I need some help.
bcao
September 5, 2020, 3:45am
3
You can deploy the model to DS if it can run well using TensorRT.
@bcao Thanks for you reply.
I know about this.
But DeepSort is seem like a tracker algorithm. So I am trying to custom a tracker plugin.
After reading some preview posts. I try to test it. Now, I can get output bbox correctly. I output the detected bbox directly. But no bbox output in the video.
Here is my test code.
#include <math.h>
#include <stdio.h>
#include "nvdstracker.h"
#include <iostream>
#include <glib.h>
#include "nvbufsurface.h"
#include "nvbufsurftransform.h"
#include "gstnvdsmeta.h"
#include "gstnvdsinfer.h"
#include <cstddef>
#include <vector>
#define TRACKER_AGE_INFRAME 120
* The plugin uses this function to query the low-level library’s capabilities and requirements
* before it starts any processing sessions (contexts) with the library.
NvMOTStatus NvMOT_Query(uint16_t customConfigFilePathSize, char *pCustomConfigFilePath, NvMOTQuery *pQuery)
std::cout << "Exec NvMOT_Query ..." << std::endl;
pQuery->memType = NVBUF_MEM_DEFAULT;
pQuery->colorFormats[0] = NVBUF_COLOR_FORMAT_RGBA;
pQuery->colorFormats[1] = NVBUF_COLOR_FORMAT_RGBA;
pQuery->colorFormats[2] = NVBUF_COLOR_FORMAT_RGBA;
pQuery->colorFormats[3] = NVBUF_COLOR_FORMAT_RGBA;
return NvMOTStatus_OK;
* After the query, and before any frames arrive, the plugin must initialize a context with the low-level library
NvMOTStatus NvMOT_Init(NvMOTConfig *pConfigIn, NvMOTContextHandle *pContextHandle, NvMOTConfigResponse *pConfigResponse)
std::cout << "Exec NvMOT_Init ..." << std::endl;
pConfigResponse->summaryStatus = NvMOTConfigStatus_OK;
pConfigResponse->computeStatus = NvMOTConfigStatus_OK;
pConfigResponse->transformBatchStatus = NvMOTConfigStatus_OK;
pConfigResponse->miscConfigStatus = NvMOTConfigStatus_OK;
pConfigResponse->customConfigStatus = NvMOTConfigStatus_OK;
NvMOTContextHandle *ctx = (NvMOTContextHandle *)pConfigIn;
*pContextHandle = *ctx;
NvMOTStatus NvMOT_Process(NvMOTContextHandle contextHandle, NvMOTProcessParams *pParams, NvMOTTrackedObjBatch *pTrackedObjectsBatch)
std::cout << "Exec NvMOT_Process ..." << std::endl;
NvMOTFrame *fr = pParams->frameList;
NvMOTObjToTrackList det_obj = fr->objectsIn;
NvMOTObjToTrack *obj_to_trk = det_obj.list;
// std::cout << "pParams->numFrames : " << pParams->numFrames <<std::endl;
std::cout << "Current Frame Num : " << fr->frameNum <<std::endl;
// std::cout << "Current timeStamp : " << fr->timeStamp <<std::endl;
//std::cout << "Current StreamID : " << fr->streamID << " is allowed to trackering ? " << (fr->doTracking ? "True" : "False") <<std::endl;
std::cout << "Current Frame Decect Objs Num is : " << det_obj.numFilled << std::endl;
std::vector<NvMOTTrackedObj> *out_trk = new std::vector<NvMOTTrackedObj>;
std::vector<NvMOTTrackedObjList> *out_trk_list = new std::vector<NvMOTTrackedObjList>;
//NvMOTTrackedObj (*out_trk)[det_obj.numFilled];
//NvMOTTrackedObjList (*out_trk_list) [pTrackedObjectsBatch->numAllocated];
for (uint32_t i = 0; i < det_obj.numFilled; i++)
if((obj_to_trk+i)->confidence < 0.9) continue;
std::cout << (obj_to_trk+i)->confidence << ":"
<< static_cast<unsigned int>((obj_to_trk+i)->bbox.x) << ":"
<< static_cast<unsigned int>((obj_to_trk+i)->bbox.y) << ":"
<< static_cast<unsigned int>((obj_to_trk+i)->bbox.width) << ":"
<< static_cast<unsigned int>((obj_to_trk+i)->bbox.height) << std::endl;
NvMOTTrackedObj *OutObject = new NvMOTTrackedObj;
OutObject->bbox.x = static_cast<unsigned int>((obj_to_trk+i)->bbox.x);
OutObject->bbox.y = static_cast<unsigned int>((obj_to_trk+i)->bbox.y);
OutObject->bbox.width = static_cast<unsigned int>((obj_to_trk+i)->bbox.width);
OutObject->bbox.height = static_cast<unsigned int>((obj_to_trk+i)->bbox.height);
OutObject->trackingId = i+1;
OutObject->confidence = (obj_to_trk+i)->confidence;
OutObject->classId = (obj_to_trk+i)->classId;
OutObject->age = TRACKER_AGE_INFRAME;
OutObject->associatedObjectIn = static_cast<NvMOTObjToTrack*>(obj_to_trk+i);
//*out_trk[i] = *OutObject;
out_trk->push_back(*OutObject);
for (uint32_t i = 0; i < pTrackedObjectsBatch->numAllocated; i++)
std::cout << "Num filled is : " << out_trk->size() << std::endl;
NvMOTTrackedObjList *OutObject_list = new NvMOTTrackedObjList;
OutObject_list->streamID = fr->streamID;
OutObject_list->frameNum = fr->frameNum;
OutObject_list->valid = true;
OutObject_list->list = out_trk->data();
OutObject_list->numFilled = out_trk->size();
OutObject_list->numAllocated = out_trk->size();
//*out_trk_list[i] = *OutObject_list;
out_trk_list->push_back(*OutObject_list);
//pTrackedObjectsBatch->numFilled = 1;
//pTrackedObjectsBatch->numAllocated = 8;
//pTrackedObjectsBatch->list = static_cast<NvMOTTrackedObjList*>(out_trk_list.data());
pTrackedObjectsBatch->list = out_trk_list->data();
//pTrackedObjectsBatch->list = *out_trk_list;
void NvMOT_DeInit(NvMOTContextHandle contextHandle)
std::cout << "Exec NvMOT_DeInit ..." << std::endl;
I have set KITTI output of tracker in config file. But all frame are empty.
When I use NVDCF, the outputs are correct.
So I suppose pTrackedObjectsBatch->list is constructed by mistake.
Any help?
After some research. I find the problems.
The key note is we should use memcpy to set pTrackedObjectsBatch->list.
Next I will try to test deepsort.
Hello.I’m a new in TensorRT field.could you help me to solve some problems?
(1) How to generate a deepsort.engine file?
(2) could you share your work about inferencing with TensorRT c++ api?
kayccc
November 9, 2020, 6:51am
9
Hi yangjinyi_gis,
Please help to open a new topic for your issue. Thanks
Hello @illusioncn , I am also trying to run YOLO and DeepSort. I have YOLO working just fine, but I have not found reference for DeepSort plugins in DeepStream. Did you manage to get it working? If so, would you mind sharing how you accomplished it?
