I installed JetPack 4.4 on Nano and ran some Deepstream 5.0 samples successfully natively (outside Docker). Then I built a docker image from nvcr.io/nvidia/deepstream-l4t:5.0-dp-20.04-samples, tried to run test1 inside the container, it failed.
I also tried ssh to Nano, then no matter where I ran the test1 sample, it didn’t work.
I confirmed the X11 forwarding is working properly, running xclock natively via ssh and inside docker showed the graphic clock successfully.
Did I miss anything to make the sample support X11 forwarding or work inside docker?
root@nano-desktop:~/ds-dp-5.0/deepstream_python_v0.9.orig/python/apps/deepstream-test1# ./deepstream_test_1.py ../sample_720p.h264
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
libEGL warning: MESA-LOADER: failed to open swrast (search paths /usr/lib/aarch64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri)
nvbuf_utils: Could not get EGL display connection
Unable to create NvStreamMux
Unable to create pgie
Unable to create nvvidconv
Unable to create nvosd
Creating EGLSink
Playing file ../sample_720p.h264
File "./deepstream_test_1.py", line 266, in <module>
sys.exit(main(sys.argv))
File "./deepstream_test_1.py", line 199, in main
streammux.set_property('width', 1920)
AttributeError: 'NoneType' object has no attribute 'set_property'
glxinfo result is shown below.
glxinfo
name of display: localhost:1.0
MESA-LOADER: failed to open swrast (search paths /usr/lib/aarch64-linux-gnu/dri:\${ORIGIN}/dri:/usr/lib/dri)
libGL error: failed to load driver: swrast
X Error of failed request: GLXBadContext
Major opcode of failed request: 149 (GLX)
Minor opcode of failed request: 6 (X_GLXIsDirect)
Serial number of failed request: 25
Current serial number in output stream: 24
Something was blinking once, then disappeared. Below are the messages.
root@nano-desktop:/tmp/samples/5_Simulations/nbody# ./nbody
Run "nbody -benchmark [-numbodies=<numBodies>]" to measure performance.
-fullscreen (run n-body simulation in fullscreen mode)
-fp64 (use double precision floating point values for simulation)
-hostmem (stores simulation data in host memory)
-benchmark (run benchmark to measure performance)
-numbodies=<N> (number of bodies (>= 1) to run in simulation)
-device=<d> (where d=0,1,2.... for the CUDA device to use)
-numdevices=<i> (where i=(number of CUDA devices > 0) to use for simulation)
-compare (compares simulation results running once on the default GPU and once on the CPU)
-cpu (run n-body simulation on the CPU)
-tipsy=<file.bin> (load a tipsy model file for simulation)
NOTE: The CUDA Samples are not meant for performance measurements. Results may vary when GPU Boost is enabled.
debug1: client_input_channel_open: ctype x11 rchan 10 win 65536 max 16384
debug1: client_request_x11: request from 127.0.0.1 53134
debug1: x11_connect_display: $DISPLAY is launchd
debug1: channel 7: new [x11]
debug1: confirm x11
> Windowed mode
> Simulation data stored in video memory
> Single precision floating point simulation
> 1 Devices used for simulation
libGL error: unable to load driver: swrast_dri.so
Required OpenGL extensions missing.debug1: channel 7: FORCE input drain
debug1: channel 7: free: x11, nchannels 8
I think since the L4T docker is officially released, the Deepstream applications are supposed to be running inside docker via a ssh session, not only insider docker via local session, right?
Anyone has any clue why the DS applications didn’t work insider docker via ssh session?
