I try to update libgst*, but it is already newest.
And “root@e6ca3336189f:/# rm -r ~/.cache/gstreamer-1.0/registry.x86_64.bin” is no use ethier.
Please give me some advice, thx.
Did you install Nvidia-docker2 according to the guide ?
Please also share the command to start docker, and provide complete information as applicable to your setup.
• DeepStream Version
• TensorRT Version
• The pipeline being used
Thx for your reply.
No, I didn’t see the guide to install Nvidia-docker2, where is it?
GPU 1660
I just download the docker image nvcr.io/nvidia/deepstream:6.0.1-devel, and run the container by
xhost +
sudo docker run --gpus all -it -p 127.0.0.1:6666:6666 -p 6879:22 --shm-size=5g -v /tmp/.X11-unix:/tmp/.X11-unix -e GDK_SCALE -e GDK_DPI_SCALE -e DISPLAY=:1 nvcr.io/nvidia/deepstream:6.0.1-devel
And then what I did is just to build deepstream-test1-app and run ./deepstream-test1-app /opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.h264, it occurred error “One element could not be creter. exit”.
Then I try to run this:
root@e6ca3336189f:/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app# deepstream-app -c source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
** ERROR: <create_multi_source_bin:1424>: Failed to create element ‘src_bin_muxer’
** ERROR: <create_multi_source_bin:1517>: create_multi_source_bin failed
** ERROR: <create_pipeline:1326>: create_pipeline failed
** ERROR: main:688: Failed to create pipeline
Quitting
App run failed
I think the reason is the same, build is always ok but run failed.
I haven’t installed jetpack, shall I install it?
The referred environment is below:
root@e6ca3336189f:/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app# deepstream-app --version-all
deepstream-app version 6.0.1
DeepStreamSDK 6.0.1
CUDA Driver Version: 11.4
CUDA Runtime Version: 0.0
TensorRT Version: 8.0
cuDNN Version: 8.2
Dewarper: not found
Sorry, I think my former colleagues have installed nvidia-docker.
zyg@zyg-ubuntu:~/Desktop$ nvidia-docker --version
Docker version 20.10.5, build 55c4c88 DGPU 1660, “nvidia-smi” can work in my docker env. In docker environment, the result of “nvidia-smi”
root@e6ca3336189f:/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app# nvidia-smi
Sat Jan 7 05:28:44 2023
| NVIDIA-SMI 450.80.02 Driver Version: 450.80.02 CUDA Version: 11.4 |
| | | MIG M. |
| 0 GeForce GTX 1660 Off | 00000000:01:00.0 On | N/A |
| 47% 24C P8 1W / 130W | 292MiB / 5943MiB | 11% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| But in host, the CUDA version is lower than docker.
zyg@zyg-ubuntu:~/Desktop$ nvidia-smi
Sat Jan 7 13:23:53 2023
| NVIDIA-SMI 450.80.02 Driver Version: 450.80.02 CUDA Version: 11.0 |
| | | MIG M. |
| 46% 24C P8 1W / 130W | 295MiB / 5943MiB | 11% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 973 G /usr/lib/xorg/Xorg 160MiB |
| 0 N/A N/A 1178 G /usr/bin/gnome-shell 132MiB |
I try it, the log is below:
root@e6ca3336189f:/opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream-test1# GST_DEBUG=3 ./deepstream-test1-app /opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_720p.h264
0:00:00.011588327 820 0x564e9dc23a10 WARN GST_ELEMENT_FACTORY gstelementfactory.c:456:gst_element_factory_make: no such element factory “nvstreammux”!
One element could not be created. Exiting.
Just from the log info, gstelementfactory.c:456:gst_element_factory_make: no such element factory “nvstreammux”!. There maybe something wrong with your env. So you may need to check it by yourself. You can refer to the link below to install the dependencies of the corresponding version. https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_Quickstart.html?highlight=compatibility#platform-and-os-compatibility
Also we sugget you install the cuda version that needed in your host. The cuda in the Docker will depend on it on the host side.
Hello, I update the host driver to 525 and Cuda version to 11.8, now the test can run well.
And the command of running container has a problem: sudo docker run --gpus all -it -p 127.0.0.1:6666:6666 -p 6879:22 --shm-size=5g -v /tmp/.X11-unix:/tmp/.X11-unix -e GDK_SCALE -e GDK_DPI_SCALE -e DISPLAY=:1 [nvcr.io/nvidia/deepstream:6.0.1-devel]
, DISPLAY should be :0 or it will cause error.
Please tell me where I can find the standard command to run nvidia container. I didn’t see it in this site Docker Containers — DeepStream 6.1.1 Release documentation (nvidia.com).
By the way, I don’t install cuDNN and TRT in the host environment, does it have any effect on docker container?
