DeepStream 6.0 Composer not working from Docker
• Hardware Platform (Jetson / GPU) GPU : NVIDIA GeForce RTX 3050 Ti
• DeepStream Version 6.0
• TensorRT Version 8.0.1
• NVIDIA GPU Driver Version (valid for GPU only) NVIDIA-Linux-x86_64-470.94 (copy).run
• Issue Type( questions, new requirements, bugs) bugs
I installed linux Ubuntu 20.4 and installed the NVIDIA driver,
I got the Deepstream 6 docker for development, the sample applications are working fine but i cannot run the composer from it with the following command:
degwey@degwey-laptop:~$ sudo docker exec -it 951e2d3bb145 bash
root@degwey-laptop:/opt/nvidia/deepstream/deepstream-6.0# composer
./kit/kit ./composer/composer-standalone.kit --ext-path ./composer/omni.exp.graph.composer/ --/plugins/carb.scripting-python.plugin/pythonPath=./registry/ --allow-root
[Info] [carb] Logging to file: /root/.nvidia-omniverse/logs/Kit/composer-standalone/1.0/kit_20220104_143505.log
[0.068s] [ext: omni.kit.pipapi-0.0.0] startup
[0.072s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.076s] [ext: omni.usd.config-1.0.0] startup
[0.077s] [ext: omni.usd.libs-1.0.0] startup
root@degwey-laptop:/opt/nvidia/deepstream/deepstream-6.0# [0.213s] [ext: omni.stats-0.0.0] startup
[0.215s] [ext: omni.gpu_foundation-0.0.0] startup
2022-01-04 14:35:05 [203ms] [Warning] [omni.ext.plugin] [ext: omni.gpu_foundation-0.0.0] Failed to load plugins, folder doesn’t exist: ‘/tmp/.tmpNvXgRaphComposer/run/kit/plugins/rtx’.
2022-01-04 14:35:05 [203ms] [Warning] [omni.ext.plugin] [ext: omni.gpu_foundation-0.0.0] ‘/tmp/.tmpNvXgRaphComposer/run/kit/plugins/rtx/rtx.xrtools.plugin’ in ‘[[native.plugin]]’ was not found.
[0.219s] [ext: omni.kit.async_engine-0.0.0] startup
[0.225s] [ext: omni.kit.loop-default-0.1.0] startup
[0.226s] [ext: omni.assets.plugins-0.0.0] startup
[0.227s] [ext: omni.appwindow-1.0.0] startup
[0.237s] [ext: omni.client-0.1.0] startup
[0.244s] [ext: omni.kit.renderer.core-0.0.0] startup
2022-01-04 14:35:05 [233ms] [Warning] [omni.ext.plugin] [ext: omni.kit.renderer.core-0.0.0] Failed to load plugins, folder doesn’t exist: ‘/tmp/.tmpNvXgRaphComposer/run/kit/plugins/rtx’.
2022-01-04 14:35:05 [233ms] [Warning] [omni.ext.plugin] [ext: omni.kit.renderer.core-0.0.0] ‘/tmp/.tmpNvXgRaphComposer/run/kit/plugins/rtx/rtx.xrtools.plugin’ in ‘[[native.plugin]]’ was not found.
| Driver Version: 470.86 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | NVIDIA GeForce RTX 3050 Ti Lap… | Yes: 0 | | 4096 MB | 10de | 0 |
| | | | | | 25a0 | 13dfd3a4… |
| OS: Linux degwey-laptop, Version: 5.11.0-43-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12013000 (1.20.13.0)
| Processor: 11th Gen Intel(R) Core™ i5-11400H @ 2.70GHz | Cores: Unknown | Logical: 12
| Total Memory (MB): 15644 | Free Memory: 1794
| Total Page/Swap (MB): 2047 | Free Page/Swap: 2047
2022-01-04 14:35:05 [433ms] [Warning] [carb.cudainterop.plugin] NVML could not be loaded. GPU Utilization stats will be unavailable. Error: libnvidia-ml.so: cannot open shared object file: No such file or directory
2022-01-04 14:35:06 [623ms] [Error] [carb.graphics-vulkan.plugin] Failed to find device surface formats.
2022-01-04 14:35:06 [623ms] [Error] [omni.kit.renderer.plugin] createSwapchain failed. Width: 1440, height: 900, Format: 9
2022-01-04 14:35:06 [623ms] [Error] [omni.kit.renderer.plugin] Failed to initialize graphics environment.
2022-01-04 14:35:06 [724ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.events.plugin.so!carbOnPluginStartup
2022-01-04 14:35:06 [724ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.tasking.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<void (carb::tasking::Scheduler::)(unsigned int, int, carb::cpp20::latch), carb::tasking::Scheduler*, unsigned int, int, carb::cpp20::latch*> > >::_M_run()
2022-01-04 14:35:06 [725ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpthread.so.0!funlockfile
2022-01-04 14:35:06 [726ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.imgui_renderer.plugin.so!void std::vector<unsigned long, std::allocator >::_M_realloc_insert<unsigned long const&>(__gnu_cxx::__normal_iterator<unsigned long*, std::vector<unsigned long, std::allocator > >, unsigned long const&)
2022-01-04 14:35:06 [726ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.imgui_renderer.plugin.so!carbOnPluginPostShutdown
2022-01-04 14:35:06 [726ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.ext.plugin.so!carbOnPluginPostShutdown
2022-01-04 14:35:06 [727ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<std::string, std::allocatorstd::string >::_M_realloc_insertstd::string&(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocatorstd::string > >, std::string&)
2022-01-04 14:35:06 [728ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!carbOnPluginShutdown
2022-01-04 14:35:06 [729ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!char* std::string::_S_construct<char*>(char*, char*, std::allocator const&, std::forward_iterator_tag)
2022-01-04 14:35:06 [730ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Rb_tree<std::string, std::string, std::_Identitystd::string, std::lessstd::string, std::allocatorstd::string >::_M_erase(std::_Rb_tree_nodestd::string)
2022-01-04 14:35:06 [731ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Rb_tree<std::string, std::string, std::_Identitystd::string, std::lessstd::string, std::allocatorstd::string >::_M_erase(std::_Rb_tree_nodestd::string
2022-01-04 14:35:06 [731ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Rb_tree<std::string, std::string, std::_Identitystd::string, std::lessstd::string, std::allocatorstd::string >::_M_erase(std::_Rb_tree_nodestd::string)
2022-01-04 14:35:06 [732ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Hashtable<std::string, std::string, std::allocatorstd::string, std::__detail::_Identity, std::equal_tostd::string, std::hashstd::string, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, true, true> >::operator=(std::_Hashtable<std::string, std::string, std::allocatorstd::string, std::__detail::_Identity, std::equal_tostd::string, std::hashstd::string, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, true, true> > const&)
2022-01-04 14:35:06 [733ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!std::string __gnu_cxx::__to_xstring<std::string, char>(int (
)(char*, unsigned long, char const*, __va_list_tag*), unsigned long, char const*, …)
2022-01-04 14:35:06 [734ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!_init
2022-01-04 14:35:06 [734ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
2022-01-04 14:35:06 [735ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!__libc_start_main
2022-01-04 14:35:06 [735ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
Are you running in docker or in host machine?
