• Hardware Platform (Jetson / GPU) 3090
• DeepStream Version 7.1 docker nvcr.io/nvidia/deepstream:7.1-gc-triton-devel
no any docs for this ,when run composercommand get error
./kit/kit ./composer/composer-standalone.kit --ext-folder composer --allow-root
Loading user config located at: '/root/.local/share/ov/data/Kit/composer-standalone/4.1/user.config.json'
[Info] [carb] Logging to file: /root/.nvidia-omniverse/logs/Kit/composer-standalone/4.1/kit_20241128_025404.log
2024-11-28 02:54:04 [5ms] [Warning] [omni.ext.plugin] [ext: omni_kit] Extensions config 'extension.toml' doesn't exist '/tmp/.tmpNvXgRaphComposer/run/composer/omni_kit' or '/tmp/.tmpNvXgRaphComposer/run/composer/omni_kit/config'
root@ps:/opt/nvidia/deepstream/deepstream# [0.471s] [ext: omni.kit.async_engine-0.0.0] startup
[0.571s] [ext: omni.assets.plugins-0.0.0] startup
[0.573s] [ext: omni.stats-0.0.0] startup
[0.574s] [ext: omni.client-1.0.1] startup
[0.586s] [ext: omni.gpu_foundation-0.0.0] startup
[0.606s] [ext: carb.windowing.plugins-1.0.0] startup
[0.641s] [ext: omni.kit.renderer.init-0.0.0] startup
2024-11-28 02:54:04 [658ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INCOMPATIBLE_DRIVER
2024-11-28 02:54:04 [658ms] [Error] [carb.graphics-vulkan.plugin] vkCreateInstance failed. Vulkan 1.1 is not supported, or your driver requires an update.
2024-11-28 02:54:04 [659ms] [Error] [gpu.foundation.plugin] carb::graphics::createInstance failed.
2024-11-28 02:54:05 [1,613ms] [Error] [omni.gpu_foundation_factory.plugin] Failed to create GPU foundation devices!
[1.715s] [ext: omni.kit.pipapi-0.0.0] startup
[1.721s] [ext: omni.kit.pip_archive-0.0.0] startup
[1.722s] [ext: omni.kit.loop-default-0.2.0] startup
[1.724s] [ext: omni.kit.test-0.0.0] startup
[1.804s] [ext: omni.mtlx-0.1.0] startup
[1.805s] [ext: omni.usd.config-1.0.3] startup
[1.811s] [ext: omni.gpucompute.plugins-0.0.0] startup
[1.812s] [ext: omni.usd.libs-1.0.0] startup
[1.920s] [ext: omni.appwindow-1.1.1] startup
[1.930s] [ext: omni.kit.renderer.core-0.0.0] startup
2024-11-28 02:54:06 [1,832ms] [Error] [omni.kit.renderer.plugin] GPU Foundation is not initialized!
[1.941s] [ext: omni.kit.renderer.capture-0.0.0] startup
[1.945s] [ext: omni.kit.renderer.imgui-0.0.0] startup
2024-11-28 02:54:06 [1,851ms] [Error] [omni.kit.imgui_renderer.plugin] _prepareDefaultWindow: invalid device attached to the default window!
