Running graph composer on GPU no output
Ubuntu 20.04
GStreamer 1.16.3
NVIDIA driver 525.85.12
CUDA 11.8
TensorRT 8.5.2.2
For above configuration we are trying to install and run NVIDIA Graph Composer 2.5. we have install this on amazon server with above configuration followed article to install deep stream 6.2 and accessing amazon server via RDP session.
when we run composer command we can see and review graph however every time when we try to run any test graph composer we are getting following error.
Can the c/c++ deepstream-test1 run successfully in the same enviroment?
Are you running Graph Composer inside docker or direct in the host machine?
