Graph Composer sample graphs not available
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version DeepStream 6.2
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 525.85.12
• Issue Type( questions, new requirements, bugs) bugs
  • Trying to create an application using Graph Composer
  • Followed instructions described in Getting Started with Graph Composer
  • I can successfully run Graph Composer and access components after completing steps in “Sync Extensions”
  • However can not reach samples graphs from Graph Composer (able to locate reference graphs in container via terminal) and can not run custom graphs
  • Perhaps system requirements are not compatible for running Graph Composer 2.5 using deepstream:6.2-devel container? OS: Ubuntu 22.04, CUDA12.0, Docker 23.0.1
I can reproduce the issue. We are investigating this problem, will be back when there is any progress.
Please refer to DeepStream 6.2 - Composer cannot access file directory - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums for the workaround.
I’m having the same problem.
Did you find a solution?
