How Running Graph Composer
• Hardware Platform (Jetson / GPU) Jetson Nano
• DeepStream Version 6.0.0
• JetPack Version (valid for Jetson only) 4.6.1
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 470
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) I have installed Deepstream and Graph Composer (Deb) package and cannot run Graph composer (compose command does not exist)
What platform is required to run Graph Composer? How can I run it if I don’t have a GPU workstation but only Jetson Nano’s?
You can only execute Graph Composer graphs on Jetson.
You can not run composer on Jetson.
https://docs.nvidia.com/metropolis/deepstream/dev-guide/graphtools-docs/docs/text/GraphComposer_intro.html
