• Hardware Platform (Xavier NX)
• DeepStream SDK 6.0
• JetPack Version 4.6
• TensorRT 8.0.1.6
• Issue Type (questions)
Hi, I have downloaded the Graph Composer Debian package and successfully installed it using the command:
sudo dpkg -i graph_composer-1.0.0_arm64.deb
After installing, I tried to launch Graph Composer by using the command:
composer
However, I receive the following output:
From what I have read over at https://forums.developer.nvidia.com/t/graph-composer-not-working-after-installation-jetson-xavier-nx/181681, it is stated that the UI for Graph Composer does not work for Jetson.
If this is the case, can I ask how can I work around this and use the Graph Composer, perhaps to run the sample applications such as deepstream-test1 found in nvidia/deepstream/deepstream-6.0/reference_graphs?
