Graph Composer not working after installation (Jetson Xavier NX)
• Hardware Platform (Jetson Xavier NX )
• DeepStream 6.0 EA
• JetPack Version 4.5.1
• Issue Type( bugs)
The graph composer UI does not seem to work on Jetson Xavier.
I have downloaded the deb (graph-composer-0.5.0_arm64.deb) and installed the package on the machine with: sudo dpkg -i graph-composer-0.5.0_arm64.deb. The package installs.
When I run the ‘compose’ command as instructed in the docs, I get a ‘command not found’.
Is there a working composer UI for Jetsons?
Jetson does not support composer UI.
I tried the installation steps, and install the deb with “sudo dpkg -i graph-composer-0.5.0_arm64.deb”. The “compose -h” command can work.
