How to run Graph Composer and check deepstream version post JP 6.0 Flash & GC install
• Hardware Platform (Jetson Orin 64GB Developer)
**• DeepStream Version 6.4 **
• JetPack Version 6.0
• TensorRT Version 8.6.2.3
• NVIDIA GPU Driver Version (valid for GPU only) How do I find?
• Issue Type( questions, bugs)
• How to reproduce the issue ? (I ran $sudo deepstream-app -version-all)
Completed a Jetpack 6 Flash with Deepstream 6.4. Visually all appears ok. I conducted an install of
Graph Composer & Deepstream reference graphs. All directories seem present :
steven@ubuntu:/opt/nvidia$ ls -al
drwxr-xr-x 3 root root 4096 Jan 15 16:34 deepstream
drwxr-xr-x 5 root root 4096 Jan 19 16:52 graph-composer
steven@ubuntu:/opt/nvidia/deepstream$ ls
deepstream deepstream-6.4
steven@ubuntu:/opt/nvidia/deepstream/deepstream-6.4$ ls -al | grep ref*
drwxr-xr-x 21 root root 4096 Jan 19 17:01 reference_graphs
steven@ubuntu:~$ sudo deepstream-app -version-all
[sudo] password for steven:
> deepstream-app: error while loading shared libraries: libgstrtspserver-1.0.so.0: cannot open shared object file: No such file or directory
#1 Don’t understand why I’m getting this error.
#2 I don’t see the way to run the Composer GUI application.
Update 2024-01-21:
I was assuming the ORIN Jetson flash of Deepstream would include all needed libraries. Apparently this isn’t the case or I missed the instructions for this somewhere. I followed part of the instruction in the Quickstart Guide used for manually installing Deep Stream.
I followed
  1. Install Dependencies section
  2. Install librdkafka (to enable Kafka protocol adaptor for message broker)
    Except, I did not create the “lib” directory in Deepstream-6.4. It was already
    created during the flash.
    After this the --version-all option worked correctly.
I still do not know how to run the Graph Composer. Anyone?
No. The SDKManager installation only install minimum dependencies.
Please follow https://docs.nvidia.com/metropolis/deepstream/6.1/dev-guide/text/DS_Quickstart.html#install-dependencies to install the dependencies.
The steps to run graphs on Jetson.
  1. Instal DeepStream SDK (Quickstart Guide — DeepStream documentation)
  2. Install graph_composer package: https://docs.nvidia.com/metropolis/deepstream/dev-guide/graphtools-docs/docs/text/GraphComposer_Platforms.html#ubuntu-22-04-lts-arm64-jetson
  3. Install sample graphs: Reference graphs — DeepStream documentation
  4. Sync GXF extensions from the server
    registry repo sync -n ngc-public
  5. Run gxf server in one terminal:
    gxf_server
  6. Run the sample graph in another terminal
    cd /opt/nvidia/deepstream/deepstream/reference_graphs/deepstream-test1
    /opt/nvidia/graph-composer/execute_graph.sh deepstream-test1.yaml parameters.yaml -d ../common/target_aarch64.yaml
Steps 1,2,3 already completed.
Step 4 executed with some errors. Maybe version difference that do not matter?
steven@development-orin:~$ registry repo sync -n ngc-public
2024-01-22 14:52:52,639 - Registry - WARNING - Some extensions failed to sync. Check logs at /tmp/nvgraph_registry.log
Repository synced
steven@development-orin:~$ cat /tmp/nvgraph_registry.log
2024-01-22 14:50:44,208 - Registry - DEBUG - Incompatible gxf core version
2024-01-22 14:50:44,208 - Registry - DEBUG - Registry gxf core version: 3.1.0 Extension gxf core version: 2.4.2
2024-01-22 14:50:44,209 - Registry - DEBUG - Skipping extension NvDsAnalyticsExt version 1.0.0
2024-01-22 14:50:44,508 - Registry - DEBUG - Extension dependency not found None version: 1.4.1
2024-01-22 14:50:44,688 - Registry - DEBUG - Extension dependency not found NvDsBaseExt version: 1.4.1
2024-01-22 14:50:44,737 - Registry - DEBUG - Incompatible gxf core version
2024-01-22 14:50:44,738 - Registry - DEBUG - Registry gxf core version: 3.1.0 Extension gxf core version: 3.0.0
2024-01-22 14:50:44,738 - Registry - DEBUG - Skipping extension NvDsAnalyticsExt version 1.3.0
2024-01-22 14:52:52,639 - Registry - DEBUG - Skipping extension UcxExtension version 0.0.5
Step 5
Terminal 1:
steven@development-orin:~$ gxf_server
INFO:root:Environment variable ‘GXF_SERVER_PORT’ is not set. Using default port: 50051.
INFO:root:SERVER started: Server is available at [::]:50051…
Step 6
Terminal 2:
steven@development-orin:~$ cd /opt/nvidia/deepstream/deepstream/reference_graphs/deepstream-test1
steven@development-orin:/opt/nvidia/deepstream/deepstream/reference_graphs/deepstream-test1$ /opt/nvidia/graph-composer/execute_graph.sh deepstream-test1.yaml parameters.yaml -d ../common/target_aarch64.yaml
Graphs: deepstream-test1.yaml,parameters.yaml
Target: ../common/target_aarch64.yaml
Running deepstream-test1.yaml
2024-01-22 15:13:57.016 ERROR extensions/nvdssource/nvurisrcbin.hpp@36: Could not create GStreamer element 'nvurisrcbin'
2024-01-22 15:13:57.016 ERROR gxf/std/program.cpp@519: Couldn't run async. Deactivating...
2024-01-22 15:13:57.016 ERROR gxf/core/runtime.cpp@1392: Graph run failed with error: GXF_FAILURE
2024-01-22 15:13:57.016 ERROR gxf/gxe/gxe.cpp@269: GxfGraphRunAsync Error: GXF_FAILURE
End deepstream-test1.yaml
[INFO] Graph installation directory /tmp/ds.deepstream-test1 and manifest /tmp/ds.deepstream-test1/manifest.yaml retained
I did not see the Graph Composer display.
Seems you installed the wrong graph composer package.
Only GXE and registry are supported on Jetson. https://docs.nvidia.com/metropolis/deepstream/dev-guide/graphtools-docs/docs/text/GraphComposer_Platforms.html#ubuntu-22-04-lts-arm64-jetson
You can only execute GXF graphs on Jetson.
Please read the document before you run.
When Installing Graph Composer on x86_64 Ubuntu 22.04 is there a requirement for an Nvidia GPU?
Sure, there must be a Nvidia GPU or iGPU(Intel Iris Graphics 540 or later). Ubuntu 22.04 LTS (x86_64) — DeepStream documentation 6.4 documentation
On my Dell laptop x86_64 with Ubuntu 22.04
~$ sudo dpkg -i graph_composer-3.1.0_x86_64.deb
dpkg: dependency problems prevent configuration of graph-composer:
graph-composer depends on libyaml-cpp-dev
so I
~$ sudo apt install libyaml-cpp-dev
~$ sudo apt --fix-broken install
Completed successfully
~$ composer
Message asked me to disable IOMMU
~$ cd /etc/default
~$ vim grub
GRUB_CMDLINE_LINUX=“intel_iommu=off”
~$ update-grub
I ran composer again, the issues above were resolved, However, now I have several new errors.
I don’t know if they are important. The Composer did open in a window.
~$ compose
[Info] [carb] Logging to file: /home/steven/.nvidia-omniverse/logs/Kit/composer-standalone/3.1/kit_20240126_151544.log
2024-01-26 23:15:44 [1ms] [Warning] [omni.ext.plugin] [ext: omni_kit] Extensions config 'extension.toml' doesn't exist '/tmp/.tmpNvXgRaphComposer/run/composer/omni_kit' or '/tmp/.tmpNvXgRaphComposer/run/composer/omni_kit/config'
steven@DEVELOPMENT-DELL:~$ [0.380s] [ext: omni.kit.async_engine-0.0.0] startup
2024-01-26 23:15:45 [435ms] [Warning] [gpu.foundation.plugin] nvidia-smi not found in '/usr/bin/'
2024-01-26 23:15:45 [520ms] [Warning] [carb.cudainterop.plugin] NVML could not be loaded. Error: libnvidia-ml.so.1: cannot open shared object file: No such file or directory
2024-01-26 23:15:45 [520ms] [Warning] [gpu.foundation.plugin] ECC check skipped: Can't query ECC mode for device 0.
[0.550s] [ext: omni.kit.pipapi-0.0.0] startup
[1.101s] [ext: omni.usd_resolver-1.0.0] startup
2024-01-26 23:15:45 [1,084ms] [Warning] [omni.ext.plugin] [ext: omni.usd_resolver-1.0.0] Native plugin search dir contains several files: /tmp/.tmpNvXgRaphComposer/run/kit/exts/omni.usd_resolver/bin . It makes dir walk slow, replace with the exact path to the plugin instead of a wildcard.
[1.105s] [ext: omni.kit.widget.nucleus_connector-1.1.0] startup
[1.602s] [ext: omni.exp.graph.composer-3.1.0] startup
2024-01-26 23:15:46 [1,587ms] [Warning] [omni.kit.app._impl] carb.imgui is deprecated. Use omni.kit.imgui instead.
[1.776s] [ext: composer-standalone-3.1.0] startup
[1.819s] app ready
2024-01-26 23:15:46 [2,073ms] [Error] [omni.exp.graph.composer.registry_window] Failed to get repo list: <AioRpcError of RPC that terminated with:
	status = StatusCode.UNAVAILABLE
	details = "failed to connect to all addresses; last error: UNKNOWN: ipv4:127.0.0.1:50051: Failed to connect to remote host: Connection refused"
	debug_error_string = "UNKNOWN:failed to connect to all addresses; last error: UNKNOWN: ipv4:127.0.0.1:50051: Failed to connect to remote host: Connection refused {created_time:"2024-01-26T15:15:46.772138-08:00", grpc_status:14}"
2024-01-26 23:15:46 [2,073ms] [Error] [omni.exp.graph.composer.node_registry_model] Registry Model update failed
steven@DEVELOPMENT-DELL:~$ 2024-01-27 00:11:48 [3,363,981ms] [Warning] [omni.kit.window.filepicker.api] No item exists with url '/opt/nvidia/deepstream/deepstream/reference_graphs'.
2024-01-27 00:11:48 [3,363,998ms] [Warning] [omni.kit.window.filepicker.api] No item exists with url '/opt/nvidia/deepstream/deepstream'.
2024-01-27 00:11:48 [3,364,083ms] [Warning] [omni.kit.window.filepicker.api] No item exists with url '/opt/nvidia/deepstream/deepstream'.
2024-01-27 00:11:48 [3,364,100ms] [Warning] [omni.kit.window.filepicker.api] No item exists with url '/opt/nvidia/deepstream'.
It is OK.
One last question:
I reviewed the 7 requirements for the Graph Composer as you pointed out. I can do all except I can’t
see how to install DeepStream SDK 6.4 for DeepStream extensions. All of the installation procedures are for dGPU or Jetson. I have a Dell XPS with an integrated iGPU (Intel(R) Iris(R) Xe Graphics). Can you point me to the install procedures in this case, or is this not needed?
iGPU device can only be used to run composer GUI to construct graphs. No DeepStream is needed for the case.
The graphs can not be executed on iGPU devices.
