• Hardware Platform (Jetson / GPU) RTX 3060
• DeepStream Version 6.1
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 510.47.03
**• Issue Type( questions, new requirements, bugs)**question
I have successfully installed graph composer according to the manual, and I have even succeeded in running composer by typing composer in the command But there is no component and when I open reference_graph(deepstream-test1 .etc) there is also no component
the following error also occurs
2022-08-05 07:57:26 [457ms] [Error] [gpu.foundation.plugin] Failed opening shader cache version file: /home/ims01/.cache/ov/Kit/103.1/66b6689c/shadercache/release/version
2022-08-05 07:57:26 [457ms] [Error] [gpu.foundation.plugin] Failed to process shader cache version file
