A2
CUDA version: 11.8
GPU Driver Version 520.61.05
• DeepStream Version
6.1.1 (docker from nvcr.io./nvidia/deepstream:6.1.1-devel)
• TensorRT Version
8.4.1-1
questions
I want to get a test application running using Composer. The Composer is running in a Docker container on a GPU machine (A2) which is connected to a Display. When I run the graph, the pipeline executes for a few frames (see logs) but then encounter several errors-
Appreciate any feedback on this.
LOG_graphcomposer_20221028.txt (166.7 KB)
2022-11-01 03:45:26 [Error] [omni.kit.app.impl] [py stderr]: 0:00:02.658422775 e[332m 391e[00m 0x7f0adc7f92f0 e[36mINFO e[00m e[00m nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<nvinfer_bin_nvinfer>e[00m NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 1]: Use deserialized engine model: /tmp/ds.deepstream-test1/gxf/sample_models/primary.resnet10.caffemodel_b1_gpu0_int8.engine
2022-11-01 03:45:26 [Error] [omni.kit.app.impl] [py stderr]: 0:00:02.660460736 e[332m 391e[00m 0x7f0adc7f92f0 e[36mINFO e[00m e[00m nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<nvinfer_bin_nvinfer>e[00m [UID 1]: Load new model:/tmp/ds.deepstream-test1/gxf/sample_models/config_infer_primary.txt sucessfully
2022-11-01 03:45:26 [Info] [omni.kit.app.impl] [py stdout]: INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
2022-11-01 03:45:26 [Info] [omni.kit.app.impl] [py stdout]: 0 INPUT kFLOAT input_1 3x368x640
2022-11-01 03:45:26 [Info] [omni.kit.app.impl] [py stdout]: 1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2022-11-01 03:45:26 [Info] [omni.kit.app.impl] [py stdout]: 2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
2022-11-01 03:45:26 [Info] [omni.kit.app.impl] [py stdout]: Running...
2022-11-01 03:45:26 [Info] [omni.kit.app.impl] [py stdout]: ****** NvDsScheduler Runtime Keyboard controls:
2022-11-01 03:45:26 [Info] [omni.kit.app.impl] [py stdout]: p: Pause pipeline
2022-11-01 03:45:26 [Info] [omni.kit.app.impl] [py stdout]: r: Resume pipeline
2022-11-01 03:45:26 [Info] [omni.kit.app.impl] [py stdout]: q: Quit pipeline
2022-11-01 03:45:26 [Info] [omni.kit.app.impl] [py stdout]: e[0m2022-11-01 03:45:26.607 INFO extensions/nvdsbase/nvds_scheduler.cpp@393: NvDsScheduler Pipeline ready
2022-11-01 03:45:26 [Error] [omni.kit.app.impl] [py stderr]: WARNING from element nvurisrc_bin_src_elem: No decoder available for type 'audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)119056e500, rate=(int)48000, channels=(int)2'.
2022-11-01 03:45:26 [Info] [omni.kit.app.impl] [py stdout]: e[0m2022-11-01 03:45:26.735 INFO extensions/nvdsbase/nvds_scheduler.cpp@378: NvDsScheduler Pipeline running
2022-11-01 03:45:26 [Info] [omni.kit.app.impl] [py stdout]: Source 0: Frame Number = 0 Total objects = 10 [ Car:4 Person:6 ]
2022-11-01 03:45:26 [Info] [omni.kit.app.impl] [py stdout]: Source 0: Frame Number = 1 Total objects = 8 [ Car:3 Person:5 ]
2022-11-01 03:45:26 [Info] [omni.kit.app.impl] [py stdout]: Source 0: Frame Number = 2 Total objects = 11 [ Car:5 Person:6 ]
2022-11-01 03:45:26 [Info] [omni.kit.app.impl] [py stdout]: Source 0: Frame Number = 3 Total objects = 10 [ Car:5 Person:5 ]
2022-11-01 03:45:26 [Info] [omni.kit.app.impl] [py stdout]: cuGraphicsGLRegisterBuffer failed with error(219) gst_eglglessink_cuda_init texture = 1
2022-11-01 03:45:26 [Info] [omni.kit.app.impl] [py stdout]: Source 0: Frame Number = 4 Total objects = 12 [ Car:5 Person:7 ]
2022-11-01 03:45:26 [Info] [omni.kit.app.impl] [py stdout]: Source 0: Frame Number = 5 Total objects = 11 [ Car:5 Person:6 ]
2022-11-01 03:45:26 [Info] [omni.kit.app.impl] [py stdout]: Source 0: Frame Number = 6 Total objects = 8 [ Car:4 Person:4 ]
2022-11-01 03:45:26 [Info] [omni.kit.app.impl] [py stdout]: Source 0: Frame Number = 7 Total objects = 8 [ Car:4 Person:4 ]
2022-11-01 03:45:26 [Info] [omni.kit.app.impl] [py stdout]: Source 0: Frame Number = 8 Total objects = 10 [ Car:5 Person:5 ]
2022-11-01 03:45:26 [Info] [omni.kit.app.impl] [py stdout]: Source 0: Frame Number = 9 Total objects = 8 [ Car:4 Person:4 ]
2022-11-01 03:45:26 [Info] [omni.kit.app.impl] [py stdout]: Source 0: Frame Number = 10 Total objects = 10 [ Car:5 Person:5 ]
2022-11-01 03:45:26 [Info] [omni.kit.app.impl] [py stdout]: Returned, stopping playback
2022-11-01 03:45:26 [Error] [omni.kit.app.impl] [py stderr]: 0:00:02.970410656 e[332m 391e[00m 0x7f0adc004400 e[33;01mWARN e[00m e[00m nvinfer gstnvinfer.cpp:2300:gst_nvinfer_output_loop:<nvinfer_bin_nvinfer>e[00m error: Internal data stream error.
2022-11-01 03:45:26 [Error] [omni.kit.app.impl] [py stderr]: 0:00:02.970424745 e[332m 391e[00m 0x7f0adc004400 e[33;01mWARN e[00m e[00m nvinfer gstnvinfer.cpp:2300:gst_nvinfer_output_loop:<nvinfer_bin_nvinfer>e[00m error: streaming stopped, reason not-negotiated (-4)
2022-11-01 03:45:26 [Error] [omni.kit.app.impl] [py stderr]: e[1;31m2022-11-01 03:45:26.914 ERROR extensions/nvdsbase/nvds_scheduler.cpp@307: Error from /GstPipeline:NvDsScheduler-Pipeline/GstDsNvInferBin:NvDsInferVideo..5080/nv_ds_infer10..2748/GstNvInfer:nvinfer_bin_nvinfer: Internal data stream error.e[0m
2022-11-01 03:45:26 [Error] [omni.kit.app.impl] [py stderr]: e[1;31m2022-11-01 03:45:26.914 ERROR extensions/nvdsbase/nvds_scheduler.cpp@309: Debug info:
2022-11-01 03:45:26 [Error] [omni.kit.app.impl] [py stderr]: gstnvinfer.cpp(2300): gst_nvinfer_output_loop (): /GstPipeline:NvDsScheduler-Pipeline/GstDsNvInferBin:NvDsInferVideo..5080/nv_ds_infer10..2748/GstNvInfer:nvinfer_bin_nvinfer:
2022-11-01 03:45:26 [Error] [omni.kit.app.impl] [py stderr]: streaming stopped, reason not-negotiated (-4)e[0m
2022-11-01 03:45:26 [Error] [omni.kit.app.impl] [py stderr]: e[1;31m2022-11-01 03:45:26.915 ERROR extensions/nvdsbase/nvds_scheduler.cpp@344: Error from /GstPipeline:NvDsScheduler-Pipeline/GstDsNvInferBin:NvDsInferVideo..5080/nv_ds_infer10..2748/GstNvInfer:nvinfer_bin_nvinfer: Internal data stream error.e[0m
2022-11-01 03:45:26 [Error] [omni.kit.app.impl] [py stderr]: e[1;31m2022-11-01 03:45:26.915 ERROR extensions/nvdsbase/nvds_scheduler.cpp@346: Debug info:
2022-11-01 03:45:26 [Error] [omni.kit.app.impl] [py stderr]: e[1;31m2022-11-01 03:45:26.916 ERROR extensions/nvdsbase/nvds_scheduler.cpp@307: Error from /GstPipeline:NvDsScheduler-Pipeline/GstDsNvUriSrcBin:NvDsSingleSrcInput..5320/nv_ds_single_src_input3..c518/GstURIDecodeBin:nvurisrc_bin_src_elem/GstDecodeBin:decodebin0/GstQTDemux:qtdemux0: Internal data stream error.e[0m
2022-11-01 03:45:26 [Error] [omni.kit.app.impl] [py stderr]: e[1;31m2022-11-01 03:45:26.916 ERROR extensions/nvdsbase/nvds_scheduler.cpp@309: Debug info:
2022-11-01 03:45:26 [Error] [omni.kit.app.impl] [py stderr]: qtdemux.c(6619): gst_qtdemux_loop (): /GstPipeline:NvDsScheduler-Pipeline/GstDsNvUriSrcBin:NvDsSingleSrcInput..5320/nv_ds_single_src_input3..c518/GstURIDecodeBin:nvurisrc_bin_src_elem/GstDecodeBin:decodebin0/GstQTDemux:qtdemux0:
2022-11-01 03:45:27 [Info] [omni.kit.app.impl] [py stdout]: Deleting pipeline
