Deepstream 6.0 + Graph Composer Container execution issue on Jetson Nano 4GB
Ahoi everyone,
I face the following issue with my Jetson Nano 4GB when trying to run a previously build container from a running graph composer application
I’m trying to put as much information about my approach as possible.
basically im following this guide ba Microsoft: Exercise - Publish an NVIDIA DeepStream Graph Composer container to Azure Container Registry - Training | Microsoft Learn
Important to note: There is no display attached to my Jetson Nano 4GB
• Hardware Platform (Jetson)
• DeepStream Version
6.0 - installed via Quickstart Guide — DeepStream 6.0.1 Release documentation as the Jetson Nano has Jetpack 4.6.3 / L4T 32.7.3 installed
• TensorRT Version
8.2.1.9
NA
This is the error I get when I run the container
2024-07-26 22:29:22.308 ERROR extensions/nvdsbase/nvds_scheduler.cpp@179: Failed to set GStreamer pipeline to PLAYING
Executing my previously build Container with the following YAML files
parameter.yaml
components:
- name: nv_ds_single_src_input3..c518
  parameters:
    uri: file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4
components:
- name: nv_ds_stream_mux6..db00
  parameters:
    batch-size: 1
    height: 1080
    width: 1920
deepstream-test1.yaml
application:
dependencies:
- extension: NvDsSourceExt
  uuid: a632d022-3425-4848-9074-e6483ef74366
  version: 0.0.6
- extension: NvDsBaseExt
  uuid: 56d7e3ec-62c6-4652-bcc8-4f1c3b00df03
  version: 0.0.4
- extension: NvDsMuxDemuxExt
  uuid: 89b8398c-5820-4051-835c-a91f2d49766b
  version: 0.0.4
- extension: NvDsInferenceExt
  uuid: 0b02963e-c24e-4c13-ace0-c4cdf36c7c71
  version: 0.0.4
- extension: NvDsSampleModelsExt
  uuid: 909dc1ea-c654-44c1-97a3-0b8fec12141a
  version: 0.0.4
- extension: NvDsVisualizationExt
  uuid: 25903cd4-fc5c-4139-987b-47bb27e8b424
  version: 0.0.3
- extension: NvDsInferenceUtilsExt
  uuid: 27856a43-5ad4-4d8e-be36-0ec2cf9bbb58
  version: 0.0.5
- extension: NvDsOutputSinkExt
  uuid: 3fc9ad87-03e7-47a8-bbfc-8501c3f7ff2f
  version: 0.0.3
components:
  parameters:
    audio-out-%u: nv_ds_dynamic_output4..c7b8
    video-out-%u: nv_ds_dynamic_output5..cb70
  type: nvidia::deepstream::NvDsSingleSrcInput
- name: nv_ds_dynamic_output4..c7b8
  type: nvidia::deepstream::NvDsDynamicOutput
- name: nv_ds_dynamic_output5..cb70
ui_property:
  position:
    x: -178.45005798339844
    y: -174.2137451171875
  state: 0
components:
  parameters:
    batch-size: 1
    height: 1080
    video-in-%u: nv_ds_on_request_input7..d9e8
    video-out: nv_ds_static_output8..da90
    width: 1920
  type: nvidia::deepstream::NvDsStreamMux
- name: nv_ds_on_request_input7..d9e8
  type: nvidia::deepstream::NvDsOnRequestInput
- name: nv_ds_static_output8..da90
  type: nvidia::deepstream::NvDsStaticOutput
ui_property:
  position:
    x: -154.7552490234375
    y: 60.636112213134766
  state: 0
components:
- name: nv_ds_connection9..7978
  parameters:
    source: NvDsSingleSrcInput..5320/nv_ds_dynamic_output5..cb70
    target: NvDsStreamMux..5d68/nv_ds_on_request_input7..d9e8
  type: nvidia::deepstream::NvDsConnection
components:
- name: nv_ds_infer10..2748
  parameters:
    infer-model-config: resnet10_4_class_detector3..b278
    video-in: nv_ds_static_input11..5a90
    video-out: nv_ds_static_output12..5b38
  type: nvidia::deepstream::NvDsInferVideo
- name: nv_ds_static_input11..5a90
  type: nvidia::deepstream::NvDsStaticInput
- name: nv_ds_static_output12..5b38
- name: resnet10_4_class_detector3..b278
  type: nvidia::deepstream::NvDsResnet10_4ClassDetectorModel
ui_property:
  position:
    x: -172.15878295898438
    y: 214.3798828125
  state: 0
components:
- name: nv_ds_connection13..5e10
  parameters:
    source: NvDsStreamMux..5d68/nv_ds_static_output8..da90
    target: NvDsInferVideo..5080/nv_ds_static_input11..5a90
components:
- name: nv_ds_osd14..5978
  parameters:
    video-in: nv_ds_static_input15..7b00
    video-out: nv_ds_static_output16..7b70
  type: nvidia::deepstream::NvDsOSD
- name: nv_ds_static_input15..7b00
- name: nv_ds_static_output16..7b70
ui_property:
  position:
    x: 231.75030517578125
    y: -93.65518951416016
  state: 0
components:
- name: nv_ds_connection17..ac88
  parameters:
    source: NvDsInferVideo..5080/nv_ds_static_output12..5b38
    target: NvDsOSD..c668/nv_ds_static_input15..7b00
components:
- name: per_class_object_counting21..ff28
  parameters:
    probe-connector: nv_ds_probe_connector0..2b00
  type: nvidia::deepstream::NvDsPerClassObjectCounting
- name: nv_ds_probe_connector0..2b00
  type: nvidia::deepstream::NvDsProbeConnector
ui_property:
  position:
    x: 229.2032012939453
    y: 416.7696838378906
  state: 0
components:
- name: nv_ds_probe1..5be0
  parameters:
    io: NvDsInferVideo..5080/nv_ds_static_output12..5b38
    probe-connector: NvDsPerClassObjectCounting..b710/nv_ds_probe_connector0..2b00
components:
- name: nv_ds_scheduler2..4a58
  type: nvidia::deepstream::NvDsScheduler
ui_property:
  position:
    x: 670.6022338867188
    y: 501.16558837890625
  state: 0
components:
- name: 1-to-N pipe fitting8
  parameters:
    in: Static Data Input9
    out-%u: On Request Data Output10
  type: nvidia::deepstream::NvDsTee
- name: Static Data Input9
- name: On Request Data Output10
  type: nvidia::deepstream::NvDsOnRequestOutput
ui_property:
  position:
    x: 428.6846008300781
    y: 117.21231079101562
components:
- name: Deepstream Data Connection11
  parameters:
    source: NvDsOSD..c668/nv_ds_static_output16..7b70
    target: 1-to-N pipe fitting/Static Data Input9
components:
- name: Video File Output12
  parameters:
    output-file: out.mp4
    video-in: Static Data Input13
  type: nvidia::deepstream::NvDsFileOut
- name: Static Data Input13
ui_property:
  position:
    x: 800.837890625
    y: 14.631561279296875
components:
- name: nv_ds_rtsp_out14
  parameters:
    audio-in: On Request Data Input15
    video-in: On Request Data Input16
  type: nvidia::deepstream::NvDsRtspOut
- name: On Request Data Input15
- name: On Request Data Input16
ui_property:
  position:
    x: 825.8868408203125
    y: 181.62344360351562
components:
- name: Deepstream Data Connection17
  parameters:
    source: 1-to-N pipe fitting/On Request Data Output10
    target: NvDsRtspOut/On Request Data Input16
components:
- name: Deepstream Data Connection18
  parameters:
    target: Video File Output/Static Data Input13
ds_test1_container_builder_jetson.yaml
# final stage
unique_stage: final_image
base_image: nvcr.io/nvidia/deepstream-l4t:6.0.1-base
stage_model: clean_stage
local_copy_files:
- src: "/opt/nvidia/graph-composer/graph_composer-1.0.0_arm64.deb"
  dst: "/tmp/"
- src: "parameters.yaml"
  dst: "/workspace/deepstream-test1/" # ends with '/' is folder
- src: "/tmp/rsync_3.1.0-2_arm64.deb"
  dst: "/tmp/"
custom_runs:
 - "apt install -y libpopt0"
 - "dpkg -i /tmp/rsync_3.1.0-2_arm64.deb"
 - "apt install -y /tmp/graph_composer-1.0.0_arm64.deb && rm -rf /tmp/graph-composer-1.0.0_arm64.deb"
work_folder: /workspace/deepstream-test1/
env_list:
  PATH: "/opt/nvidia/graph-composer/:$PATH"
  LD_LIBRARY_PATH: "/opt/nvidia/graph-composer/:$LD_LIBRARY_PATH"
#  DISPLAY: ":0"
# Setup entrypoint
entrypoint:
- "gxe"
- "--manifest"
- "deepstream-test1_manifest.yaml"
- "--app"
- "deepstream-test1.yaml,parameters.yaml"
# Container Builder Config
container_builder: main # required
graph:
  graph_files: [ deepstream-test1.yaml ]
  graph_dst: /workspace/deepstream-test1/
  manifest_dst: /workspace/deepstream-test1/deepstream-test1_manifest.yaml
  ext_install_root: /workspace/deepstream-test1/
docker_build:
    image_name: deepstream-test1-jetson_17072024:v1
When executing the graph application everything runs as designed.
The Graph Composer application is executed via:
sudo /opt/nvidia/graph-composer/execute_graph.sh deepstream-test1.yaml parameters.yaml -d /opt/nvidia/graph-composer/config/target_aarch64.yaml
Graph Composer Application execution Output
nvidia@ubuntu:/opt/nvidia/deepstream/deepstream-6.0/reference_graphs/TEST2$ sudo /opt/nvidia/graph-composer/execute_graph.sh deepstream-test1.yaml parameters.yaml -d /opt/nvidia/graph-composer/config/target_aarch64.yaml
Graphs: deepstream-test1.yaml,parameters.yaml
Target: /opt/nvidia/graph-composer/config/target_aarch64.yaml
Running deepstream-test1.yaml
[INFO] Writing manifest to /tmp/ds.deepstream-test1/manifest.yaml
2024-07-27 00:16:37.806 INFO  gxf/gxe/gxe.cpp@98: Creating context
2024-07-27 00:16:38.827 INFO  gxf/gxe/gxe.cpp@85: Loading app: '/opt/nvidia/deepstream/deepstream-6.0/reference_graphs/TEST2/deepstream-test1.yaml'
2024-07-27 00:16:38.827 INFO  gxf/std/yaml_file_loader.cpp@59: Loading GXF entities from YAML file '/opt/nvidia/deepstream/deepstream-6.0/reference_graphs/TEST2/deepstream-test1.yaml'...
2024-07-27 00:16:38.842 INFO  gxf/gxe/gxe.cpp@85: Loading app: '/opt/nvidia/deepstream/deepstream-6.0/reference_graphs/TEST2/parameters.yaml'
2024-07-27 00:16:38.842 INFO  gxf/std/yaml_file_loader.cpp@59: Loading GXF entities from YAML file '/opt/nvidia/deepstream/deepstream-6.0/reference_graphs/TEST2/parameters.yaml'...
2024-07-27 00:16:38.843 INFO  gxf/gxe/gxe.cpp@153: Initializing...
2024-07-27 00:16:38.945 INFO  extensions/nvdsbase/nvds_scheduler.cpp@266: This program is linked against GStreamer 1.14.5
2024-07-27 00:16:38.946 INFO  extensions/nvdssource/nvurisrcbin.hpp@24: initialize: nvurisrcbin nv_ds_single_src_input3..c518
2024-07-27 00:16:38.947 INFO  extensions/nvdsmuxdemux/nvstreammux.hpp@27: initialize: nvstreammux nv_ds_stream_mux6..db00
2024-07-27 00:16:38.947 INFO  extensions/nvdsinference/nvinferbin.hpp@24: initialize: nvinferbin nv_ds_infer10..2748
2024-07-27 00:16:38.948 INFO  extensions/nvdsvisualization/nvosdbin.hpp@24: initialize: nvosdbin nv_ds_osd14..5978
2024-07-27 00:16:38.949 INFO  ./extensions/nvdsbase/tee.hpp@23: initialize: tee 1-to-N pipe fitting8
2024-07-27 00:16:38.949 INFO  extensions/nvdsoutputsink/nvvideoencfilesinkbin.hpp@23: initialize: nvvideoencfilesinkbin Video File Output12
2024-07-27 00:16:38.949 INFO  extensions/nvdsoutputsink/nvrtspoutsinkbin.hpp@23: initialize: nvrtspoutsinkbin nv_ds_rtsp_out14
2024-07-27 00:16:38.950 INFO  gxf/gxe/gxe.cpp@160: Running...
2024-07-27 00:16:38.950 INFO  extensions/nvdsbase/nvds_scheduler.cpp@117: Scheduling 7 elements and 1 components
2024-07-27 00:16:38.950 INFO  extensions/nvdssource/nvurisrcbin.hpp@32: create_element: nvurisrcbin nv_ds_single_src_input3..c518
2024-07-27 00:16:39.264 INFO  extensions/nvdssource/nvurisrcbin.hpp@56: bin_add: nvurisrcbin nv_ds_single_src_input3..c518
2024-07-27 00:16:39.264 INFO  extensions/nvdsmuxdemux/nvstreammux.hpp@37: create_element: nvstreammux nv_ds_stream_mux6..db00
2024-07-27 00:16:39.268 INFO  extensions/nvdsmuxdemux/nvstreammux.hpp@61: bin_add: nvstreammux nv_ds_stream_mux6..db00
2024-07-27 00:16:39.269 INFO  extensions/nvdsinference/nvinferbin.hpp@32: create_element: nvinferbin nv_ds_infer10..2748
2024-07-27 00:16:39.274 INFO  extensions/nvdsinference/nvinferbin.hpp@56: bin_add: nvinferbin nv_ds_infer10..2748
2024-07-27 00:16:39.277 INFO  extensions/nvdsvisualization/nvosdbin.hpp@32: create_element: nvosdbin nv_ds_osd14..5978
2024-07-27 00:16:39.282 INFO  extensions/nvdsvisualization/nvosdbin.hpp@56: bin_add: nvosdbin nv_ds_osd14..5978
2024-07-27 00:16:39.282 INFO  ./extensions/nvdsbase/tee.hpp@31: create_element: tee 1-to-N pipe fitting8
2024-07-27 00:16:39.282 INFO  ./extensions/nvdsbase/tee.hpp@55: bin_add: tee 1-to-N pipe fitting8
2024-07-27 00:16:39.282 INFO  extensions/nvdsoutputsink/nvvideoencfilesinkbin.hpp@31: create_element: nvvideoencfilesinkbin Video File Output12
2024-07-27 00:16:39.283 INFO  extensions/nvdsoutputsink/nvvideoencfilesinkbin.hpp@49: bin_add: nvvideoencfilesinkbin Video File Output12
2024-07-27 00:16:39.283 INFO  extensions/nvdsoutputsink/nvrtspoutsinkbin.hpp@31: create_element: nvrtspoutsinkbin nv_ds_rtsp_out14
2024-07-27 00:16:39.283 INFO  extensions/nvdsoutputsink/nvrtspoutsinkbin.hpp@55: bin_add: nvrtspoutsinkbin nv_ds_rtsp_out14
 *** NvDsRtspOut/nv_ds_rtsp_out14: Launched RTSP Streaming at rtsp://localhost:8554/ds-test ***
Opening in BLOCKING MODE
ERROR: Deserialize engine failed because file path: /tmp/ds.deepstream-test1/909dc1ea-c654-44c1-97a3-0b8fec12141a/0.0.4/primary.resnet10.caffemodel_b1_gpu0_int8.engine open error
0:00:03.092522591  1501   0x7f544e8af0 WARN                 nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<nvinfer_bin_nvinfer> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1889> [UID = 1]: deserialize engine from file :/tmp/ds.deepstream-test1/909dc1ea-c654-44c1-97a3-0b8fec12141a/0.0.4/primary.resnet10.caffemodel_b1_gpu0_int8.engine failed
0:00:03.094183973  1501   0x7f544e8af0 WARN                 nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<nvinfer_bin_nvinfer> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1996> [UID = 1]: deserialize backend context from engine from file :/tmp/ds.deepstream-test1/909dc1ea-c654-44c1-97a3-0b8fec12141a/0.0.4/primary.resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:00:03.094234338  1501   0x7f544e8af0 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<nvinfer_bin_nvinfer> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
WARNING: INT8 not supported by platform. Trying FP16 mode.
0:01:13.007931445  1501   0x7f544e8af0 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<nvinfer_bin_nvinfer> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1947> [UID = 1]: serialize cuda engine to file: /tmp/ds.deepstream-test1/909dc1ea-c654-44c1-97a3-0b8fec12141a/0.0.4/primary.resnet10.caffemodel_b1_gpu0_fp16.engine successfully
INFO: [Implicit Engine Info]: layers num: 3
0   INPUT  kFLOAT input_1         3x368x640
1   OUTPUT kFLOAT conv2d_bbox     16x23x40
2   OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:01:13.205847406  1501   0x7f544e8af0 INFO                 nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<nvinfer_bin_nvinfer> [UID 1]: Load new model:/tmp/ds.deepstream-test1/909dc1ea-c654-44c1-97a3-0b8fec12141a/0.0.4/config_infer_primary.txt sucessfully
Running...
****** NvDsScheduler Runtime Keyboard controls:
p: Pause pipeline
r: Resume pipeline
q: Quit pipeline
2024-07-27 00:17:52.055 INFO  extensions/nvdsbase/nvds_scheduler.cpp@358: NvDsScheduler Pipeline ready
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
2024-07-27 00:17:52.483 INFO  extensions/nvdsbase/nvds_scheduler.cpp@343: NvDsScheduler Pipeline running
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
Source 0: Frame Number = 0 Total objects = 7 [ Car:4 Person:3 ]
Source 0: Frame Number = 1 Total objects = 7 [ Car:4 Person:3 ]
Source 0: Frame Number = 2 Total objects = 7 [ Car:4 Person:3 ]
Source 0: Frame Number = 3 Total objects = 8 [ Car:5 Person:3 ]
Source 0: Frame Number = 4 Total objects = 10 [ Car:5 Person:5 ]
Source 0: Frame Number = 5 Total objects = 8 [ Car:5 Person:3 ]
H264: Profile = 66, Level = 0
avg bitrate=0 for CBR, force to CQP mode
NVMEDIA_ENC: bBlitMode is set to TRUE
Source 0: Frame Number = 6 Total objects = 5 [ Car:3 Person:2 ]
Source 0: Frame Number = 7 Total objects = 6 [ Car:4 Person:2 ]
Source 0: Frame Number = 8 Total objects = 7 [ Car:4 Person:3 ]
Source 0: Frame Number = 9 Total objects = 7 [ Car:4 Person:3 ]
Source 0: Frame Number = 10 Total objects = 7 [ Car:4 Person:3 ]
... Frames ommited
Source 0: Frame Number = 1432 Total objects = 6 [ Bicycle:0 Car:4 Person:2 Roadsign:0 ]
Source 0: Frame Number = 1433 Total objects = 6 [ Bicycle:0 Car:4 Person:2 Roadsign:0 ]
Source 0: Frame Number = 1434 Total objects = 8 [ Bicycle:0 Car:6 Person:2 Roadsign:0 ]
Source 0: Frame Number = 1435 Total objects = 9 [ Bicycle:0 Car:7 Person:2 Roadsign:0 ]
Source 0: Frame Number = 1436 Total objects = 10 [ Bicycle:0 Car:8 Person:2 Roadsign:0 ]
Source 0: Frame Number = 1437 Total objects = 8 [ Bicycle:0 Car:6 Person:2 Roadsign:0 ]
Source 0: Frame Number = 1438 Total objects = 8 [ Bicycle:0 Car:6 Person:2 Roadsign:0 ]
Source 0: Frame Number = 1439 Total objects = 8 [ Bicycle:0 Car:6 Person:2 Roadsign:0 ]
Source 0: Frame Number = 1440 Total objects = 9 [ Bicycle:0 Car:7 Person:2 Roadsign:0 ]
Source 0: Frame Number = 1441 Total objects = 9 [ Bicycle:0 Car:7 Person:2 Roadsign:0 ]
Source 0: Frame Number = 1442 Total objects = 0 [ Bicycle:0 Car:0 Person:0 Roadsign:0 ]
End of stream
Returned, stopping playback
Deleting pipeline
2024-07-27 00:18:40.191 INFO  gxf/gxe/gxe.cpp@182: Deinitializing...
2024-07-27 00:18:40.194 INFO  gxf/gxe/gxe.cpp@189: Closing log file...
2024-07-27 00:18:40.194 INFO  gxf/gxe/gxe.cpp@204: Destroying context
2024-07-27 00:18:40.196 INFO  gxf/gxe/gxe.cpp@211: Done.
End deepstream-test1.yaml
[INFO] Graph installation directory /tmp/ds.deepstream-test1 and manifest /tmp/ds.deepstream-test1/manifest.yaml retained
With a successful execution of the Graph Composer Application I proceeded to build the container.
sudo container_builder -c ds_test1_container_builder_jetson.yaml -d /opt/nvidia/graph-composer/config/target_aarch64.yaml
Container build Output:
ubuntu@nvidia-ds6-us1804:/opt/nvidia/deepstream/deepstream-6.0/reference_graphs/TEST2$ sudo container_builder -c ds_test1_container_builder_jetson.yaml -d /opt/nvidia/graph-composer/config/target_aarch64.yaml
[sudo] password for ubuntu:
2024-07-26 22:13:25,929 - ContainerBuilder.container_builder.docker_manager - INFO - base_image set in config file nvcr.io/nvidia/deepstream-l4t:6.0.1-base
2024-07-26 22:13:25,929 - ContainerBuilder.container_builder.docker_manager - INFO - start building stage image deepstream-test1-jetson_17072024:v1
2024-07-26 22:13:25,946 - ContainerBuilder.container_builder.docker_templ.docker_templ_maker - INFO - writing docker content to /home/ubuntu/.cache/container_builder/.dockerfile_19879
2024-07-26 22:13:25,946 - ContainerBuilder.container_builder.docker_manager - INFO - docker file /home/ubuntu/.cache/container_builder/.dockerfile_19879 generated
2024-07-26 22:13:25,947 - ContainerBuilder.container_builder.docker_manager - INFO - start preparing work folder: /home/ubuntu/.cache/container_builder/.workfolder_19879
2024-07-26 22:13:25,947 - ContainerBuilder.container_builder.docker_workfolder - INFO - copying local files to work folder
2024-07-26 22:13:25,958 - ContainerBuilder.container_builder.docker_workfolder - INFO - Work folder: /home/ubuntu/.cache/container_builder/.workfolder_19879/final_image is ready
2024-07-26 22:13:27,219 - Registry - INFO - Installing graph ...
2024-07-26 22:13:27,242 - Registry - INFO - Extension update found for extension: NvDsBaseExt
2024-07-26 22:13:27,242 - Registry - INFO - Old version: 0.0.3 New version: 0.0.4
2024-07-26 22:13:27,244 - Registry - INFO -
Requested target configuration:
  arch: aarch64 os: linux distribution: ubuntu_18.04 cuda: 10.2 cudnn: 8.0.3 tensorrt: 8.0.1.6 deepstream: 6.0 vpi: 1.1.12
Selected extension variants:
MultimediaExtension
  Version: 1.0.0 Variant: arch: aarch64 os: linux distribution: ubuntu_18.04
StandardExtension
  Version: 1.0.1 Variant: arch: aarch64 os: linux distribution: ubuntu_18.04 cuda: 10.2
NvDsInterfaceExt
  Version: 0.0.3 Variant: arch: aarch64 os: linux distribution: ubuntu_18.04 deepstream: 6.0
NvDsBaseExt
  Version: 0.0.4 Variant: arch: aarch64 os: linux distribution: ubuntu_18.04 deepstream: 6.0
NvDsSourceExt
  Version: 0.0.6 Variant: arch: aarch64 os: linux distribution: ubuntu_18.04 deepstream: 6.0
NvDsMuxDemuxExt
NvDsInferenceExt
NvDsSampleModelsExt
NvDsOutputSinkExt
  Version: 0.0.5 Variant: arch: aarch64 os: linux distribution: ubuntu_18.04 deepstream: 6.0
2024-07-26 22:14:11,762 - ContainerBuilder.container_builder.docker_manager - INFO - work folder: /home/ubuntu/.cache/container_builder/.workfolder_19879 is ready
2024-07-26 22:14:11,762 - ContainerBuilder.container_builder.docker_manager - INFO - start build docker file /home/ubuntu/.cache/container_builder/.dockerfile_19879
Step 1/11 : FROM  nvcr.io/nvidia/deepstream-l4t:6.0.1-base AS final_image
 ---> b7b630713447
Step 2/11 : ARG DEBIAN_FRONTEND=noninteractive
 ---> [Warning] The requested image's platform (linux/arm64) does not match the detected host platform (linux/amd64/v3) and no specific platform was requested
 ---> Running in d27a99a907c5
Removing intermediate container d27a99a907c5
 ---> 39f50d534c23
Step 3/11 : COPY ["final_image", "/"]
 ---> 12eaf46b0a21
Step 4/11 : RUN true
 ---> Running in 0b91e0998ad6
Removing intermediate container 0b91e0998ad6
 ---> 5245ab79f479
Step 5/11 : ENV PATH="/opt/nvidia/graph-composer/:$PATH"
 ---> Running in 8d724ff69631
Removing intermediate container 8d724ff69631
 ---> 702607305e0c
Step 6/11 : ENV LD_LIBRARY_PATH="/opt/nvidia/graph-composer/:$LD_LIBRARY_PATH"
 ---> Running in 07faf477f8d1
Removing intermediate container 07faf477f8d1
 ---> 42dc46e6cca9
Step 7/11 : WORKDIR /workspace/deepstream-test1/
 ---> Running in 0c1f30534fc6
Removing intermediate container 0c1f30534fc6
 ---> 0750bad5c82c
Step 8/11 : RUN apt install -y libpopt0
 ---> Running in 1534d26eb9a9
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following NEW packages will be installed:
  libpopt0
0 upgraded, 1 newly installed, 0 to remove and 10 not upgraded.
Need to get 22.8 kB of archives.
After this operation, 115 kB of additional disk space will be used.
Get:1 http://ports.ubuntu.com/ubuntu-ports bionic/main arm64 libpopt0 arm64 1.16-11 [22.8 kB]
Fetched 22.8 kB in 0s (116 kB/s)
debconf: delaying package configuration, since apt-utils is not installed
Selecting previously unselected package libpopt0:arm64.
(Reading database ... 38036 files and directories currently installed.)
Preparing to unpack .../libpopt0_1.16-11_arm64.deb ...
Unpacking libpopt0:arm64 (1.16-11) ...
Setting up libpopt0:arm64 (1.16-11) ...
Processing triggers for libc-bin (2.27-3ubuntu1.4) ...
Removing intermediate container 1534d26eb9a9
 ---> dcda65329f6d
Step 9/11 : RUN dpkg -i /tmp/rsync_3.1.0-2_arm64.deb
 ---> Running in 5bc58e0c82ad
Selecting previously unselected package rsync.
(Reading database ... 38042 files and directories currently installed.)
Preparing to unpack /tmp/rsync_3.1.0-2_arm64.deb ...
Unpacking rsync (3.1.0-2) ...
Setting up rsync (3.1.0-2) ...
invoke-rc.d: could not determine current runlevel
invoke-rc.d: policy-rc.d denied execution of restart.
Removing intermediate container 5bc58e0c82ad
 ---> 4a4aa186b73b
Step 10/11 : RUN apt install -y /tmp/graph_composer-1.0.0_arm64.deb && rm -rf /tmp/graph-composer-1.0.0_arm64.deb
 ---> Running in 8d92fa8721f1
Note, selecting 'graph-composer' instead of '/tmp/graph_composer-1.0.0_arm64.deb'
  graph-composer
0 upgraded, 1 newly installed, 0 to remove and 11 not upgraded.
Need to get 0 B/23.0 MB of archives.
After this operation, 406 MB of additional disk space will be used.
Get:1 /tmp/graph_composer-1.0.0_arm64.deb graph-composer arm64 1.0.0 [23.0 MB]
Selecting previously unselected package graph-composer.
(Reading database ... 38071 files and directories currently installed.)
Preparing to unpack .../graph_composer-1.0.0_arm64.deb ...
Unpacking graph-composer (1.0.0) ...
Setting up graph-composer (1.0.0) ...
update-alternatives: using /opt/nvidia/graph-composer/libgxf_core.so to provide /usr/lib/aarch64-linux-gnu/libgxf_core.so (gxf_core) in auto mode
update-alternatives: using /opt/nvidia/graph-composer/gxe to provide /usr/bin/gxe (gxe) in auto mode
update-alternatives: using /opt/nvidia/graph-composer/registry to provide /usr/bin/registry (registry) in auto mode
Removing intermediate container 8d92fa8721f1
 ---> 43437098a1a6
Step 11/11 : ENTRYPOINT [  "gxe",  "--manifest",  "deepstream-test1_manifest.yaml",  "--app",  "deepstream-test1.yaml,parameters.yaml"  ]
 ---> Running in 938c63a025f4
Removing intermediate container 938c63a025f4
 ---> c89fd09f6914
Successfully built c89fd09f6914
Successfully tagged deepstream-test1-jetson_17072024:v1
2024-07-26 22:14:44,230 - ContainerBuilder.container_builder.docker_builder - INFO - docker build image on file:/home/ubuntu/.cache/container_builder/.dockerfile_19879, successfully
2024-07-26 22:14:44,230 - ContainerBuilder.container_builder.docker_manager - INFO - build image deepstream-test1-jetson_17072024:v1 on dockerfile /home/ubuntu/.cache/container_builder/.dockerfile_19879 sucessfully
2024-07-26 22:14:44,230 - ContainerBuilder.container_builder.docker_manager - INFO - build final image deepstream-test1-jetson_17072024:v1 sucessfully
2024-07-26 22:14:44,230 - ContainerBuilder.container_builder.docker_manager - INFO - start pruning images
2024-07-26 22:14:44,237 - ContainerBuilder.container_builder.docker_manager - INFO - Container builder build config sucessfully
Than tagged the container
docker tag deepstream-test1-jetson_17072024:v1 xxyyzz.azurecr.io/deepstream-test1-jetson_17072024:v1
Pushed the container
docker push xxyyzz.azurecr.io/deepstream-test1-jetson_17072024:v1
unfortunatelly when I try to execute the container it fails
sudo docker run -it --rm --gpus all -v /tmp/.X11-unix/:/tmp/.X11-unix/ xxyyzz.azurecr.io/deepstream-test1-jetson_17072024:v1
Output:
nvidia@ubuntu:/opt/nvidia/deepstream/deepstream-6.0/reference_graphs/TEST2$ sudo docker run -it --rm --gpus all -v /tmp/.X11-unix/:/tmp/.X11-unix/ xxyyzz.azurecr.io/deepstream-test1-jetson_17072024:v1
Unable to find image 'xxyyzz.azurecr.io/deepstream-test1-jetson_17072024:v1' locally
v1: Pulling from deepstream-test1-jetson_17072024
f46992f278c2: Pull complete
d0ec296fcb76: Pull complete
9e18ddc8ca7a: Pull complete
457ba495c8e5: Pull complete
71bca45e35bd: Pull complete
644761cdc735: Pull complete
11628dbc31eb: Pull complete
d364c3700c33: Pull complete
01869d070b2e: Pull complete
cc3009375042: Pull complete
3e182d6364dc: Pull complete
f72feb4812f9: Pull complete
151eb940bbec: Pull complete
0e9dda2495b9: Pull complete
0e78bdc2f297: Pull complete
8dc68d594a4e: Pull complete
dcec34da2e7c: Pull complete
acae7215d8de: Pull complete
644cf9ff81e4: Pull complete
049e0a279055: Pull complete
8e9f2f36a229: Pull complete
49edaf70fd8a: Pull complete
d218a5a3f2fe: Pull complete
3ebdd498e4a1: Pull complete
e9acea715ff6: Pull complete
81db192c3dbe: Pull complete
Digest: sha256:cc7db8e192cd33c7d5a9a195a49ccf442d143fc73db4ad8916355181c849dbc6
Status: Downloaded newer image for atcloudlabjetsoncontainer.azurecr.io/deepstream-test1-jetson_17072024:v1
2024-07-26 22:41:14.408 INFO  gxf/gxe/gxe.cpp@98: Creating context
2024-07-26 22:41:14.463 INFO  gxf/gxe/gxe.cpp@85: Loading app: 'deepstream-test1.yaml'
2024-07-26 22:41:14.463 INFO  gxf/std/yaml_file_loader.cpp@59: Loading GXF entities from YAML file 'deepstream-test1.yaml'...
2024-07-26 22:41:14.474 INFO  gxf/gxe/gxe.cpp@85: Loading app: 'parameters.yaml'
2024-07-26 22:41:14.474 INFO  gxf/std/yaml_file_loader.cpp@59: Loading GXF entities from YAML file 'parameters.yaml'...
2024-07-26 22:41:14.475 INFO  gxf/gxe/gxe.cpp@153: Initializing...
(Argus) Error FileOperationFailed: Connecting to nvargus-daemon failed: No such file or directory (in src/rpc/socket/client/SocketClientDispatch.cpp, function openSocketConnection(), line 205)
(Argus) Error FileOperationFailed: Cannot create camera provider (in src/rpc/socket/client/SocketClientDispatch.cpp, function createCameraProvider(), line 106)
(gst-plugin-scanner:7): GStreamer-WARNING **: 22:41:16.700: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7): GStreamer-WARNING **: 22:41:17.106: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
2024-07-26 22:41:17.508 INFO  extensions/nvdsbase/nvds_scheduler.cpp@266: This program is linked against GStreamer 1.14.5
2024-07-26 22:41:17.509 INFO  extensions/nvdssource/nvurisrcbin.hpp@24: initialize: nvurisrcbin nv_ds_single_src_input3..c518
2024-07-26 22:41:17.510 INFO  extensions/nvdsmuxdemux/nvstreammux.hpp@27: initialize: nvstreammux nv_ds_stream_mux6..db00
2024-07-26 22:41:17.511 INFO  extensions/nvdsinference/nvinferbin.hpp@24: initialize: nvinferbin nv_ds_infer10..2748
2024-07-26 22:41:17.512 INFO  extensions/nvdsvisualization/nvosdbin.hpp@24: initialize: nvosdbin nv_ds_osd14..5978
2024-07-26 22:41:17.513 INFO  ./extensions/nvdsbase/tee.hpp@23: initialize: tee 1-to-N pipe fitting8
2024-07-26 22:41:17.514 INFO  extensions/nvdsoutputsink/nvvideoencfilesinkbin.hpp@23: initialize: nvvideoencfilesinkbin Video File Output12
2024-07-26 22:41:17.514 INFO  extensions/nvdsoutputsink/nvrtspoutsinkbin.hpp@23: initialize: nvrtspoutsinkbin nv_ds_rtsp_out14
2024-07-26 22:41:17.515 INFO  gxf/gxe/gxe.cpp@160: Running...
2024-07-26 22:41:17.515 INFO  extensions/nvdsbase/nvds_scheduler.cpp@117: Scheduling 7 elements and 1 components
2024-07-26 22:41:17.515 INFO  extensions/nvdssource/nvurisrcbin.hpp@32: create_element: nvurisrcbin nv_ds_single_src_input3..c518
2024-07-26 22:41:17.654 INFO  extensions/nvdssource/nvurisrcbin.hpp@56: bin_add: nvurisrcbin nv_ds_single_src_input3..c518
2024-07-26 22:41:17.654 INFO  extensions/nvdsmuxdemux/nvstreammux.hpp@37: create_element: nvstreammux nv_ds_stream_mux6..db00
2024-07-26 22:41:17.657 INFO  extensions/nvdsmuxdemux/nvstreammux.hpp@61: bin_add: nvstreammux nv_ds_stream_mux6..db00
2024-07-26 22:41:17.657 INFO  extensions/nvdsinference/nvinferbin.hpp@32: create_element: nvinferbin nv_ds_infer10..2748
2024-07-26 22:41:17.662 INFO  extensions/nvdsinference/nvinferbin.hpp@56: bin_add: nvinferbin nv_ds_infer10..2748
2024-07-26 22:41:17.664 INFO  extensions/nvdsvisualization/nvosdbin.hpp@32: create_element: nvosdbin nv_ds_osd14..5978
2024-07-26 22:41:17.669 INFO  extensions/nvdsvisualization/nvosdbin.hpp@56: bin_add: nvosdbin nv_ds_osd14..5978
2024-07-26 22:41:17.669 INFO  ./extensions/nvdsbase/tee.hpp@31: create_element: tee 1-to-N pipe fitting8
2024-07-26 22:41:17.670 INFO  ./extensions/nvdsbase/tee.hpp@55: bin_add: tee 1-to-N pipe fitting8
2024-07-26 22:41:17.670 INFO  extensions/nvdsoutputsink/nvvideoencfilesinkbin.hpp@31: create_element: nvvideoencfilesinkbin Video File Output12
2024-07-26 22:41:17.670 INFO  extensions/nvdsoutputsink/nvvideoencfilesinkbin.hpp@49: bin_add: nvvideoencfilesinkbin Video File Output12
2024-07-26 22:41:17.670 INFO  extensions/nvdsoutputsink/nvrtspoutsinkbin.hpp@31: create_element: nvrtspoutsinkbin nv_ds_rtsp_out14
2024-07-26 22:41:17.671 INFO  extensions/nvdsoutputsink/nvrtspoutsinkbin.hpp@55: bin_add: nvrtspoutsinkbin nv_ds_rtsp_out14
ERROR: Deserialize engine failed because file path: /workspace/deepstream-test1/909dc1ea-c654-44c1-97a3-0b8fec12141a/0.0.4/primary.resnet10.caffemodel_b1_gpu0_int8.engine open error
0:00:06.503938521     1   0x7f684e4460 WARN                 nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<nvinfer_bin_nvinfer> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1889> [UID = 1]: deserialize engine from file :/workspace/deepstream-test1/909dc1ea-c654-44c1-97a3-0b8fec12141a/0.0.4/primary.resnet10.caffemodel_b1_gpu0_int8.engine failed
0:00:06.505211571     1   0x7f684e4460 WARN                 nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<nvinfer_bin_nvinfer> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1996> [UID = 1]: deserialize backend context from engine from file :/workspace/deepstream-test1/909dc1ea-c654-44c1-97a3-0b8fec12141a/0.0.4/primary.resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:00:06.505261363     1   0x7f684e4460 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<nvinfer_bin_nvinfer> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
0:01:16.905342171     1   0x7f684e4460 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<nvinfer_bin_nvinfer> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1947> [UID = 1]: serialize cuda engine to file: /workspace/deepstream-test1/909dc1ea-c654-44c1-97a3-0b8fec12141a/0.0.4/primary.resnet10.caffemodel_b1_gpu0_fp16.engine successfully
0:01:17.166728466     1   0x7f684e4460 INFO                 nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<nvinfer_bin_nvinfer> [UID 1]: Load new model:/workspace/deepstream-test1/909dc1ea-c654-44c1-97a3-0b8fec12141a/0.0.4/config_infer_primary.txt sucessfully
2024-07-26 22:42:31.657 ERROR extensions/nvdsbase/nvds_scheduler.cpp@179: Failed to set GStreamer pipeline to PLAYING
Deleting pipeline
2024-07-26 22:42:31.670 INFO  gxf/gxe/gxe.cpp@182: Deinitializing...
2024-07-26 22:42:31.673 INFO  gxf/gxe/gxe.cpp@189: Closing log file...
2024-07-26 22:42:31.673 INFO  gxf/gxe/gxe.cpp@204: Destroying context
2024-07-26 22:42:31.676 INFO  gxf/gxe/gxe.cpp@211: Done.
really appreciate your help and input on this topic.
BR Maximilian
Can you upgrade to DeepStream 6.3 and Graph Composer 3.0.0?
Ahoi @Fiona.Chen
I don’t think that Deepstream 6.3 is supported on my Jetson Nano 4GB
https://docs.nvidia.com/metropolis/deepstream/6.3/dev-guide/text/DS_Quickstart.html#jetson-setup
For Jetson Nano 4GB Jetpack 4.6.5 is the latest suported version and Deepstream 6.3 requires JetPack 5.x
Or do you mean to upgrade my virtual machine that I use to build the container to deepstream 6.3?
Am I doing sth wrong to assume that when the graph composer application is running so should the container version?
BR Maximilian
Have you run the deepstream-test1 sample after you installed the Graph Composer and pull the extensions?
Ahoi @Fiona.Chen,
The deepstream-test1 application can be executed via:
this works as expected.
But when I try to run the same application as a build container via:
the execution fails and I don’t know why…
BR Maximilian
It is recommended to run the container in Jetson with the command like
docker run -it --rm --net=host --runtime nvidia  -e DISPLAY=$DISPLAY -w /workspace/deepstream-test1 -v /tmp/.X11-unix/:/tmp/.X11-unix deepstream-sample:v1
