Jetson
• DeepStream Version
6.0 GA on host, 5.1 on Jetson
4.5.1
• TensorRT Version
8
470
Bug
I’m following the tutorial here. When running sudo container_builder -c ds_test4_container_builder_jetson.yaml -d /opt/nvidia/graph-composer/config/target_aarch64.yaml
, I get the following error:
2021-11-11 11:38:06,737 - ContainerBuilder.container_builder.docker_manager - INFO - Auto selected base image: nvcr.io/nvidia/deepstream-l4t:6.0-samples
2021-11-11 11:38:06,737 - ContainerBuilder.container_builder.docker_manager - INFO - start building stage image deepstream-test4-jetson
2021-11-11 11:38:06,754 - ContainerBuilder.container_builder.docker_templ.docker_templ_maker - INFO - writing docker content to /root/.cache/container_builder/.dockerfile_6908
2021-11-11 11:38:06,754 - ContainerBuilder.container_builder.docker_manager - INFO - docker file /root/.cache/container_builder/.dockerfile_6908 generated
2021-11-11 11:38:06,754 - ContainerBuilder.container_builder.docker_manager - INFO - start preparing work folder: /root/.cache/container_builder/.workfolder_6908
2021-11-11 11:38:06,754 - ContainerBuilder.container_builder.docker_workfolder - INFO - copying local files to work folder
2021-11-11 11:38:06,765 - ContainerBuilder.container_builder.docker_workfolder - INFO - Work folder: /root/.cache/container_builder/.workfolder_6908/final_image is ready
File "container_builder/cli.py", line 13, in <module>
File "container_builder/container_builder.py", line 88, in main
File "container_builder/container_builder.py", line 47, in build
File "container_builder/docker_manager.py", line 457, in build_main_yaml
File "container_builder/docker_manager.py", line 514, in build_stage_image
File "container_builder/docker_workfolder.py", line 105, in prepare_all
File "container_builder/graph_handler.py", line 45, in __init__
File "container_builder/graph_handler.py", line 49, in init_registry
File "<frozen registry.core.core_interface>", line 28, in __init__
File "<frozen registry.core.core>", line 54, in __init__
File "<frozen registry.core.core>", line 1154, in _setup_logger
File "logging/handlers.py", line 150, in __init__
File "logging/handlers.py", line 57, in __init__
File "logging/__init__.py", line 1032, in __init__
File "logging/__init__.py", line 1061, in _open
PermissionError: [Errno 13] Permission denied: '/tmp/nvgraph_registry.log'
[6908] Failed to execute script cli
I can build the container using Graph Composer (Update: apparently the same issue can happen in Graph Composer as well). But deploying the container to Azure Edge device (Jetson Xavier NX) results in the following error:
2021-11-11 02:49:22.477 INFO gxf/gxe/gxe.cpp@98: Creating context
2021-11-11 02:49:22.483 ERROR gxf/std/extension_loader.cpp@109: libcudart.so.10.2: cannot open shared object file: No such file or directory
2021-11-11 02:49:22.486 ERROR gxf/gxe/gxe.cpp@143: LoadExtensionManifest Error: GXF_EXTENSION_FILE_NOT_FOUND
I’m thinking the error on Jetson is probably related to the container_builder error. What should I do to resolve this?
Thank you.
Update 1:
I found a workaround by deleting /tmp/nvgraph_registry.log
and /tmp/gxf_log
, and then running registry repo sync -n ngc-public
Now, running sudo container_builder -c ds_test4_container_builder_jetson.yaml -d /opt/nvidia/graph-composer/config/target_aarch64.yaml
produces the error below:
2021-11-12 09:44:15,042 - ContainerBuilder.container_builder.docker_manager - INFO - Auto selected base image: nvcr.io/nvidia/deepstream-l4t:6.0-samples
2021-11-12 09:44:15,042 - ContainerBuilder.container_builder.docker_manager - INFO - start building stage image deepstream-test4-jetson
2021-11-12 09:44:15,059 - ContainerBuilder.container_builder.docker_templ.docker_templ_maker - INFO - writing docker content to /root/.cache/container_builder/.dockerfile_64677
2021-11-12 09:44:15,059 - ContainerBuilder.container_builder.docker_manager - INFO - docker file /root/.cache/container_builder/.dockerfile_64677 generated
2021-11-12 09:44:15,060 - ContainerBuilder.container_builder.docker_manager - INFO - start preparing work folder: /root/.cache/container_builder/.workfolder_64677
2021-11-12 09:44:15,060 - ContainerBuilder.container_builder.docker_workfolder - INFO - copying local files to work folder
2021-11-12 09:44:15,071 - ContainerBuilder.container_builder.docker_workfolder - INFO - Work folder: /root/.cache/container_builder/.workfolder_64677/final_image is ready
2021-11-12 09:44:16,310 - Registry - INFO - Installing graph ...
2021-11-12 09:44:16,342 - Registry - INFO -
Requested target configuration:
arch: aarch64 os: linux distribution: ubuntu_18.04 cuda: 10.2 cudnn: 8.0.3 tensorrt: 8.0.1.6 deepstream: 6.0 vpi: 1.1.12
Selected extension variants:
MultimediaExtension
Version: 1.0.0 Variant: arch: aarch64 os: linux distribution: ubuntu_18.04
StandardExtension
Version: 1.0.1 Variant: arch: aarch64 os: linux distribution: ubuntu_18.04 cuda: 10.2
NvDsInterfaceExt
Version: 0.0.3 Variant: arch: aarch64 os: linux distribution: ubuntu_18.04 deepstream: 6.0
NvDsBaseExt
Version: 0.0.4 Variant: arch: aarch64 os: linux distribution: ubuntu_18.04 deepstream: 6.0
NvDsCloudMsgExt
NvDsInferenceExt
NvDsInferenceUtilsExt
Version: 0.0.5 Variant: arch: aarch64 os: linux distribution: ubuntu_18.04 deepstream: 6.0
NvDsSourceExt
Version: 0.0.6 Variant: arch: aarch64 os: linux distribution: ubuntu_18.04 deepstream: 6.0
NvDsMuxDemuxExt
NvDsOutputSinkExt
NvDsVisualizationExt
NvDsTemplateExt
NvDsSampleExt
NvDsSampleModelsExt
2021-11-12 09:45:08,407 - ContainerBuilder.container_builder.docker_manager - INFO - work folder: /root/.cache/container_builder/.workfolder_64677 is ready
2021-11-12 09:45:08,407 - ContainerBuilder.container_builder.docker_manager - INFO - start build docker file /root/.cache/container_builder/.dockerfile_64677
File "urllib3/connectionpool.py", line 601, in urlopen
File "urllib3/connectionpool.py", line 357, in _make_request
File "http/client.py", line 1281, in request
File "http/client.py", line 1327, in _send_request
File "http/client.py", line 1276, in endheaders
File "http/client.py", line 1042, in _send_output
File "http/client.py", line 980, in send
File "docker/transport/unixconn.py", line 30, in connect
FileNotFoundError: [Errno 2] No such file or directory
During handling of the above exception, another exception occurred:
File "requests/adapters.py", line 440, in send
File "urllib3/connectionpool.py", line 639, in urlopen
File "urllib3/util/retry.py", line 357, in increment
File "urllib3/packages/six.py", line 685, in reraise
urllib3.exceptions.ProtocolError: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
File "docker/api/client.py", line 214, in _retrieve_server_version
File "docker/api/daemon.py", line 181, in version
File "docker/utils/decorators.py", line 46, in inner
File "docker/api/client.py", line 237, in _get
File "requests/sessions.py", line 521, in get
File "requests/sessions.py", line 508, in request
File "requests/sessions.py", line 618, in send
File "requests/adapters.py", line 490, in send
requests.exceptions.ConnectionError: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
File "container_builder/docker_manager.py", line 528, in build_stage_image
File "container_builder/docker_builder.py", line 113, in build_from
File "container_builder/docker_builder.py", line 66, in _internal_build
File "container_builder/docker_builder.py", line 47, in _ensure_client
File "container_builder/docker_builder.py", line 37, in _create_client
File "docker/client.py", line 101, in from_env
File "docker/client.py", line 45, in __init__
File "docker/api/client.py", line 197, in __init__
File "docker/api/client.py", line 222, in _retrieve_server_version
docker.errors.DockerException: Error while fetching server API version: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
[64677] Failed to execute script cli
