• Hardware Platform (Jetson / GPU) Jetson Xavier
• DeepStream Version 6.1
• JetPack Version (valid for Jetson only) 35.1.0
• TensorRT Version 8.4.1.5
• Issue Type( questions, new requirements, bugs) Question
I am trying to run my python based Deepstream application on Jetson Xavier. I have followed the steps for Deepstream installation and the application is working fine on the host.
Now, when i try to dockerize and run the application using the below Dockerfile, I am getting errors. Details are below:
Dockerfile
FROM nvcr.io/nvidia/deepstream-l4t:6.1-samples
RUN apt update -y
RUN apt upgrade -y
RUN apt-get install -y python3-pip
# GStreamer Dependencies
RUN apt install -y libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev libgstreamer-plugins-bad1.0-dev \
gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly \
gstreamer1.0-libav gstreamer1.0-doc gstreamer1.0-tools gstreamer1.0-x gstreamer1.0-alsa gstreamer1.0-gl \
gstreamer1.0-gtk3 gstreamer1.0-qt5 gstreamer1.0-pulseaudio
RUN apt update && apt-get install -y libssl1.1 \
libgstreamer1.0-0 \
gstreamer1.0-tools \
gstreamer1.0-plugins-good \
gstreamer1.0-plugins-bad \
gstreamer1.0-libav \
libgstreamer-plugins-base1.0-dev \
libgstrtspserver-1.0-0 \
libjansson4 \
libyaml-cpp-dev
# Gst RTSP Server
RUN apt install -y libgstrtspserver-1.0-dev gstreamer1.0-rtsp
# Deepstream Dependencies
RUN apt install -y python3-gi python3-dev python3-gst-1.0 python-gi-dev git python-dev \
python3 python3-pip python3.8-dev cmake g++ build-essential libglib2.0-dev \
libglib2.0-dev-bin libgstreamer1.0-dev libtool m4 autoconf automake libgirepository1.0-dev libcairo2-dev
# Clone the Deepstream Python Apps Repo into <deepstream>/sources
WORKDIR /opt/nvidia/deepstream/deepstream/sources
RUN git clone https://github.com/NVIDIA-AI-IOT/deepstream_python_apps.git
# Download and install the Deepstream Python Bindings
RUN mkdir /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/build
WORKDIR /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/build
RUN curl -O -L https://github.com/NVIDIA-AI-IOT/deepstream_python_apps/releases/download/v1.1.3/pyds-1.1.3-py3-none-linux_aarch64.whl
RUN pip install ./pyds-1.1.3-py3-none-linux_aarch64.whl
RUN apt-get install -y libgstrtspserver-1.0-0 gstreamer1.0-rtsp libgirepository1.0-dev gobject-introspection gir1.2-gst-rtsp-server-1.0
RUN mkdir /model
WORKDIR /model
COPY requirements.txt .
RUN pip install -r requirements.txt
COPY . .
CMD [ "python3", "main.py" ]
Error
Creating Pipeline
Creating streamux
Creating source_bin 0
Creating source bin
source-bin-00
Creating Pgie
Creating tiler
Creating nvvidconv
Creating nvosd
Creating transform
Creating H264 Encoder
Creating H264 rtppay
Adding elements to Pipeline
Linking elements in the Pipeline
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8554/6d4e1564-b50d-4c9d-b245-d8f43c226792 ***
Now playing...
https://192.168.1.228:8000/videos/vac/vac-toll-6.mp4
Starting pipeline
Opening in BLOCKING MODE
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
gstnvtracker: Failed to open low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
dlopen error: /opt/nvidia/vpi2/lib64/priv/libcupva_host.so: undefined symbol: PvaQueueSubmit
gstnvtracker: Failed to initilaize low level lib.
Please let me know how do I resolve this issue.
