Deepstream 6.4 problem with gst registry cache
GPU, A6000, RTX2080 Ti, RTX8000
• DeepStream Version
6.4
• TensorRT Version
8.6.1
545.23.08
The second run of deepstream-test1 experiences a hang-up during the source creation phase.
  1. prepare user_deepstream_python_apps_install.sh which is located in nvcr.io/nvidia/deepstream:6.4-gc-triton-devel(/opt/nvidia/deepstream/deepstream/user_deepstream_python_apps_install.sh)
  2. run deepstream 6.4 container.
    $ docker run -it --rm --gpus all nvcr.io/nvidia/deepstream:6.4-samples-multiarch
  3. copy user_deepstream_python_apps_install.sh to the container
  4. install python requirements.
    $ bash user_deepstream_python_apps_install.sh --version 1.1.10
  5. run the sample app(deepstream-test1). It works.
$ cd /opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_python_apps/apps/deepstream-test1; python3 deepstream_test_1.py /opt/nvidia/deepstream/deepstream-6.4/samples/streams/sample_1080p_h264.mp4
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating EGLSink
Playing file /opt/nvidia/deepstream/deepstream-6.4/samples/streams/sample_1080p_h264.mp4
Adding elements to Pipeline
Linking elements in the Pipeline
/opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_python_apps/apps/deepstream-test1/deepstream_test_1.py:220: DeprecationWarning: Gst.Element.get_request_pad is deprecated
sinkpad = streammux.get_request_pad(“sink_0”)
Starting pipeline
(omitted…)
streaming stopped, reason not-negotiated (-4)
nvstreammux: Successfully handled EOS for source_id=0
(DONE)
  1. run the sample app again(deepstream-test1).
Creating Pipeline
Creating Source
(hang forever…)
I found two workarounds.
  • removing gst registry cache(~/.cache/gstreamer-1.0/registry.x86_64.bin)
  • disabling the registry with GST_REGISTRY_UPDATE=no
It was okay with the latest cpu(Intel 12th Gen).
It seems the older cpus(Intel 8th, 10th) cannot support some instructions used in deepstream 6.4
Could you use the deepstream:6.4-triton-multiarch docker and the latest python demo code? You’d better use a matching version between the demo code and DeepStream.
Thanks for reply.
I’ve tried your suggestion. but it didn’t work.
I use the deepstream:6.4-triton-multiarch docker.
1.$ cd /opt/nvidia/deepstream/deepstream
2.$ ./user_deepstream_python_apps_install.sh --build-bindings -r master
3.$ cd /opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_python_apps/apps/deepstream-test1
4. $python3 deepstream_test_1.py /opt/nvidia/deepstream/deepstream-6.4/samples/streams/sample_720p.h264
It works well. Are your steps the same as mine?
This seems to be the same issue as this (which I also experience): DeepStream 6.4 - Gst-nvstreammux Plugin Hangs Indefinitely
sorry, building bindings was failed with error.
-- Build files have been written to: /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/build
[  6%] Building CXX object CMakeFiles/pyds.dir/src/bindgstnvdsmeta.cpp.o
[ 12%] Building CXX object CMakeFiles/pyds.dir/src/utils.cpp.o
[ 18%] Building CXX object CMakeFiles/pyds.dir/src/pyds.cpp.o
[ 25%] Building CXX object CMakeFiles/pyds.dir/src/bindmeta360.cpp.o
[ 31%] Building CXX object CMakeFiles/pyds.dir/src/bindfunctions.cpp.o
[ 37%] Building CXX object CMakeFiles/pyds.dir/src/bindanalyticsmeta.cpp.o
[ 43%] Building CXX object CMakeFiles/pyds.dir/src/bindnvbufsurface.cpp.o
[ 56%] Building CXX object CMakeFiles/pyds.dir/src/bindnvosd.cpp.o
[ 56%] Building CXX object CMakeFiles/pyds.dir/src/bindnvdsinfer.cpp.o
[ 62%] Building CXX object CMakeFiles/pyds.dir/src/bindnvdsmeta.cpp.o
[ 75%] Building CXX object CMakeFiles/pyds.dir/src/bindschema.cpp.o
[ 75%] Building CXX object CMakeFiles/pyds.dir/src/bindtrackermeta.cpp.o
[ 81%] Building CXX object CMakeFiles/pyds.dir/src/bindopticalflow.cpp.o
[ 87%] Building CXX object CMakeFiles/pyds.dir/src/custom_binding/bindcustom.cpp.o
In file included from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/utils.cpp:26:
/opt/nvidia/deepstream/deepstream/sources/includes/gstnvdsmeta.h:43:10: fatal error: gst/video/video.h: No such file or directory
   43 | #include <gst/video/video.h>
compilation terminated.
make[2]: *** [CMakeFiles/pyds.dir/build.make:90: CMakeFiles/pyds.dir/src/utils.cpp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
In file included from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/pyds.hpp:29,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/bind/bindmeta360.hpp:22,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindmeta360.cpp:20:
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/bind/bindnvbufsurface.hpp:22,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvbufsurface.cpp:20:
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/bind/bindnvdsinfer.hpp:22,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvdsinfer.cpp:20:
make[2]: *** [CMakeFiles/pyds.dir/build.make:146: CMakeFiles/pyds.dir/src/bindmeta360.cpp.o] Error 1
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/bind/bindanalyticsmeta.hpp:23,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/pyds.cpp:19:
make[2]: *** [CMakeFiles/pyds.dir/build.make:160: CMakeFiles/pyds.dir/src/bindnvbufsurface.cpp.o] Error 1
make[2]: *** [CMakeFiles/pyds.dir/build.make:174: CMakeFiles/pyds.dir/src/bindnvdsinfer.cpp.o] Error 1
make[2]: *** [CMakeFiles/pyds.dir/build.make:76: CMakeFiles/pyds.dir/src/pyds.cpp.o] Error 1
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindanalyticsmeta.cpp:21:
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/custom_binding/include/bindcustom.hpp:20,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/custom_binding/bindcustom.cpp:21:
In file included from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/utils.hpp:30,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvosd.cpp:21:
make[2]: *** [CMakeFiles/pyds.dir/build.make:104: CMakeFiles/pyds.dir/src/bindanalyticsmeta.cpp.o] Error 1
make[2]: *** [CMakeFiles/pyds.dir/build.make:258: CMakeFiles/pyds.dir/src/custom_binding/bindcustom.cpp.o] Error 1
make[2]: *** [CMakeFiles/pyds.dir/build.make:202: CMakeFiles/pyds.dir/src/bindnvosd.cpp.o] Error 1
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/bind/bindfunctions.hpp:26,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindfunctions.cpp:19:
make[2]: *** [CMakeFiles/pyds.dir/build.make:118: CMakeFiles/pyds.dir/src/bindfunctions.cpp.o] Error 1
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/bind/bindopticalflow.hpp:22,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindopticalflow.cpp:21:
make[2]: *** [CMakeFiles/pyds.dir/build.make:216: CMakeFiles/pyds.dir/src/bindopticalflow.cpp.o] Error 1
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/bind/bindtrackermeta.hpp:22,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindtrackermeta.cpp:21:
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/bind/bindschema.hpp:23,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindschema.cpp:21:
make[2]: *** [CMakeFiles/pyds.dir/build.make:244: CMakeFiles/pyds.dir/src/bindtrackermeta.cpp.o] Error 1
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/bind/bindnvdsmeta.hpp:22,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvdsmeta.cpp:21:
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/include/bind/bindgstnvdsmeta.hpp:20,
                 from /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindgstnvdsmeta.cpp:21:
make[2]: *** [CMakeFiles/pyds.dir/build.make:230: CMakeFiles/pyds.dir/src/bindschema.cpp.o] Error 1
make[2]: *** [CMakeFiles/pyds.dir/build.make:188: CMakeFiles/pyds.dir/src/bindnvdsmeta.cpp.o] Error 1
make[2]: *** [CMakeFiles/pyds.dir/build.make:132: CMakeFiles/pyds.dir/src/bindgstnvdsmeta.cpp.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:85: CMakeFiles/pyds.dir/all] Error 2
make: *** [Makefile:91: all] Error 2
Installing built PyDS wheel
WARNING: Requirement './pyds-1*_x86_64.whl' looks like a filename, but the file does not exist
ERROR: pyds-1*_x86_64.whl is not a valid wheel filename.
OK. You can just install the whl yourself. Also if you use the deepstream-test1, please use a h264 stream as the source.
I could build pyds bindings with your command.
installing to build/bdist.linux-x86_64/wheel
running install
running install_lib
creating build/bdist.linux-x86_64
creating build/bdist.linux-x86_64/wheel
copying build/lib/pyds.so -> build/bdist.linux-x86_64/wheel
running install_egg_info
running egg_info
creating pyds.egg-info
writing pyds.egg-info/PKG-INFO
writing dependency_links to pyds.egg-info/dependency_links.txt
writing requirements to pyds.egg-info/requires.txt
writing top-level names to pyds.egg-info/top_level.txt
writing manifest file 'pyds.egg-info/SOURCES.txt'
reading manifest file 'pyds.egg-info/SOURCES.txt'
Copying pyds.egg-info to build/bdist.linux-x86_64/wheel/pyds-1.1.10-py3.10.egg-info
running install_scripts
creating build/bdist.linux-x86_64/wheel/pyds-1.1.10.dist-info/WHEEL
creating 'dist/pyds-1.1.10-py3-none-linux_x86_64.whl' and adding 'build/bdist.linux-x86_64/wheel' to it
adding 'pyds.so'
adding 'pyds-1.1.10.dist-info/METADATA'
adding 'pyds-1.1.10.dist-info/WHEEL'
adding 'pyds-1.1.10.dist-info/top_level.txt'
adding 'pyds-1.1.10.dist-info/RECORD'
removing build/bdist.linux-x86_64/wheel
make[2]: Leaving directory '/opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_python_apps/bindings/build'
[100%] Built target pip_wheel
make[1]: Leaving directory '/opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_python_apps/bindings/build'
Processing ./pyds-1.1.10-py3-none-linux_x86_64.whl
Requirement already satisfied: pgi in /usr/local/lib/python3.10/dist-packages (from pyds==1.1.10) (0.0.11.2)
Requirement already satisfied: PyGObject in /usr/local/lib/python3.10/dist-packages (from pyds==1.1.10) (3.46.0)
Requirement already satisfied: pycairo>=1.16.0 in /usr/local/lib/python3.10/dist-packages (from PyGObject->pyds==1.1.10) (1.25.1)
Installing collected packages: pyds
Successfully installed pyds-1.1.10
however it doesn’t help with same output(hang).
What is your OS Host?
I did two tests:
RTX 4090 (with docker ds-6.4) - OS Host Ubuntu 20.04.6 LTS (Failed)
NVIDIA L4 (with docker ds-6.4) - OS Host Ubuntu 22.04.3 LTS (Works)
Maybe pyds 1.1.10 have some issue on Host Ubuntu 20.04.6 LTS.
Hi @bongkyung.ko Have you changed your source in your pipeline?
python3 deepstream_test_1.py \
Deepstream_test_1 only supports the h264 stream, not the mp4 stream.
That could be it. I’m all the way back on Ubuntu 18.04.6 LTS.
yes I did.
It was ubuntu 20.04
After upgrade to 22.04, the issue still persists. I was confused sorry.
It worked!
deepstream 6.4 image requires ubuntu 22.04 on host system.
Confirmed. There is an incompatibility when using a Ubuntu Docker image with a version lower than that of the physical host.
