Can not run deepstream_test_1.py?
• DeepStream Version
• TensorRT Version
hi i already install deepstream and python binding and every thing i need from this 2 page:
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_Installation.html#dgpu-setup-for-ubuntu
and i want to run deepstream_test_1.py but i’ve gotten this error :
gst_buffer_get_nvds_batch_meta return None
what should i do now? i will be hapy if you help me
Can the native deepstream-test1-app work normally ?
cd /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-test1/
make CUDA_VER=12.2
./deepstream-test1-app /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264
If OK, There should be some problems with the installation of python bindings.
If not, DS-SDK is not installed correctly.
Docker is recommned for avoid the complex steps of installation.
if i comment add_probe for sink of nvosd(nvdswosd) it will run correctly but i have 3 questations:
1 – i do somthing in installation step !! i convert every /opt/nvidia/deepstream/deepstream to /opt/nvidia/deepstream/deepstream-7.0 for libkafka and deepstrema_app_binding and everywhere that exist in pages that i sent ! i wanna know that
is there any problem with it ??
2 – in 1 page said gst-python have to be version 1.20.3 but in another page that i sent 2 days ago .it use gst-python that exist in 3rdparty/gstreamer/subprojects/gst-python/ ! so which one should i install ?
3 --why don’t we use sudo make install in Compiling the bindings step ? should i do it myself?
I think there is no problem with it. /opt/nvidia/deepstream/deepstream/ just a soft link to /opt/nvidia/deepstream/deepstream-7.0, You can check it with ls -l /opt/nvidia/deepstream/
This is not a conflict, just follow the steps in the README
Because the compiled output is *. whl, It’s a Python package. No need to use make install, just pip install *.whl
pip3 install ./pyds-1.1.11-py3-none*.whl
Thanks a lot you help me alot in this ticket!! 🙏🙏but did you mean this readme file by saying README?
And another question that i forgot to ask about that is : i install nvidia driver from sudo apt install nvidia-driver-535 instead of .deb file that you mentioned in deepstream installation guide is there any problem with it?(i have t4)
Yes,These steps in the document have been tested.
Or use docker to avoid complicated installtion steps.
Generally it is fine, if you have any problem, please try this link
