RTX3060
• DeepStream Version
nvcr.io/nvidia/deepstream:6.1-triton
• TensorRT Version
510
• How to reproduce the issue ? (This
Dockerfile (1.1 KB)
run.sh (257 Bytes)
is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
I’ve created a docker image to add python bindings to DS6.x. The Dockerfile is attached.
I’m able to run apps/deepstream_test_1.py and observe the display.
When I try to profile the application using nsys I get unexpected “End of file”
root@dsp-video-c4:/opt/nvidia/deepstream/deepstream-6.1/sources/deepstream_python_apps/apps/deepstream-test1# nsys profile -o log_test1 python3 deepstream_test_1.py /opt/nvidia/deepstream/deepstream-6.1/samples/streams/sample_qHD.h264
End of file
If I delay sampling by adding “-y 1” the application runs but no log is generated:
root@dsp-video-c4:/opt/nvidia/deepstream/deepstream-6.1/sources/deepstream_python_apps/apps/deepstream-test1# nsys profile -o log_test1 -y 1 python3 deepstream_test_1.py /opt/nvidia/deepstream/deepstream-6.1/samples/streams/sample_qHD.h264
Frame Number=1799 Number of Objects=11 Vehicle_count=10 Person_count=0
Frame Number=1800 Number of Objects=10 Vehicle_count=9 Person_count=0
Frame Number=1801 Number of Objects=10 Vehicle_count=9 Person_count=0
End-of-stream
Now it just hangs, the application does not end, and no stream recording is generated. If I hit ctrl+c I get “The proxy is not started”.
How can I profile deepstream app using nsys?
I’ve also tried
root@dsp-video-c4:/opt/nvidia/deepstream/deepstream-6.1/sources/deepstream_python_apps/apps/deepstream-test1# nsys launch -w false python3 deepstream_test_1.py /opt/nvidia/deepstream/deepstream-6.1/samples/streams/sample_qHD.h264 &
[1] 442
#The application window is now displayed
6.1/sources/deepstream_python_apps/apps/deepstream-test1# nsys status
application launched. use the 'start' command to start collecting data
root@dsp-video-c4:/opt/nvidia/deepstream/deepstream-6.1/sources/deepstream_python_apps/apps/deepstream-test1# nsys start
End of file
We will try nsys with python to reproduce this issue
@Fiona.Chen ,
I’m not claiming there is a “general” problem with nsys and python.
I tested a few PyTorch tutorials (like EfficientNet-B0) with nsys and it worked fine straight away.
Deepstream is an example of an application that I couldn’t profile straight away with nsys.
I’ve tried with DeepStream 6.1.1 GA and Nsight 2022.3.4, no error.
WARNING: CPU context switch tracing not supported, disabling.
Try the ‘nsys status --environment’ command to learn more.
WARNING: CPU sampling not supported, disabling.
0:00:00.863863710 10906 0x2ba7960 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1170> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
0:00:03.877284701 10906 0x2ba7960 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1909> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.1/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:03.969471154 10906 0x2ba7960 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.1/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
0:00:03.972193636 10906 0x2ba7960 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus: [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating EGLSink
Playing file /opt/nvidia/deepstream/deepstream-6.1/samples/streams/sample_qHD.h264
Adding elements to Pipeline
Linking elements in the Pipeline
Starting pipeline
Frame Number=0 Number of Objects=6 Vehicle_count=4 Person_count=1
Frame Number=1 Number of Objects=6 Vehicle_count=4 Person_count=1
Frame Number=2 Number of Objects=6 Vehicle_count=4 Person_count=1
Frame Number=3 Number of Objects=6 Vehicle_count=4 Person_count=1
Frame Number=4 Number of Objects=6 Vehicle_count=4 Person_count=1
Frame Number=5 Number of Objects=6 Vehicle_count=4 Person_count=1
Frame Number=6 Number of Objects=6 Vehicle_count=4 Person_count=1
Frame Number=7 Number of Objects=6 Vehicle_count=5 Person_count=1
Frame Number=8 Number of Objects=8 Vehicle_count=7 Person_count=1
End-of-stream
Generating ‘/tmp/nsys-report-a23f.qdstrm’
Failed to create ‘/opt/nvidia/deepstream/deepstream-6.1/sources/deepstream_python_apps/apps/deepstream-test1/log_test1.nsys-rep’: File exists.
Use --force-overwrite true to overwrite existing files.
[1/1] [========================100%] nsys-report-40b5.nsys-rep
Generated:
/tmp/nsys-report-40b5.nsys-rep
Thanks,
Are you using a Deepstream docker? Did you try with the Dockerfile I’ve attached to this thread?
I tried with the Nvidia deepstream docker. DeepStream | NVIDIA NGC
Thanks @Fiona.Chen,
When upgrading the docker’s Nsight 2022.3.4 recording works.
