Deepstream 7.0 object detection issue (Only class_id = 0) is getting detected, other classes are being ignored
• Hardware Platform (Jetson / GPU) = GPU – Tesla V100 PCIe 16GB
• DeepStream Version = 7.0.0
• JetPack Version (valid for Jetson only = N/A (GPU platform)
• TensorRT Version = 8.6
• NVIDIA GPU Driver Version (valid for GPU only) = 535.161.08
**• Issue Type( questions, new requirements, bugs) = bugs
config file = [application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-color-format=0
onnx-file=/opt/nvidia/deepstream/deepstream-7.0/sources/deepstream_python_apps/apps/aiis-deepstream-pipeline/modelss/vehicledetection3.onnx
#model-engine-file=/opt/nvidia/deepstream/deepstream-7.0/sources/deepstream_python_apps/apps/aiis-deepstream-pipeline/modelss/vehicledetection3.engine
labelfile-path=/opt/nvidia/deepstream/deepstream-7.0/sources/deepstream_python_apps/apps/aiis-deepstream-pipeline/modelss/vd_labels.txt
batch-size=1 # Increased for better GPU utilization
network-mode=0 # FP16
num-detected-classes=5
interval=0
output-blob-names=detections
gie-unique-id=1
process-mode=1
network-type=0
cluster-mode=2
maintain-aspect-ratio=1
symmetric-padding=1
parse-bbox-func-name=NvDsInferParseYolo
custom-lib-path=/opt/nvidia/deepstream/deepstream-7.0/sources/deepstream_python_apps/apps/aiis-deepstream-pipeline/nvdsinfer_custom_impl_Yolo/libnvdsinfer_custom_impl_Yolo.so
engine-create-func-name=NvDsInferYoloCudaEngineGet
[class-attrs-all]
nms-iou-threshold=0.2
pre-cluster-threshold=0.15
topk=1500
import sys
sys.path.append(“../”)
from common.bus_call import bus_call
from common.platform_info import PlatformInfo
from common.FPS import PERF_DATA
import pyds
import platform
import math
import time
import os
from ctypes import *
import gi
gi.require_version(“Gst”, “1.0”)
gi.require_version(“GstRtspServer”, “1.0”)
from gi.repository import Gst, GstRtspServer, GLib, GObject
import configparser
import datetime
import argparse
import threading
no_display = False
silent = False
file_loop = False
perf_data = None
MAX_DISPLAY_LEN = 64
PGIE_CLASS_ID_PERSON = 0
PGIE_CLASS_ID_BICYCLE = 1
PGIE_CLASS_ID_CAR = 2
PGIE_CLASS_ID_MOTORCYCLE = 3
PGIE_CLASS_ID_BUS = 5
MUXER_OUTPUT_WIDTH = 1920
MUXER_OUTPUT_HEIGHT = 1080
MUXER_BATCH_TIMEOUT_USEC = 33000
TILED_OUTPUT_WIDTH = 1280
TILED_OUTPUT_HEIGHT = 720
GST_CAPS_FEATURES_NVMM = “memory:NVMM”
OSD_PROCESS_MODE = 0
OSD_DISPLAY_TEXT = 0
pgie_classes_str = [“Person”,“Bicycle”, “Car”, “Motorcycle”, “Bus”]
myclient = pymongo.MongoClient(“mongodb://192.1.81.54:27017/”)
mydb = myclient[“smart_security_”]
def osd_sink_pad_buffer_probe(pad, info, u_data):
frame_number=0
num_rects=0
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
# Retrieve batch metadata from the gst_buffer
# Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
# C address of gst_buffer as input, which is obtained with hash(gst_buffer)
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
# Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
# The casting is done by pyds.NvDsFrameMeta.cast()
# The casting also keeps ownership of the underlying memory
# in the C code, so the Python garbage collector will leave
# it alone.
print("frame_meta",frame_meta)
except StopIteration:
break
# Initialize object counter with 0 for our target classes
obj_counter = {
PGIE_CLASS_ID_PERSON: 0,
PGIE_CLASS_ID_BICYCLE: 0,
PGIE_CLASS_ID_CAR: 0,
PGIE_CLASS_ID_MOTORCYCLE: 0,
PGIE_CLASS_ID_BUS: 0
frame_number=frame_meta.frame_num
num_rects = frame_meta.num_obj_meta
l_obj=frame_meta.obj_meta_list
while l_obj is not None:
try:
# Casting l_obj.data to pyds.NvDsObjectMeta
obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
break
obj_counter[obj_meta.class_id] += 1
obj_meta.rect_params.border_color.set(0.0, 0.0, 1.0, 0.8) #0.8 is alpha (opacity)
try:
l_obj=l_obj.next
break
# Acquiring a display meta object. The memory ownership remains in
# the C code so downstream plugins can still access it. Otherwise
# the garbage collector will claim it when this probe function exits.
display_meta=pyds.nvds_acquire_display_meta_from_pool(batch_meta)
display_meta.num_labels = 1
py_nvosd_text_params = display_meta.text_params[0]
# Setting display text to be shown on screen
# Note that the pyds module allocates a buffer for the string, and the
# memory will not be claimed by the garbage collector.
# Reading the display_text field here will return the C address of the
# allocated string. Use pyds.get_string() to get the string content.
py_nvosd_text_params.display_text = "Frame Number={} Number of Objects={} Vehicle_count={} Person_count={}".format(frame_number, num_rects, obj_counter[PGIE_CLASS_ID_CAR], obj_counter[PGIE_CLASS_ID_PERSON])
# Now set the offsets where the string should appear
py_nvosd_text_params.x_offset = 10
py_nvosd_text_params.y_offset = 12
# Font , font-color and font-size
py_nvosd_text_params.font_params.font_name = "Serif"
py_nvosd_text_params.font_params.font_size = 10
# set(red, green, blue, alpha); set to White
py_nvosd_text_params.font_params.font_color.set(1.0, 1.0, 1.0, 1.0)
# Text background color
py_nvosd_text_params.set_bg_clr = 1
# set(red, green, blue, alpha); set to Black
py_nvosd_text_params.text_bg_clr.set(0.0, 0.0, 0.0, 1.0)
# Using pyds.get_string() to get display_text as string
print(pyds.get_string(py_nvosd_text_params.display_text))
pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
try:
l_frame=l_frame.next
break
return Gst.PadProbeReturn.OK
def pgie_src_pad_buffer_probe(pad, info, u_data):
frame_number = 0
if not gst_buffer:
print(“Unable to get GstBuffer”)
# Get batch metadata
# Debug: Print all detected classes
detected_classes = set()
try:
break
frame_number = frame_meta.frame_num
l_obj = frame_meta.obj_meta_list
# Initialize object counters
obj_counter = {
PGIE_CLASS_ID_BUS: 0,
total_relevant_objects = 0
try:
obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
detected_classes.add(obj_meta.class_id)
print("detected classes",obj_meta.class_id)
# Debug print for ALL detections
print(f"[RAW] Frame {frame_number}: {obj_meta.obj_label} (ID:{obj_meta.class_id}) Conf:{obj_meta.confidence:.2f}")
# Filter for target classes
if obj_meta.class_id in obj_counter:
total_relevant_objects += 1
# Enhanced debug for vehicles
print(f"[VEHICLE] Frame {frame_number}: {obj_meta.obj_label} "
f"at ({obj_meta.rect_params.left:.0f},{obj_meta.rect_params.top:.0f}) "
f"Size:{obj_meta.rect_params.width:.0f}x{obj_meta.rect_params.height:.0f} "
f"Conf:{obj_meta.confidence:.2f}")
except Exception as e:
print(f"Error processing obj_meta: {str(e)}")
break
try:
l_obj = l_obj.next
break
# Frame summary with improved formatting
print("\n" + "="*50)
print(f"Frame {frame_number} Vehicle Report:")
print(f" Persons: {obj_counter[PGIE_CLASS_ID_PERSON]}")
print(f" Bicycles: {obj_counter[PGIE_CLASS_ID_BICYCLE]}")
print(f" Cars: {obj_counter[PGIE_CLASS_ID_CAR]}")
print(f" Motorcycles: {obj_counter[PGIE_CLASS_ID_MOTORCYCLE]}")
print(f" Buses: {obj_counter[PGIE_CLASS_ID_BUS]}")
print("="*50 + "\n")
# Performance monitoring (fixed typo in pad_index)
stream_index = f"stream{frame_meta.pad_index}"
if perf_data is not None:
perf_data.update_fps(stream_index)
try:
l_frame = l_frame.next
break
# Debug: Print all unique classes detected in this batch
if detected_classes:
print(f"\nAll detected class IDs in this batch: {sorted(detected_classes)}")
def cb_newpad(decodebin, decoder_src_pad, data):
The function is called when a new pad is created by the decodebin.
The function checks if the new pad is for video and not audio.
If the new pad is for video, the function checks if the pad caps contain NVMM memory features.
If the pad caps contain NVMM memory features, the function links the decodebin pad to the source bin
ghost pad.
If the pad caps do not contain NVMM memory features, the function prints an error message.
:param decodebin: The decodebin element that is creating the new pad
:param decoder_src_pad: The source pad created by the decodebin element
:param data: This is the data that was passed to the callback function. In this case, it is the
source_bin
print(“In cb_newpad\n”)
caps = decoder_src_pad.get_current_caps()
gststruct = caps.get_structure(0)
gstname = gststruct.get_name()
source_bin = data
features = caps.get_features(0)
# Need to check if the pad created by the decodebin is for video and not
# audio.
print("gstname=", gstname)
if gstname.find("video") != -1:
# Link the decodebin pad only if decodebin has picked nvidia
# decoder plugin nvdec_*. We do this by checking if the pad caps contain
# NVMM memory features.
print("features=", features)
if features.contains("memory:NVMM"):
# Get the source bin ghost pad
bin_ghost_pad = source_bin.get_static_pad("src")
if not bin_ghost_pad.set_target(decoder_src_pad):
sys.stderr.write(
"Failed to link decoder src pad to source bin ghost pad\n"
else:
sys.stderr.write(" Error: Decodebin did not pick nvidia decoder plugin.\n")
def decodebin_child_added(child_proxy, Object, name, user_data):
If the child added to the decodebin is another decodebin, connect to its child-added signal. If the
child added is a source, set its drop-on-latency property to True.
:param child_proxy: The child element that was added to the decodebin
:param Object: The object that emitted the signal
:param name: The name of the element that was added
:param user_data: This is a pointer to the data that you want to pass to the callback function
print("Decodebin child added:", name, "\n")
if name.find("decodebin") != -1:
Object.connect("child-added", decodebin_child_added, user_data)
if "source" in name:
source_element = child_proxy.get_by_name("source")
if source_element.find_property("drop-on-latency") != None:
Object.set_property("drop-on-latency", True)
def create_source_bin(index, uri):
It creates a GstBin, adds a uridecodebin to it, and connects the uridecodebin’s pad-added signal to
a callback function
:param index: The index of the source bin
:param uri: The URI of the video file to be played
:return: A bin with a uri decode bin and a ghost pad.
print("Creating source bin")
# Create a source GstBin to abstract this bin's content from the rest of the
# pipeline
bin_name = "source-bin-%02d" % index
print(bin_name)
nbin = Gst.Bin.new(bin_name)
if not nbin:
sys.stderr.write(" Unable to create source bin \n")
# Source element for reading from the uri.
# We will use decodebin and let it figure out the container format of the
# stream and the codec and plug the appropriate demux and decode plugins.
uri_decode_bin = Gst.ElementFactory.make("uridecodebin", "uri-decode-bin")
if not uri_decode_bin:
sys.stderr.write(" Unable to create uri decode bin \n")
# We set the input uri to the source element
uri_decode_bin.set_property("uri", uri)
# Connect to the "pad-added" signal of the decodebin which generates a
# callback once a new pad for raw data has beed created by the decodebin
uri_decode_bin.connect("pad-added", cb_newpad, nbin)
uri_decode_bin.connect("child-added", decodebin_child_added, nbin)
# We need to create a ghost pad for the source bin which will act as a proxy
# for the video decoder src pad. The ghost pad will not have a target right
# now. Once the decode bin creates the video decoder and generates the
# cb_newpad callback, we will set the ghost pad target to the video decoder
# src pad.
Gst.Bin.add(nbin, uri_decode_bin)
bin_pad = nbin.add_pad(Gst.GhostPad.new_no_target("src", Gst.PadDirection.SRC))
if not bin_pad:
sys.stderr.write(" Failed to add ghost pad in source bin \n")
return None
return nbin
def make_element(element_name, i):
Creates a Gstreamer element with unique name
Unique name is created by adding element type and index e.g. element_name-i
Unique name is essential for all the element in pipeline otherwise gstreamer will throw exception.
:param element_name: The name of the element to create
:param i: the index of the element in the pipeline
:return: A Gst.Element object
element = Gst.ElementFactory.make(element_name, element_name)
if not element:
sys.stderr.write(" Unable to create {0}".format(element_name))
element.set_property(“name”, “{0}-{1}”.format(element_name, str(i)))
return element
def setup_rtsp_server(rtsp_port_num):
server = GstRtspServer.RTSPServer.new()
server.props.service = f"{rtsp_port_num}"
server.attach(None)
return server
def create_rtsp_out(rtsp_server, udp_port, stream_path):
vcodec=“H264”
# server = GstRtspServer.RTSPServer.new()
# server.props.service = “%d” % rtsp_port_num
# server.attach(None)
factory = GstRtspServer.RTSPMediaFactory.new()
factory.set_launch(
‘( udpsrc name=pay0 port=%d buffer-size=524288 caps="application/x-rtp, media=video, clock-rate=90000, encoding-name=(string)%s, payload=96 " )’
% (udp_port, vcodec)
print(f"UDP PORT for {stream_path}: {udp_port}“)
factory.set_shared(True)
rtsp_server.get_mount_points().add_factory(stream_path, factory)
print(f”\n *** DeepStream: Launched RTSP Streaming at rtsp://localhost:8555{stream_path} ***\n")
def main(args):
number_sources = len(args)
print(f"{number_sources = }")
global perf_data
perf_data = PERF_DATA(number_sources)
rtsp_port = 8555
udp_port = 5400
codec = “H264”
bitrate = 4000000
stream_udpport_mapping = {}
# Standard GStreamer initialization
Gst.init(None)
# Create gstreamer elements */
# Create Pipeline element that will form a connection of other elements
print("Creating Pipeline \n ")
pipeline = Gst.Pipeline()
is_live = False
if not pipeline:
sys.stderr.write(" Unable to create Pipeline \n")
print("Creating streamux \n ")
# Create nvstreammux instance to form batches from one or more sources.
streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
if not streammux:
sys.stderr.write(" Unable to create NvStreamMux \n")
pipeline.add(streammux)
for i in range(number_sources):
print("Creating source_bin ", i, " \n ")
uri_name = args[i]
if uri_name.find("rtsp://") == 0:
is_live = True
source_bin = create_source_bin(i, uri_name)
if not source_bin:
sys.stderr.write("Unable to create source bin \n")
pipeline.add(source_bin)
padname = f"sink_{i}"
sinkpad = streammux.request_pad_simple(padname)
print("padname {}".format(padname))
if not sinkpad:
sys.stderr.write("Unable to create sink pad bin \n")
srcpad = source_bin.get_static_pad("src")
if not srcpad:
sys.stderr.write("Unable to create src pad bin \n")
print(f"Linking source_bin[{i}] src pad to streammux sink_{i} pad.")
srcpad.link(sinkpad)
print("Creating queue1 \n ")
queue1 = Gst.ElementFactory.make("queue", "queue1")
pipeline.add(queue1)
print("Creating Pgie \n ")
pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
if not pgie:
sys.stderr.write(" Unable to create pgie \n")
print("Creating nvstreamdemux \n ")
nvstreamdemux = Gst.ElementFactory.make("nvstreamdemux", "nvstreamdemux")
if not nvstreamdemux:
sys.stderr.write(" Unable to create nvstreamdemux \n")
if is_live:
print("Atleast one of the sources is live")
streammux.set_property("live-source", 1)
streammux.set_property("width", 1920)
streammux.set_property("height", 1080)
streammux.set_property("batch-size", number_sources)
streammux.set_property("batched-push-timeout", 4000000)
#pgie.set_property("config-file-path", "deepstream-nvdsanalytics/ds_demux_pgie_config.txt")
pgie.set_property("config-file-path", "config/dstest1_pgie1_config_yolox.txt")
pgie_batch_size = pgie.get_property("batch-size")
if pgie_batch_size != number_sources:
print(
"WARNING: Overriding infer-config batch-size",
pgie_batch_size,
" with number of sources ",
number_sources,
" \n",
pgie.set_property("batch-size", number_sources)
print("Adding elements to Pipeline \n")
pipeline.add(pgie)
pipeline.add(nvstreamdemux)
# linking
streammux.link(queue1)
queue1.link(pgie)
pgie.link(nvstreamdemux)
##creating demux src
for i, uri in enumerate(args):
uri_stream_path = uri.split("/")[-1]
# creating queue
print("i============ {}".format(i))
queue = make_element("queue", i)
pipeline.add(queue)
# creating nvvidconv
nvvideoconvert = make_element("nvvideoconvert", i)
pipeline.add(nvvideoconvert)
# creating nvosd
nvdsosd = make_element("nvdsosd", i)
pipeline.add(nvdsosd)
nvdsosd.set_property("process-mode", OSD_PROCESS_MODE)
nvdsosd.set_property("display-text", OSD_DISPLAY_TEXT)
# connect nvstreamdemux -> queue
padname = "src_%u" % i
demuxsrcpad = nvstreamdemux.get_request_pad(padname)
if not demuxsrcpad:
sys.stderr.write("Unable to create demux src pad \n")
queuesinkpad = queue.get_static_pad("sink")
if not queuesinkpad:
sys.stderr.write("Unable to create queue sink pad \n")
demuxsrcpad.link(queuesinkpad)
# connect queue -> nvvidconv -> nvosd -> nveglgl
queue.link(nvvideoconvert)
nvvideoconvert.link(nvdsosd)
nvvidconv_postosd = Gst.ElementFactory.make("nvvideoconvert", "convertor_postosd"+str(i))
if not nvvidconv_postosd:
sys.stderr.write(" Unable to create nvvidconv_postosd \n")
# Create a caps filter
caps = Gst.ElementFactory.make("capsfilter", "filter"+str(i))
if i < 30:
caps.set_property(
"caps", Gst.Caps.from_string("video/x-raw(memory:NVMM),format=I420")#format=I420"),width=640,height=480
else:
caps.set_property(
"caps", Gst.Caps.from_string("video/x-raw,format=I420")#format=I420"),width=640,height=480
# Make the encoder
encoder = Gst.ElementFactory.make("nvv4l2h264enc", "encoder"+str(i))
print("Creating HW H264 Encoder")
# elif codec == "H265":
# encoder = Gst.ElementFactory.make("nvv4l2h265enc", "encoder")
# print("Creating H265 Encoder")
# if not encoder:
# sys.stderr.write(" Unable to create encoder")
encoder.set_property("bitrate", bitrate)
# Make the payload-encode video into RTP packets
if codec == "H264":
rtppay = Gst.ElementFactory.make("rtph264pay", "rtppay"+str(i))
print("Creating H264 rtppay")
rtppay = Gst.ElementFactory.make("rtph265pay", "rtppay")
print("Creating H265 rtppay")
if not rtppay:
sys.stderr.write(" Unable to create rtppay")
# sink = Gst.ElementFactory.make("udpsink", "udpsink"+str(i))
# if not sink:
# sys.stderr.write(" Unable to create udpsink")
# # sink.set_property("host", "224.224.255.255")
# sink.set_property("host", "127.0.0.1")
# sink.set_property("port", udp_port)
# sink.set_property("async", False)
# sink.set_property("sync", 0) # inportant for live source
h264parse = Gst.ElementFactory.make("h264parse", "h264parse"+str(i))
sink = Gst.ElementFactory.make("rtspclientsink", "rtspclientsink" + str(i))
if not sink:
sys.stderr.write(" Unable to create rtspclientsink")
stream_udpport_mapping[uri_stream_path] = udp_port
udp_port +=1
media_mtx_url = f"rtsp://localhost:8554/outstream{i}" # Replace <MEDIAMTX_SERVER_IP> with actual IP or hostname
sink.set_property("location", media_mtx_url)
sink.set_property("protocols","tcp")
pipeline.add(nvvidconv_postosd)
pipeline.add(caps)
pipeline.add(encoder)
pipeline.add(rtppay)
pipeline.add(h264parse)
pipeline.add(sink)
nvdsosd.link(nvvidconv_postosd)
nvvidconv_postosd.link(caps)
caps.link(encoder)
encoder.link(h264parse)
h264parse.link(sink)
print("Linking elements in the Pipeline \n")
# create an event loop and feed gstreamer bus mesages to it
loop = GLib.MainLoop()
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect("message", bus_call, loop)
pgie_src_pad = pgie.get_static_pad("src")
# if not pgie_src_pad:
# sys.stderr.write(" Unable to get src pad \n")
# else:
# pgie_src_pad.add_probe(Gst.PadProbeType.BUFFER, pgie_src_pad_buffer_probe, 0)
# # perf callback function to print fps every 5 sec
# GLib.timeout_add(5000, perf_data.perf_print_callback)
# Lets add probe to get informed of the meta data generated, we add probe to
# the sink pad of the osd element, since by that time, the buffer would have
# had got all the metadata.
osdsinkpad = nvdsosd.get_static_pad("sink")
if not osdsinkpad:
sys.stderr.write(" Unable to get sink pad of nvosd \n")
osdsinkpad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0)
print("Starting pipeline \n")
# setup rtsp server
rtsp_server = setup_rtsp_server(rtsp_port_num=rtsp_port)
print(f"{stream_udpport_mapping = }")
for ix, uri in enumerate(args):
out_stream_path = f"/outstream{ix}"
stream_udp_port = stream_udpport_mapping[uri_stream_path]
# create_rtsp_out(rtsp_server=rtsp_server, udp_port=stream_udp_port, stream_path=out_stream_path)
print(f"{stream_udp_port = }, {out_stream_path = }")
# udp_port +=1
# start play back and listed to events
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except:
pass
# cleanup
print("Exiting app\n")
pipeline.set_state(Gst.State.NULL)
def parse_args():
parser = argparse.ArgumentParser(prog=“deepstream_demux_multi_in_multi_out.py”,
description=“deepstream-demux-multi-in-multi-out takes multiple URI streams as input”
“and uses nvstreamdemux
to split batches and output separate buffer/streams”)
parser.add_argument(
“-i”,
“–input”,
help=“Path to input streams”,
nargs=“+”,
metavar=“URIs”,
default=[“a”],
required=True,
if len(sys.argv)==1:
parser.print_help(sys.stderr)
sys.exit(1)
args = parser.parse_args()
global stream_path
stream_paths = args.input
return stream_paths
if name == “main”:
stream_paths = parse_args()
sys.exit(main(stream_paths))
