• Hardware Platform (Jetson / GPU): Jetson
• DeepStream Version: 7.1
• JetPack Version (valid for Jetson only): 6.2.1+b38
• TensorRT Version: 10.3.0.30
• Issue Type(questions, new requirements, bugs): question
I am running my pipeline using DeepStream 7.1 on a Jetson Orin Nano device. The pipeline works correctly when running directly on the device, but when I run it inside a Docker container based on nvcr.io/nvidia/deepstream:7.1-samples-multiarch, I encounter the following error:
**E1001 09:41:50.455479 pipeline.cpp:206] ERROR from element nvv4l2-decoder: Error getting capabilities for device '/dev/v4l2-nvdec': It isn't a v4l2 driver. Check if it is a v4l1 driver.**
**system error: Inappropriate ioctl for device**
The container is run with:
runtime: nvidiaprivileged: truenetwork_mode: host/dev:/devmounted
Could someone explain why nvv4l2-decoder fails in this setup and how to resolve it?
Thanks in advance for your help.
