No such element factory "nvv4l2decoder" on deepstream7.1
• Hardware Platform (Jetson / GPU): Jetson Orin Nano Super
• DeepStream Version: 7.1
• JetPack Version (valid for Jetson only): 6.2
• TensorRT Version: 10.3.0.30
• NVIDIA GPU Driver Version (valid for GPU only):
I have a Jetson Orin Nano Super Developer Kit and tried to run deepstream-test1, but I got an error saying “no such element factory ‘nvv4l2decoder’”. I have already installed deepstream-7.1_7.1.0-1_arm64.deb and also tried installing nvidia-jetpack-runtime, but the issue still exists. I didn’t find libgstnvvideo4linux2.so on the deepstream plugin path.
nvidia@nvidia-desktop:/opt/nvidia/deepstream/deepstream-7.1/sources/apps/sample_apps/deepstream-test1$ ls /opt/nvidia/deepstream/deepstream-7.1/lib/gst-plugins/
libcustom2d_preprocess.so libnvdsgst_deepstream_bins.so libnvdsgst_logger.so libnvdsgst_nvmultiurisrcbin.so libnvdsgst_segvisual.so
libgstnvvideoconvert.so libnvdsgst_dewarper.so libnvdsgst_metamux.so libnvdsgst_nvurisrcbin.so libnvdsgst_speech.so
libnvdsgst_3dbridge.so libnvdsgst_dsanalytics.so libnvdsgst_msgbroker.so libnvdsgst_of.so libnvdsgst_text_to_speech.so
libnvdsgst_3dfilter.so libnvdsgst_dsexample.so libnvdsgst_msgconv.so libnvdsgst_ofvisual.so libnvdsgst_tracker.so
libnvdsgst_3dmixer.so libnvdsgst_inferaudio.so libnvdsgst_multistream_legacy.a libnvdsgst_osd.so libnvdsgst_udp.so
libnvdsgstA2Vtemplate.so libnvdsgst_inferserver.so libnvdsgst_multistream.so libnvdsgst_postprocess.so libnvdsgst_videotemplate.so
libnvdsgst_audiotemplate.so libnvdsgst_infer.so libnvdsgst_multistreamtiler.so libnvdsgst_preprocess.so
sudo /opt/nvidia/deepstream/deepstream/install.sh
If the above command line does not work, it is recommended to use SDKManager to re-burn Jetpack and DeepStream
Thank you for your reply.
sudo apt install --reinstall nvidia-l4t-gstreamer
This command fixed my problem.
