No element "nvinfer"
I try to run script:
gst-launch-1.0 filesrc location=/opt/nvidia/deepstream/deepstream-4.0/samples/streams/sample_1080p_h264.mp4 ! \
            	decodebin ! m.sink_0 nvstreammux name=m batch-size=1 width=1280 \
            	height=720 ! nvinfer config-file-path=$1 ! \
            	nvvideoconvert ! nvdsosd ! nvegltransform ! nveglglessink sync=false
but I get error as below image:
How can I fix it?
• DeepStream Version
• TensorRT Version
Hello @Fiona.Chen,
I use Jetson TX2, jetpack 4.2
Deepstream 4.0
TensorRT 6.0.1
Can you run “gst-inspect-1.0 nvinfer”? What is the result?
Screenshot from 2021-02-22 08-52-35
DeepStreamSDK is not installed correctly, please install deepstreamSDK correctly.
DeepStreamSDK 4.0 is not supported now. Please use latest deepstream. Quickstart Guide — DeepStream 6.1.1 Release documentation
Hi @Fiona.Chen,
because of some reason so I have to use DeepStream 4.0. In this case, I should reinstall DeepstreamSDK, right?
Sure. And the related drivers also need to be correct.
@Fiona.Chen, thank you !
Hi @Fiona.Chen
I have reinstalled Deepstream 4.0 follow this link, but I still get the same error.
Do you have other ideal for it?
No. No idea.
