• Hardware Platform: Jetson Nano/Xavier NX
• DeepStream Version: 5.1
• JetPack Version 4.6.1(Nano) / 4.5.1(Xavier)
• TensorRT Version: 8.0.1-1+cuda10.2
I am unable to launch a gst-launch with nvinfer. I have tried it from the command line
$ gst-launch-1.0 v4l2src device=/dev/video0 \
> ! image/jpeg, width=1280, height=720, framerate=30/1 \
> ! jpegparse \
> ! nvv4l2decoder \
> ! m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=720 gpu-id=0 nvbuf-memory-type=0 \
> ! nvinfer config-file-path=/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/config_infer_primary.txt batch-size=1 unique-id=1 \
> ! queue \
> ! nvvideoconvert \
> ! nvdsosd \
> ! nvegltransform \
> ! fakesink
(gst-plugin-scanner:9340): GStreamer-WARNING **: 16:08:06.783: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_osd.so': libnvinfer.so.7: cannot open shared object file: No such file or directory
(gst-plugin-scanner:9340): GStreamer-WARNING **: 16:08:06.815: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libnvinfer.so.7: cannot open shared object file: No such file or directory
(gst-plugin-scanner:9340): GStreamer-WARNING **: 16:08:06.820: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so': libnvparsers.so.7: cannot open shared object file: No such file or directory
(gst-plugin-scanner:9340): GStreamer-WARNING **: 16:08:06.829: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferaudio.so': libnvparsers.so.7: cannot open shared object file: No such file or directory
WARNING: erroneous pipeline: no element "nvinfer"
And also from the samples l4t container
$ sudo docker run -it --rm --net=host --runtime nvidia -w /opt/nvidia/deepstream/deepstream-5.1 -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/deepstream-l4t:5.1-21.02-samples
$/opt/nvidia/deepstream/deepstream-5.1# gst-inspect-1.0 nvinfer
(Argus) Error FileOperationFailed: Connecting to nvargus-daemon failed: No such file or directory (in src/rpc/socket/client/SocketClientDispatch.cpp, function openSocketConnection(), line 205)
(Argus) Error FileOperationFailed: Cannot create camera provider (in src/rpc/socket/client/SocketClientDispatch.cpp, function createCameraProvider(), line 106)
(gst-plugin-scanner:14): GStreamer-WARNING **: 04:30:36.918: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_osd.so': /usr/lib/aarch64-linux-gnu/libnvinfer.so.7: file too short
(gst-plugin-scanner:14): GStreamer-WARNING **: 04:30:37.013: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': /usr/lib/aarch64-linux-gnu/libnvinfer.so.7: file too short
(gst-plugin-scanner:14): GStreamer-WARNING **: 04:30:37.037: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so': /usr/lib/aarch64-linux-gnu/libnvparsers.so.7: file too short
(gst-plugin-scanner:14): GStreamer-WARNING **: 04:30:37.068: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferaudio.so': /usr/lib/aarch64-linux-gnu/libnvparsers.so.7: file too short
No such element or plugin 'nvinfer'
Any ideas on how to resolve. I have tried it on multiple devices (Nano\Xavier). But no luck so far.
