Container deepstream-l4t:6.1-triton Not working Jetson Xavier NX?
• Hardware Platform (Jetson / GPU) = Jetson
• DeepStream Version = 6.1
• JetPack Version (valid for Jetson only) = 5.0.2-b231
• TensorRT Version
Getting error while running deepstream pipeline in jetson xavier nx with deepstream-6.1 triton container.
gst-launch-1.0 uridecodebin uri=$1 ! nvvideoconvert ! m.sink_0 nvstreammux name=m width=1920 height=1080 batch-size=1 batched-push-timeout=40000 ! queue ! nvinfer config-file-path=dstest3_pgie_config.txt ! queue ! nvtracker tracker-width=640 tracker-height=384 ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so ! queue ! nvvideoconvert name=converter ! nvdsosd name=onscreendisplay process-mode=0 display-text=1 ! nv3dsink name=nv3d-sink
0:00:00.108779595 18 0xaaaaddadc0d0 WARN GST_ELEMENT_FACTORY gstelementfactory.c:456:gst_element_factory_make: no such element factory “nvvideoconvert”!
0:00:00.108921707 18 0xaaaaddadc0d0 ERROR GST_PIPELINE grammar.y:816:priv_gst_parse_yyparse: no element “nvvideoconvert”
0:00:00.109005900 18 0xaaaaddadc0d0 ERROR GST_PIPELINE grammar.y:1001:priv_gst_parse_yyparse: link has no source [sink=m@(nil)]
0:00:00.109077068 18 0xaaaaddadc0d0 WARN GST_ELEMENT_FACTORY gstelementfactory.c:456:gst_element_factory_make: no such element factory “nvstreammux”!
0:00:00.109124620 18 0xaaaaddadc0d0 ERROR GST_PIPELINE grammar.y:816:priv_gst_parse_yyparse: no element “nvstreammux”
0:00:00.112613651 18 0xaaaaddadc0d0 ERROR GST_PIPELINE grammar.y:901:priv_gst_parse_yyparse: link has no source [sink=@0xaaaaddaec180]
0:00:00.112711348 18 0xaaaaddadc0d0 WARN GST_ELEMENT_FACTORY gstelementfactory.c:456:gst_element_factory_make: no such element factory “nvinfer”!
0:00:00.112770164 18 0xaaaaddadc0d0 ERROR GST_PIPELINE grammar.y:816:priv_gst_parse_yyparse: no element “nvinfer”
0:00:00.112827796 18 0xaaaaddadc0d0 ERROR GST_PIPELINE grammar.y:901:priv_gst_parse_yyparse: link has no sink [source=@0xaaaaddaec180]
0:00:00.113379189 18 0xaaaaddadc0d0 ERROR GST_PIPELINE grammar.y:901:priv_gst_parse_yyparse: link has no source [sink=@0xaaaaddaec480]
0:00:00.113455349 18 0xaaaaddadc0d0 WARN GST_ELEMENT_FACTORY gstelementfactory.c:456:gst_element_factory_make: no such element factory “nvtracker”!
0:00:00.113511477 18 0xaaaaddadc0d0 ERROR GST_PIPELINE grammar.y:816:priv_gst_parse_yyparse: no element “nvtracker”
0:00:00.113568245 18 0xaaaaddadc0d0 ERROR GST_PIPELINE grammar.y:901:priv_gst_parse_yyparse: link has no sink [source=@0xaaaaddaec480]
0:00:00.113966070 18 0xaaaaddadc0d0 ERROR GST_PIPELINE grammar.y:901:priv_gst_parse_yyparse: link has no source [sink=@0xaaaaddaec780]
0:00:00.114037014 18 0xaaaaddadc0d0 WARN GST_ELEMENT_FACTORY gstelementfactory.c:456:gst_element_factory_make: no such element factory “nvvideoconvert”!
0:00:00.114077111 18 0xaaaaddadc0d0 ERROR GST_PIPELINE grammar.y:816:priv_gst_parse_yyparse: no element “nvvideoconvert”
0:00:00.114170359 18 0xaaaaddadc0d0 ERROR GST_PIPELINE grammar.y:901:priv_gst_parse_yyparse: link has no sink [source=@0xaaaaddaec780]
0:00:00.114240887 18 0xaaaaddadc0d0 WARN GST_ELEMENT_FACTORY gstelementfactory.c:456:gst_element_factory_make: no such element factory “nvdsosd”!
0:00:00.114284759 18 0xaaaaddadc0d0 ERROR GST_PIPELINE grammar.y:816:priv_gst_parse_yyparse: no element “nvdsosd”
0:00:00.114338487 18 0xaaaaddadc0d0 ERROR GST_PIPELINE grammar.y:901:priv_gst_parse_yyparse: link has no source [sink=@(nil)]
0:00:00.114392439 18 0xaaaaddadc0d0 WARN GST_ELEMENT_FACTORY gstelementfactory.c:456:gst_element_factory_make: no such element factory “nv3dsink”!
0:00:00.114432375 18 0xaaaaddadc0d0 ERROR GST_PIPELINE grammar.y:816:priv_gst_parse_yyparse: no element “nv3dsink”
0:00:00.114478199 18 0xaaaaddadc0d0 ERROR GST_PIPELINE grammar.y:901:priv_gst_parse_yyparse: link has no source [sink=@(nil)]
WARNING: erroneous pipeline: no element “nvvideoconvert”
(gst-plugin-scanner:50): GStreamer-WARNING **: 08:07:31.541: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dewarper.so’: libnvdsbufferpool.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:50): GStreamer-WARNING **: 08:07:31.543: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so’: libnvbufsurface.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:50): GStreamer-WARNING **: 08:07:31.545: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_preprocess.so’: libnvbufsurface.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:50): GStreamer-WARNING **: 08:07:31.547: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideoconvert.so’: libnvdsbufferpool.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:50): GStreamer-WARNING **: 08:07:31.558: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_segvisual.so’: libnvdsbufferpool.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:50): GStreamer-WARNING **: 08:07:31.561: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so’: libnvbufsurface.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:50): GStreamer-WARNING **: 08:07:31.581: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferaudio.so’: libnvdla_compiler.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:50): GStreamer-WARNING **: 08:07:31.583: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:50): GStreamer-WARNING **: 08:07:31.590: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_ofvisual.so’: libnvdsbufferpool.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:50): GStreamer-WARNING **: 08:07:31.593: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libnvbufsurface.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:50): GStreamer-WARNING **: 08:07:31.605: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_deepstream_bins.so’: libnvdsbufferpool.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:50): GStreamer-WARNING **: 08:07:31.608: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_tracker.so’: libnvbufsurface.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:50): GStreamer-WARNING **: 08:07:31.610: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dsexample.so’: libnvbufsurface.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:50): GStreamer-WARNING **: 08:07:31.616: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistreamtiler.so’: libnvbufsurface.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:50): GStreamer-WARNING **: 08:07:31.618: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libcustom2d_preprocess.so’: libnvbufsurftransform.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:50): GStreamer-WARNING **: 08:07:31.621: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_osd.so’: libnvbufsurface.so.1.0.0: cannot open shared object file: No such file or directory
  1. from the error, the application can’t find many gstreamer plugins, can you share the output of ""gst-inspect-1.0 |grep nvvideoconvert?
  2. please install dependencies by this link: jetson-setup
I have tried deepsteam 6.1 SDK without docker and it is working fine.
i know nonw of the nvidia plugins installed in docker, but why?
i tried other containers also all are giving the same error.
[quote=“neo21995, post:4, topic:249305”]
please find start docker method in this link: deepstream-l4t.
It worked, Thank you.
