**• Hardware Platform (Jetson / GPU): GPU Tesla V100 • DeepStream Version 6.0.0 • JetPack Version (valid for Jetson only) • TensorRT Version: 8.0.3-1+cuda11.3 • NVIDIA GPU Driver Version (valid for GPU only): 470.182.03 • Issue Type( questions, new requirements, bugs): bug • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
GST_DEBUG=3 deepstream-app -c source30_1080p_dec_preprocess_infer-resnet_tiled_display_int8.txt
I installed deepstream on a Azure virtual machine running Ubuntu 20.04 following the instruction found in NVIDIA DeepStream development with Microsoft Azure - Training | Microsoft Learn. I have to make some changes to match the Ubuntu distribution like changing some repositories.
The configuration I’m using is:
Ubuntu 20.04
Deepstream: 6.0.0
Nvidia driver: 470.182.03
Cuda:11.4
TensorRT: 8.0.3-1+cuda11.3
gstreamer: 1.0.0
ibssl1.1 (had o change from 1.0.0 because that version isn’t available for Ubuntu 20.04)
Before running deepstream I run:
rm -rf ~/.cache/gstreamer-1.0/
I tried to run the sample configuration file source30_1080p_dec_preprocess_infer-resnet_tiled_display_int8.txt with sink type 2 getting this error:
0:00:00.011157008 2488780 0x563fa2a59ca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x120000: 'AVR (Audio Visual Research)' is not ma>
0:00:00.011188408 2488780 0x563fa2a59ca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x180000: 'CAF (Apple Core Audio File)' is not ma>
0:00:00.011197008 2488780 0x563fa2a59ca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x100000: 'HTK (HMM Tool Kit)' is not mapped
0:00:00.011204808 2488780 0x563fa2a59ca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0xc0000: 'MAT4 (GNU Octave 2.0 / Matlab 4.2)' is >
0:00:00.011212307 2488780 0x563fa2a59ca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0xd0000: 'MAT5 (GNU Octave 2.1 / Matlab 5.0)' is >
0:00:00.011219407 2488780 0x563fa2a59ca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x210000: 'MPC (Akai MPC 2k)' is not mapped
0:00:00.011224807 2488780 0x563fa2a59ca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0xe0000: 'PVF (Portable Voice Format)' is not map>
0:00:00.011232307 2488780 0x563fa2a59ca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x160000: 'SD2 (Sound Designer II)' is not mapped
0:00:00.011241507 2488780 0x563fa2a59ca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x190000: 'WVE (Psion Series 3)' is not mapped
0:00:00.048033776 2488780 0x563fa2a59ca0 WARN ladspa gstladspa.c:507:plugin_init:<plugin41> no LADSPA plugins found, check LADSPA_PATH
0:00:00.422090061 2488780 0x563fa2a59ca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: librivermax.so.0: cannot >
(gst-plugin-scanner:2488780): GStreamer-WARNING **: 11:29:49.593: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.>
0:00:00.427128675 2488780 0x563fa2a59ca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libtritonserver.so: canno>
(gst-plugin-scanner:2488780): GStreamer-WARNING **: 11:29:49.598: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libt>
0:00:00.427550868 2488780 0x563fa2a59ca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libgstbadvideo-1.0.so.0: >
(gst-plugin-scanner:2488780): GStreamer-WARNING **: 11:29:49.599: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_nvblender.so': libgst>
0:00:00.677493681 2488780 0x563fa2a59ca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: librivermax.so.0: cannot >
(gst-plugin-scanner:2488780): GStreamer-WARNING **: 11:29:49.849: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.>
0:00:00.678762460 2488780 0x563fa2a59ca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libtritonserver.so: canno>
(gst-plugin-scanner:2488780): GStreamer-WARNING **: 11:29:49.850: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libt>
0:00:00.679324850 2488780 0x563fa2a59ca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libgstbadvideo-1.0.so.0: >
(gst-plugin-scanner:2488780): GStreamer-WARNING **: 11:29:49.851: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_nvblender.so': libgst>
0:00:00.693621405 2488780 0x563fa2a59ca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: librivermax.so.0: cannot >
(gst-plugin-scanner:2488780): GStreamer-WARNING **: 11:29:49.865: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.>
0:00:00.694855584 2488780 0x563fa2a59ca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libtritonserver.so: canno>
(gst-plugin-scanner:2488780): GStreamer-WARNING **: 11:29:49.866: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libt>
0:00:00.695418674 2488780 0x563fa2a59ca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libgstbadvideo-1.0.so.0: >
(gst-plugin-scanner:2488780): GStreamer-WARNING **: 11:29:49.867: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_nvblender.so': libgst>
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:1484 Deserialize engine failed because file path: /home/adminvdi/deepstream/samples-6.0/configs/deepstream-app/../../models/>
0:00:01.752556924 2488779 0x55e77fd75900 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferCon>
0:00:01.752620823 2488779 0x55e77fd75900 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferCon>
0:00:01.752635523 2488779 0x55e77fd75900 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContex>
ERROR: [TRT]: 1: [executionResources.cpp::setTacticSources::146] Error Code 1: Cudnn (Could not initialize cudnn, please check cudnn installation.)
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:1119 Build engine failed from config file
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:811 failed to build trt engine.
0:00:02.259799804 2488779 0x55e77fd75900 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContext>
0:00:02.260084199 2488779 0x55e77fd75900 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContext>
0:00:02.260105599 2488779 0x55e77fd75900 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContext>
0:00:02.260149298 2488779 0x55e77fd75900 WARN nvinfer gstnvinfer.cpp:841:gst_nvinfer_start:<primary_gie> error: Failed to create NvDsInferContext instance
0:00:02.260158998 2488779 0x55e77fd75900 WARN nvinfer gstnvinfer.cpp:841:gst_nvinfer_start:<primary_gie> error: Config file path: /home/adminvdi/deepstream/>
0:00:02.260217597 2488779 0x55e77fd75900 WARN GST_PADS gstpad.c:1142:gst_pad_set_active:<primary_gie:sink> Failed to activate pad
** ERROR: <main:658>: Failed to set pipeline to PAUSED
Quitting
ERROR from primary_gie: Failed to create NvDsInferContext instance
Debug info: gstnvinfer.cpp(841): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie:
Config file path: /home/adminvdi/deepstream/samples-6.0/configs/deepstream-app/config_infer_primary.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
App run failed
And if I change sink type to 3:
0:00:00.009836993 2491846 0x5648c90acca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x120000: 'AVR (Audio Visual Research)' is not ma>
0:00:00.009870493 2491846 0x5648c90acca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x180000: 'CAF (Apple Core Audio File)' is not ma>
0:00:00.009881792 2491846 0x5648c90acca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x100000: 'HTK (HMM Tool Kit)' is not mapped
0:00:00.009890392 2491846 0x5648c90acca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0xc0000: 'MAT4 (GNU Octave 2.0 / Matlab 4.2)' is >
0:00:00.009897992 2491846 0x5648c90acca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0xd0000: 'MAT5 (GNU Octave 2.1 / Matlab 5.0)' is >
0:00:00.009905092 2491846 0x5648c90acca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x210000: 'MPC (Akai MPC 2k)' is not mapped
0:00:00.009914892 2491846 0x5648c90acca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0xe0000: 'PVF (Portable Voice Format)' is not map>
0:00:00.009922692 2491846 0x5648c90acca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x160000: 'SD2 (Sound Designer II)' is not mapped
0:00:00.009931591 2491846 0x5648c90acca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x190000: 'WVE (Psion Series 3)' is not mapped
0:00:00.043037595 2491846 0x5648c90acca0 WARN ladspa gstladspa.c:507:plugin_init:<plugin41> no LADSPA plugins found, check LADSPA_PATH
0:00:00.239633357 2491846 0x5648c90acca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: librivermax.so.0: cannot >
(gst-plugin-scanner:2491846): GStreamer-WARNING **: 11:33:12.571: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.>
0:00:00.244773049 2491846 0x5648c90acca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libtritonserver.so: canno>
(gst-plugin-scanner:2491846): GStreamer-WARNING **: 11:33:12.576: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libt>
0:00:00.245193740 2491846 0x5648c90acca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libgstbadvideo-1.0.so.0: >
(gst-plugin-scanner:2491846): GStreamer-WARNING **: 11:33:12.577: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_nvblender.so': libgst>
0:00:00.507464220 2491846 0x5648c90acca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: librivermax.so.0: cannot >
(gst-plugin-scanner:2491846): GStreamer-WARNING **: 11:33:12.839: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.>
0:00:00.508749993 2491846 0x5648c90acca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libtritonserver.so: canno>
(gst-plugin-scanner:2491846): GStreamer-WARNING **: 11:33:12.840: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libt>
0:00:00.509315081 2491846 0x5648c90acca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libgstbadvideo-1.0.so.0: >
(gst-plugin-scanner:2491846): GStreamer-WARNING **: 11:33:12.841: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_nvblender.so': libgst>
0:00:00.525211846 2491846 0x5648c90acca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: librivermax.so.0: cannot >
(gst-plugin-scanner:2491846): GStreamer-WARNING **: 11:33:12.857: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.>
0:00:00.527190505 2491846 0x5648c90acca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libtritonserver.so: canno>
(gst-plugin-scanner:2491846): GStreamer-WARNING **: 11:33:12.859: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libt>
0:00:00.528163684 2491846 0x5648c90acca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libgstbadvideo-1.0.so.0: >
(gst-plugin-scanner:2491846): GStreamer-WARNING **: 11:33:12.860: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_nvblender.so': libgst>
** ERROR: <create_encode_file_bin:467>: create_encode_file_bin failed
** ERROR: <create_sink_bin:781>: create_sink_bin failed
** ERROR: <create_processing_instance:815>: create_processing_instance failed
** ERROR: <create_pipeline:1323>: create_pipeline failed
** ERROR: <main:639>: Failed to create pipeline
Quitting
App run failed
Sorry I didn’t realized that it was truncated I copied it from nano editor and I thought it was complete. Here is the complete logs:
Synk type 2:
0:00:00.011157008 2488780 0x563fa2a59ca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x120000: 'AVR (Audio Visual Research)' is not mapped
0:00:00.011188408 2488780 0x563fa2a59ca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x180000: 'CAF (Apple Core Audio File)' is not mapped
0:00:00.011204808 2488780 0x563fa2a59ca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0xc0000: 'MAT4 (GNU Octave 2.0 / Matlab 4.2)' is not mapped
0:00:00.011212307 2488780 0x563fa2a59ca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0xd0000: 'MAT5 (GNU Octave 2.1 / Matlab 5.0)' is not mapped
0:00:00.011224807 2488780 0x563fa2a59ca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0xe0000: 'PVF (Portable Voice Format)' is not mapped
0:00:00.422090061 2488780 0x563fa2a59ca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2488780): GStreamer-WARNING **: 11:29:49.593: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
0:00:00.427128675 2488780 0x563fa2a59ca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2488780): GStreamer-WARNING **: 11:29:49.598: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
0:00:00.427550868 2488780 0x563fa2a59ca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libgstbadvideo-1.0.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2488780): GStreamer-WARNING **: 11:29:49.599: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_nvblender.so': libgstbadvideo-1.0.so.0: cannot open shared object file: No such file or directory
0:00:00.677493681 2488780 0x563fa2a59ca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2488780): GStreamer-WARNING **: 11:29:49.849: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
0:00:00.678762460 2488780 0x563fa2a59ca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2488780): GStreamer-WARNING **: 11:29:49.850: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
0:00:00.679324850 2488780 0x563fa2a59ca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libgstbadvideo-1.0.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2488780): GStreamer-WARNING **: 11:29:49.851: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_nvblender.so': libgstbadvideo-1.0.so.0: cannot open shared object file: No such file or directory
0:00:00.693621405 2488780 0x563fa2a59ca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2488780): GStreamer-WARNING **: 11:29:49.865: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
0:00:00.694855584 2488780 0x563fa2a59ca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2488780): GStreamer-WARNING **: 11:29:49.866: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
0:00:00.695418674 2488780 0x563fa2a59ca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libgstbadvideo-1.0.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2488780): GStreamer-WARNING **: 11:29:49.867: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_nvblender.so': libgstbadvideo-1.0.so.0: cannot open shared object file: No such file or directory
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:1484 Deserialize engine failed because file path: /home/adminvdi/deepstream/samples-6.0/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b60_gpu0_int8.engine open error
0:00:01.752556924 2488779 0x55e77fd75900 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1889> [UID = 1]: deserialize engine from file :/home/adminvdi/deepstream/samples-6.0/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b60_gpu0_int8.engine failed
0:00:01.752620823 2488779 0x55e77fd75900 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1996> [UID = 1]: deserialize backend context from engine from file :/home/adminvdi/deepstream/samples-6.0/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b60_gpu0_int8.engine failed, try rebuild
0:00:01.752635523 2488779 0x55e77fd75900 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
0:00:02.259799804 2488779 0x55e77fd75900 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1934> [UID = 1]: build engine file failed
0:00:02.260084199 2488779 0x55e77fd75900 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2020> [UID = 1]: build backend context failed
0:00:02.260105599 2488779 0x55e77fd75900 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1257> [UID = 1]: generate backend failed, check config file settings
0:00:02.260158998 2488779 0x55e77fd75900 WARN nvinfer gstnvinfer.cpp:841:gst_nvinfer_start:<primary_gie> error: Config file path: /home/adminvdi/deepstream/samples-6.0/configs/deepstream-app/config_infer_primary.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
Quitting
App run failed
Synk type 3:
sink type 3
0:00:00.009836993 2491846 0x5648c90acca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x120000: 'AVR (Audio Visual Research)' is not mapped
0:00:00.009870493 2491846 0x5648c90acca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x180000: 'CAF (Apple Core Audio File)' is not mapped
0:00:00.009890392 2491846 0x5648c90acca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0xc0000: 'MAT4 (GNU Octave 2.0 / Matlab 4.2)' is not mapped
0:00:00.009897992 2491846 0x5648c90acca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0xd0000: 'MAT5 (GNU Octave 2.1 / Matlab 5.0)' is not mapped
0:00:00.009914892 2491846 0x5648c90acca0 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0xe0000: 'PVF (Portable Voice Format)' is not mapped
0:00:00.239633357 2491846 0x5648c90acca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2491846): GStreamer-WARNING **: 11:33:12.571: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
0:00:00.244773049 2491846 0x5648c90acca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2491846): GStreamer-WARNING **: 11:33:12.576: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
0:00:00.245193740 2491846 0x5648c90acca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libgstbadvideo-1.0.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2491846): GStreamer-WARNING **: 11:33:12.577: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_nvblender.so': libgstbadvideo-1.0.so.0: cannot open shared object file: No such file or directory
0:00:00.507464220 2491846 0x5648c90acca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2491846): GStreamer-WARNING **: 11:33:12.839: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
0:00:00.508749993 2491846 0x5648c90acca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2491846): GStreamer-WARNING **: 11:33:12.840: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
0:00:00.509315081 2491846 0x5648c90acca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libgstbadvideo-1.0.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2491846): GStreamer-WARNING **: 11:33:12.841: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_nvblender.so': libgstbadvideo-1.0.so.0: cannot open shared object file: No such file or directory
0:00:00.525211846 2491846 0x5648c90acca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2491846): GStreamer-WARNING **: 11:33:12.857: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
0:00:00.527190505 2491846 0x5648c90acca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2491846): GStreamer-WARNING **: 11:33:12.859: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
0:00:00.528163684 2491846 0x5648c90acca0 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libgstbadvideo-1.0.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2491846): GStreamer-WARNING **: 11:33:12.860: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_nvblender.so': libgstbadvideo-1.0.so.0: cannot open shared object file: No such file or directory
Quitting
App run failed
The configuration I’m using is correct or should I change to this:
Yes. We suggest that you use the matching version of the software, like TRT, cuDNN…
Just from the log attached, there maybe some problems in your config file.
