Hi everyone,
I’m having problems running applications on DeepStream 6.1 inside a docker. I’ve followed all tutorials and still haven’t figured it out.
Some context:
• Hardware Platform (GPU): NVIDIA TITAN X
~$ nvidia-smi
Fri Jun 3 14:05:28 2022
| NVIDIA-SMI 510.47.03 Driver Version: 510.47.03 CUDA Version: 11.6 |
| | | MIG M. |
| 0 NVIDIA TITAN X ... On | 00000000:01:00.0 Off | N/A |
| 23% 21C P8 9W / 250W | 16MiB / 12288MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1246 G /usr/lib/xorg/Xorg 9MiB |
| 0 N/A N/A 1332 G /usr/bin/gnome-shell 3MiB |
• Cuda Version : 11.6.1
• DeepStream Version: 6.1
• TensorRT Version: TensorRT 8.2.5.1
• NVIDIA GPU Driver Version: Driver Version: 510.47.03
• What I have tried:
- Create the docker using these instructions: docker-container-for-dgpu
- After this, I tried running the deepstream_tao_apps and had multiple errors.
- Create a clean docker and setting up with the tutorial on the quick-start available in DS-Quick Start
In both situations, I ended up with errors regarding plugins not being available for loading.
Whenever I try to run any example I end up with something similar to this or other errors:
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Unable to create NvStreamMux
Unable to create pgie
Unable to create nvvidconv
Creating EGLSink
Unable to create egl sink
Playing file ../../../../samples/streams/sample_720p.h264
File "deepstream_test_1.py", line 260, in <module>
sys.exit(main(sys.argv))
File "deepstream_test_1.py", line 193, in main
streammux.set_property('width', 1920)
AttributeError: 'NoneType' object has no attribute 'set_property'
Yes, I tried to remove the cache by running rm ${HOME}/.cache/gstreamer-1.0/registry.x86_64.bin.
root@82128e05cb12:/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/apps/deepstream-test1# gst-inspect-1.0 libnvdsgst_infer.so
Plugin Details:
Name libnvdsgst_infer.so
Description Plugin for blacklisted file
Filename /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so
Version 0.0.0
License BLACKLIST
Source module BLACKLIST
Binary package BLACKLIST
Origin URL BLACKLIST
0 features:
Then I tried to run ldd on some of the packages and had the following output with the export GST_DEBUG=3:
root@8a6245b5d731:/opt/nvidia/deepstream/deepstream-6.1# ldd /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_ucx.so
linux-vdso.so.1 (0x00007fffcbebf000)
libucs.so.0 => not found
libucp.so.0 => not found
libnvdsbufferpool.so => ///opt/nvidia/deepstream/deepstream-6.1/lib/libnvdsbufferpool.so (0x00007f464732b000)
libnvdsgst_helper.so => ///opt/nvidia/deepstream/deepstream-6.1/lib/libnvdsgst_helper.so (0x00007f4647321000)
libnvdsgst_audio.so => ///opt/nvidia/deepstream/deepstream-6.1/lib/libnvdsgst_audio.so (0x00007f464731c000)
libnvds_meta.so => ///opt/nvidia/deepstream/deepstream-6.1/lib/libnvds_meta.so (0x00007f464730f000)
libnvdsgst_meta.so => ///opt/nvidia/deepstream/deepstream-6.1/lib/libnvdsgst_meta.so (0x00007f4647308000)
libgstreamer-1.0.so.0 => /lib/x86_64-linux-gnu/libgstreamer-1.0.so.0 (0x00007f46471c1000)
libgstbase-1.0.so.0 => /lib/x86_64-linux-gnu/libgstbase-1.0.so.0 (0x00007f4647143000)
libglib-2.0.so.0 => /lib/x86_64-linux-gnu/libglib-2.0.so.0 (0x00007f464701a000)
libgobject-2.0.so.0 => /lib/x86_64-linux-gnu/libgobject-2.0.so.0 (0x00007f4646fba000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f4646dc6000)
libnvbufsurface.so => ///opt/nvidia/deepstream/deepstream-6.1/lib/libnvbufsurface.so (0x00007f4646dbd000)
libgstvideo-1.0.so.0 => /lib/x86_64-linux-gnu/libgstvideo-1.0.so.0 (0x00007f4646d0c000)
libgstrtp-1.0.so.0 => /lib/x86_64-linux-gnu/libgstrtp-1.0.so.0 (0x00007f4646ce6000)
libnvds_mem_allocator.so => ///opt/nvidia/deepstream/deepstream-6.1/lib/libnvds_mem_allocator.so (0x00007f4646ce1000)
libnvds_audio_allocator.so => ///opt/nvidia/deepstream/deepstream-6.1/lib/libnvds_audio_allocator.so (0x00007f4646cda000)
libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f4646af8000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f4646add000)
libgmodule-2.0.so.0 => /lib/x86_64-linux-gnu/libgmodule-2.0.so.0 (0x00007f4646ad7000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f4646988000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f4646982000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f464695d000)
libpcre.so.3 => /lib/x86_64-linux-gnu/libpcre.so.3 (0x00007f46468ea000)
libffi.so.7 => /lib/x86_64-linux-gnu/libffi.so.7 (0x00007f46468de000)
/lib64/ld-linux-x86-64.so.2 (0x00007f4647368000)
libcudart.so.11.0 => /usr/local/cuda-11.6/lib64/libcudart.so.11.0 (0x00007f464663a000)
libnvbuf_fdmap.so => ///opt/nvidia/deepstream/deepstream-6.1/lib/libnvbuf_fdmap.so (0x00007f4646634000)
liborc-0.4.so.0 => /lib/x86_64-linux-gnu/liborc-0.4.so.0 (0x00007f46465af000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f46465a5000)
and also:
root@8a6245b5d731:/opt/nvidia/deepstream/deepstream-6.1# deepstream-app -c samples/configs/deepstream-app/config_infer_primary.txt
0:00:00.030109213 21815 0x560db1fd1100 WARN ladspa gstladspa.c:507:plugin_init:<plugin79> no LADSPA plugins found, check LADSPA_PATH
0:00:00.176361830 21815 0x560db1fd1100 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x120000: 'AVR (Audio Visual Research)' is not mapped
0:00:00.176374627 21815 0x560db1fd1100 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x180000: 'CAF (Apple Core Audio File)' is not mapped
0:00:00.176381627 21815 0x560db1fd1100 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x100000: 'HTK (HMM Tool Kit)' is not mapped
0:00:00.176388389 21815 0x560db1fd1100 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0xc0000: 'MAT4 (GNU Octave 2.0 / Matlab 4.2)' is not mapped
0:00:00.176393832 21815 0x560db1fd1100 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0xd0000: 'MAT5 (GNU Octave 2.1 / Matlab 5.0)' is not mapped
0:00:00.176398745 21815 0x560db1fd1100 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x210000: 'MPC (Akai MPC 2k)' is not mapped
0:00:00.176404655 21815 0x560db1fd1100 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0xe0000: 'PVF (Portable Voice Format)' is not mapped
0:00:00.176410053 21815 0x560db1fd1100 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x160000: 'SD2 (Sound Designer II)' is not mapped
0:00:00.176415429 21815 0x560db1fd1100 WARN default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x190000: 'WVE (Psion Series 3)' is not mapped
0:00:00.185265913 21815 0x560db1fd1100 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:21815): GStreamer-WARNING **: 16:45:06.083: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
nvbufsurftransform:cuInit failed : 100
0:00:00.245900638 21814 0x5626a1e56790 ERROR GST_PLUGIN_LOADING gstpluginloader.c:276:plugin_loader_replay_pending: Plugin file /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_preprocess.so failed to load. Blacklisting
0:00:00.260615194 21814 0x5626a1e56790 ERROR GST_PLUGIN_LOADING gstpluginloader.c:276:plugin_loader_replay_pending: Plugin file /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libcustom2d_preprocess.so failed to load. Blacklisting
0:00:00.279678546 21814 0x5626a1e56790 ERROR GST_PLUGIN_LOADING gstpluginloader.c:276:plugin_loader_replay_pending: Plugin file /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so failed to load. Blacklisting
0:00:00.002299549 21821 0x560e872f4640 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libucs.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:21821): GStreamer-WARNING **: 16:45:06.179: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_ucx.so': libucs.so.0: cannot open shared object file: No such file or directory
0:00:00.298292130 21814 0x5626a1e56790 ERROR GST_PLUGIN_LOADING gstpluginloader.c:276:plugin_loader_replay_pending: Plugin file /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistreamtiler.so failed to load. Blacklisting
0:00:00.397547840 21814 0x5626a1e56790 ERROR GST_PLUGIN_LOADING gstpluginloader.c:276:plugin_loader_replay_pending: Plugin file /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_deepstream_bins.so failed to load. Blacklisting
0:00:00.532046554 21814 0x5626a1e56790 ERROR GST_PLUGIN_LOADING gstpluginloader.c:276:plugin_loader_replay_pending: Plugin file /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dewarper.so failed to load. Blacklisting
0:00:00.547836002 21814 0x5626a1e56790 ERROR GST_PLUGIN_LOADING gstpluginloader.c:276:plugin_loader_replay_pending: Plugin file /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dsexample.so failed to load. Blacklisting
0:00:00.564467399 21814 0x5626a1e56790 ERROR GST_PLUGIN_LOADING gstpluginloader.c:276:plugin_loader_replay_pending: Plugin file /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_tracker.so failed to load. Blacklisting
0:00:00.580578201 21814 0x5626a1e56790 ERROR GST_PLUGIN_LOADING gstpluginloader.c:276:plugin_loader_replay_pending: Plugin file /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideoconvert.so failed to load. Blacklisting
0:00:00.668240124 21814 0x5626a1e56790 ERROR GST_PLUGIN_LOADING gstpluginloader.c:276:plugin_loader_replay_pending: Plugin file /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so failed to load. Blacklisting
0:00:00.684803032 21814 0x5626a1e56790 ERROR GST_PLUGIN_LOADING gstpluginloader.c:276:plugin_loader_replay_pending: Plugin file /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_nvblender.so failed to load. Blacklisting
0:00:00.004377436 21837 0x560dcace7c60 WARN GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:21837): GStreamer-WARNING **: 16:45:06.586: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
0:00:00.833922097 21814 0x5626a1e56790 WARN GST_ELEMENT_FACTORY gstelementfactory.c:456:gst_element_factory_make: no such element factory "nvstreammux"!
** ERROR: <create_multi_source_bin:1457>: Failed to create element 'src_bin_muxer'
** ERROR: <create_multi_source_bin:1550>: create_multi_source_bin failed
** ERROR: <create_pipeline:1327>: create_pipeline failed
** ERROR: <main:697>: Failed to create pipeline
Quitting
App run failed
Looking with the gst-inspect-1.0 to check the blacklisted plugins I had the following output.
root@82128e05cb12:/opt/nvidia/deepstream# gst-inspect-1.0
(gst-plugin-scanner:56292): GStreamer-WARNING **: 18:39:19.804: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:56298): GStreamer-WARNING **: 18:39:19.910: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_ucx.so': libucs.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:56314): GStreamer-WARNING **: 18:39:20.326: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
nvdsgst_dsanalytics: nvdsanalytics: DsAnalytics plugin
nvdsgst_jpegdec: nvjpegdec: JPEG image decoder
nvdsgst_eglglessink: nveglglessink: EGL/GLES vout Sink
nvdsgst_videotemplate: nvdsvideotemplate: NvDsVideoTemplate plugin for Transform/In-Place use-cases
nvdsgst_logger: nvdslogger: Nvdslogger
nvdsgst_audiotemplate: nvdsaudiotemplate: DS AUDIO template Plugin for Transform IP use-cases
nvdsgst_of: nvof: nvof
nvdsgst_inferaudio: nvinferaudio: NvInfer Audio plugin
nvdsgst_osd: nvdsosd: NvDsOsd plugin
nvdsgst_metautils: nvdsmetaextract: nvdsmetaextract
nvdsgst_metautils: nvdsmetainsert: nvdsmetainsert
nvdsgst_speech: nvdsasr: DS ASR Plugin for speech use-cases
nvvideo4linux2: nvv4l2h265enc: V4L2 H.265 Encoder
nvvideo4linux2: nvv4l2h264enc: V4L2 H.264 Encoder
nvvideo4linux2: nvv4l2decoder: NVIDIA v4l2 video decoder
nvdsgst_ofvisual: nvofvisual: nvofvisual
nvdsgst_3dfilter: nvds3dfilter: DS 3D filter custom plugin
nvdsgst_segvisual: nvsegvisual: nvsegvisual
nvdsgst_postprocess: nvdspostprocess: NvDsPostProcess plugin for Transform/In-Place use-cases
nvdsgst_msgconv: nvmsgconv: Message Converter
nvdsgst_msgbroker: nvmsgbroker: Message Broker
nvdsgst_text_to_speech: nvds_text_to_speech: DS Text To Speech Plugin for Conversational AI use cases
bayer: rgb2bayer: RGB to Bayer converter
bayer: bayer2rgb: Bayer to RGB decoder for cameras
sid: siddec: Sid decoder
videoconvert: videoconvert: Colorspace converter
wavparse: wavparse: WAV audio demuxer
deinterlace: deinterlace: Deinterlacer
gdp: gdppay: GDP Payloader
gdp: gdpdepay: GDP Depayloader
dtls: dtlssrtpdemux: DTLS SRTP Demultiplexer
dtls: dtlssrtpenc: DTLS-SRTP Encoder
dtls: dtlssrtpdec: DTLS-SRTP Decoder
dtls: dtlsdec: DTLS Decoder
dtls: dtlsenc: DTLS Encoder
xingmux: xingmux: MP3 Xing muxer
videofiltersbad: videodiff: Video Diff
videofiltersbad: zebrastripe: Zebra stripe overlay
videofiltersbad: scenechange: Scene change detector
ximagesrc: ximagesrc: Ximage video source
alsa: alsamidisrc: AlsaMidi Source
alsa: alsasink: Audio sink (ALSA)
alsa: alsasrc: Audio source (ALSA)
sndfile: sfdec: Sndfile decoder
videorate: videorate: Video rate adjuster
videocrop: aspectratiocrop: aspectratiocrop
videocrop: videocrop: Crop
zbar: zbar: Barcode detector
avi: avisubtitle: Avi subtitle parser
avi: avimux: Avi muxer
avi: avidemux: Avi demuxer
mpegpsmux: mpegpsmux: MPEG Program Stream Muxer
audioresample: audioresample: Audio resampler
mplex: mplex: mplex video multiplexer
videosignal: simplevideomark: Video marker
videosignal: simplevideomarkdetect: Video detecter
videosignal: videoanalyse: Video analyser
navigationtest: navigationtest: Video navigation test
speed: speed: Speed
audioparsers: wavpackparse: Wavpack audio stream parser
audioparsers: sbcparse: SBC audio parser
audioparsers: mpegaudioparse: MPEG1 Audio Parser
audioparsers: flacparse: FLAC audio parser
audioparsers: dcaparse: DTS Coherent Acoustics audio stream parser
audioparsers: ac3parse: AC3 audio stream parser
audioparsers: amrparse: AMR audio stream parser
audioparsers: aacparse: AAC audio stream parser
colormanagement: lcms: LCMS2 ICC correction
camerabin: camerabin: Camera Bin
camerabin: wrappercamerabinsrc: Wrapper camera src element for camerabin2
camerabin: viewfinderbin: Viewfinder Bin
alpha: alpha: Alpha filter
encoding: encodebin: Encoder Bin
id3demux: id3demux: ID3 tag demuxer
audiomixmatrix: audiomixmatrix: Matrix audio mix
audiofxbad: audiochannelmix: Simple stereo audio mixer
autoconvert: autovideoconvert: Select color space convertor based on caps
autoconvert: autoconvert: Select convertor based on caps
festival: festival: Festival Text-to-Speech synthesizer
mulaw: mulawdec: Mu Law audio decoder
mulaw: mulawenc: Mu Law audio encoder
flac: flactag: FLAC tagger
flac: flacdec: FLAC audio decoder
flac: flacenc: FLAC audio encoder
closedcaption: line21encoder: Line 21 CC Encoder
closedcaption: cc708overlay: Closed Caption overlay
closedcaption: line21decoder: Line 21 CC Decoder
closedcaption: ccextractor: Closed Caption Extractor
closedcaption: ccconverter: Closed Caption Converter
closedcaption: cccombiner: Closed Caption Combiner
ogg: oggaviparse: Ogg AVI parser
ogg: oggparse: Ogg parser
ogg: ogmtextparse: OGM text stream parser
ogg: ogmvideoparse: OGM video stream parser
ogg: ogmaudioparse: OGM audio stream parser
ogg: oggmux: Ogg muxer
ogg: oggdemux: Ogg demuxer
teletext: teletextdec: Teletext decoder
audiofx: stereo: Stereo effect
audiofx: scaletempo: Scaletempo
audiofx: audioecho: Audio echo
audiofx: audiofirfilter: Audio FIR filter
audiofx: audiowsincband: Band pass & band reject filter
audiofx: audiowsinclimit: Low pass & high pass filter
audiofx: audioiirfilter: Audio IIR filter
audiofx: audiochebband: Band pass & band reject filter
audiofx: audiocheblimit: Low pass & high pass filter
audiofx: audiodynamic: Dynamic range controller
audiofx: audioamplify: Audio amplifier
audiofx: audiokaraoke: AudioKaraoke
audiofx: audioinvert: Audio inversion
audiofx: audiopanorama: Stereo positioning
videobox: videobox: Video box filter
taglib: apev2mux: TagLib-based APEv2 Muxer
taglib: id3v2mux: TagLib-based ID3v2 Muxer
mpeg2dec: mpeg2dec: mpeg1 and mpeg2 video decoder
monoscope: monoscope: Monoscope
cdio: cdiocddasrc: CD audio source (CDDA)
playback: parsebin: Parse Bin
playback: urisourcebin: URI reader
playback: uridecodebin3: URI Decoder
playback: uridecodebin: URI Decoder
playback: decodebin3: Decoder Bin 3
playback: decodebin: Decoder Bin
playback: streamsynchronizer: Stream Synchronizer
playback: subtitleoverlay: Subtitle Overlay
playback: playsink: Player Sink
playback: playbin3: Player Bin 3
playback: playbin: Player Bin 2
aiff: aiffmux: AIFF audio muxer
aiff: aiffparse: AIFF audio demuxer
dashdemux: dashdemux: DASH Demuxer
curl: curlhttpsrc: HTTP Client Source using libcURL
curl: curlsmtpsink: Curl smtp sink
curl: curlftpsink: Curl ftp sink
curl: curlfilesink: Curl file sink
curl: curlhttpsink: Curl http sink
amrwbdec: amrwbdec: AMR-WB audio decoder
asfmux: asfparse: ASF parser
asfmux: rtpasfpay: RTP ASF payloader
asfmux: asfmux: ASF muxer
multifile: splitmuxsrc: Split File Demuxing Bin
multifile: splitmuxsink: Split Muxing Bin
multifile: splitfilesrc: Split-File Source
multifile: multifilesink: Multi-File Sink
multifile: multifilesrc: Multi-File Source
pbtypes: GstVideoMultiviewFlagsSet (GstDynamicTypeFactory)
shout2: shout2send: Icecast network sink
compositor: compositor: Compositor
rtspclientsink: rtspclientsink: RTSP RECORD client
interlace: interlace: Interlace filter
rtsp: rtpdec: RTP Decoder
rtsp: rtspsrc: RTSP packet receiver
dvb: dvbbasebin: DVB bin
dvb: dvbsrc: DVB Source
gme: gmedec: Gaming console music file decoder
jpeg: jpegdec: JPEG image decoder
jpeg: jpegenc: JPEG image encoder
inter: intervideosink: Internal video sink
inter: intervideosrc: Internal video source
inter: intersubsink: Internal subtitle sink
inter: intersubsrc: Internal subtitle source
inter: interaudiosink: Internal audio sink
inter: interaudiosrc: Internal audio source
vorbis: vorbistag: VorbisTag
vorbis: vorbisparse: VorbisParse
vorbis: vorbisdec: Vorbis audio decoder
vorbis: vorbisenc: Vorbis audio encoder
mpegpsdemux: mpegpsdemux: MPEG Program Stream Demuxer
sbc: sbcenc: Bluetooth SBC audio encoder
sbc: sbcdec: Bluetooth SBC audio decoder
subenc: webvttenc: WebVTT encoder
subenc: srtenc: Srt encoder
smpte: smptealpha: SMPTE transitions
smpte: smpte: SMPTE transitions
de265: libde265dec: HEVC/H.265 decoder
subparse: ssaparse: SSA Subtitle Parser
subparse: subparse: Subtitle parser
subparse: subparse_typefind: srt, sub, mpsub, mdvd, smi, txt, dks, vtt
fbdevsink: fbdevsink: fbdev video sink
ttmlsubs: ttmlrender: TTML subtitle renderer
ttmlsubs: ttmlparse: TTML subtitle parser
alphacolor: alphacolor: Alpha color filter
dvdlpcmdec: dvdlpcmdec: DVD LPCM Audio decoder
kate: katetag: Kate stream tagger
kate: kateparse: Kate stream parser
kate: kateenc: Kate stream encoder
kate: katedec: Kate stream text decoder
srt: srtserversink: SRT sink
srt: srtclientsink: SRT sink
srt: srtserversrc: SRT source
srt: srtclientsrc: SRT source
srt: srtsink: SRT sink
srt: srtsrc: SRT source
netsim: netsim: Network Simulator
libav: avdeinterlace: libav Deinterlace element
libav: avmux_chromaprint: libav Chromaprint muxer
libav: avmux_yuv4mpegpipe: libav YUV4MPEG pipe muxer (not recommended, use y4menc instead)
libav: avmux_wtv: libav Windows Television (WTV) muxer
libav: avmux_webp: libav WebP muxer
libav: avmux_wav: libav WAV / WAVE (Waveform Audio) muxer (not recommended, use wavenc instead)
libav: avmux_w64: libav Sony Wave64 muxer
libav: avmux_voc: libav Creative Voice muxer
libav: avmux_vc1test: libav VC-1 test bitstream muxer
libav: avmux_uncodedframecrc: libav uncoded framecrc testing muxer
libav: avmux_tta: libav TTA (True Audio) muxer
libav: avmux_mkvtimestamp_v2: libav extract pts as timecode v2 format, as defined by mkvtoolnix muxer
libav: avmux_3gp: libav 3GP (3GPP file format) muxer (not recommended, use gppmux instead)
libav: avmux_3g2: libav 3GP2 (3GPP2 file format) muxer
libav: avmux_swf: libav SWF (ShockWave Flash) muxer
libav: avmux_spdif: libav IEC 61937 (used on S/PDIF - IEC958) muxer
libav: avmux_spx: libav Ogg Speex muxer
libav: avmux_sox: libav SoX native muxer
libav: avmux_smoothstreaming: libav Smooth Streaming Muxer muxer
libav: avmux_smjpeg: libav Loki SDL MJPEG muxer
libav: avmux_singlejpeg: libav JPEG single image muxer
libav: avmux_film_cpk: libav Sega FILM / CPK muxer
libav: avmux_sap: libav SAP output muxer
libav: avmux_rtsp: libav RTSP output muxer
libav: avmux_rso: libav Lego Mindstorms RSO muxer
libav: avmux_rm: libav RealMedia muxer
libav: avmux_psp: libav PSP MP4 (MPEG-4 Part 14) muxer
libav: avmux_vidc: libav PCM Archimedes VIDC muxer
libav: avmux_opus: libav Ogg Opus muxer
libav: avmux_oma: libav Sony OpenMG audio muxer
libav: avmux_ogv: libav Ogg Video muxer
libav: avmux_ogg: libav Ogg muxer (not recommended, use oggmux instead)
libav: avmux_oga: libav Ogg Audio muxer
libav: avmux_nut: libav NUT muxer
libav: avmux_mxf_opatom: libav MXF (Material eXchange Format) Operational Pattern Atom muxer
libav: avmux_mxf_d10: libav MXF (Material eXchange Format) D-10 Mapping muxer
libav: avmux_mxf: libav MXF (Material eXchange Format) muxer (not recommended, use mxfmux instead)
libav: avmux_mpjpeg: libav MIME multipart JPEG muxer (not recommended, use multipartmux instead)
libav: avmux_mpegts: libav MPEG-TS (MPEG-2 Transport Stream) muxer (not recommended, use mpegtsmux instead)
libav: avmux_vob: libav MPEG-2 PS (VOB) muxer
libav: avmux_svcd: libav MPEG-2 PS (SVCD) muxer
libav: avmux_dvd: libav MPEG-2 PS (DVD VOB) muxer
libav: avmux_vcd: libav MPEG-1 Systems / MPEG program stream (VCD) muxer
libav: avmux_mpeg: libav MPEG-1 Systems / MPEG program stream muxer
libav: avmux_mp4: libav MP4 (MPEG-4 Part 14) muxer (not recommended, use mp4mux instead)
libav: avmux_mp3: libav MP3 (MPEG audio layer 3) formatter (not recommended, use id3v2mux instead)
libav: avmux_mp2: libav MP2 (MPEG audio layer 2) formatter (not recommended, use id3v2mux instead)
libav: avmux_mov: libav QuickTime / MOV muxer (not recommended, use qtmux instead)
libav: avmux_mmf: libav Yamaha SMAF muxer
libav: avmux_matroska: libav Matroska muxer (not recommended, use matroskamux instead)
libav: avmux_md5: libav MD5 testing muxer
libav: avmux_latm: libav LOAS/LATM muxer
libav: avmux_ivf: libav On2 IVF muxer
libav: avmux_ismv: libav ISMV/ISMA (Smooth Streaming) muxer
libav: avmux_ircam: libav Berkeley/IRCAM/CARL Sound Format muxer
libav: avmux_ipod: libav iPod H.264 MP4 (MPEG-4 Part 14) muxer
libav: avmux_ilbc: libav iLBC storage muxer
libav: avmux_ico: libav Microsoft Windows ICO muxer
libav: avmux_hls: libav Apple HTTP Live Streaming muxer
libav: avmux_hds: libav HDS Muxer muxer
libav: avmux_hash: libav Hash testing muxer
libav: avmux_gxf: libav GXF (General eXchange Format) muxer
libav: avmux_flv: libav FLV (Flash Video) muxer (not recommended, use flvmux instead)
libav: avmux_fits: libav Flexible Image Transport System muxer
libav: avmux_filmstrip: libav Adobe Filmstrip muxer
libav: avmux_f4v: libav F4V Adobe Flash Video muxer
libav: avmux_dv: libav DV (Digital Video) muxer
libav: avmux_daud: libav D-Cinema audio muxer
libav: avmux_dash: libav DASH Muxer muxer
libav: avmux_codec2: libav codec2 .c2 muxer muxer
libav: avmux_caf: libav Apple CAF (Core Audio Format) muxer
libav: avmux_bit: libav G.729 BIT file format muxer
libav: avmux_avm2: libav SWF (ShockWave Flash) (AVM2) muxer
libav: avmux_avi: libav AVI (Audio Video Interleaved) muxer (not recommended, use avimux instead)
libav: avmux_au: libav Sun AU muxer
libav: avmux_asf_stream: libav ASF (Advanced / Active Streaming Format) muxer (not recommended, use asfmux instead)
libav: avmux_ast: libav AST (Audio Stream) muxer
libav: avmux_asf: libav ASF (Advanced / Active Streaming Format) muxer (not recommended, use asfmux instead)
libav: avmux_apng: libav Animated Portable Network Graphics muxer
libav: avmux_amr: libav 3GPP AMR muxer
libav: avmux_aiff: libav Audio IFF muxer (not recommended, use aiffmux instead)
libav: avmux_adx: libav CRI ADX muxer
libav: avmux_adts: libav ADTS AAC (Advanced Audio Coding) muxer (not recommended, use aacparse instead)
libav: avmux_a64: libav a64 - video for Commodore 64 muxer
libav: avtype_yuv4mpegpipe: y4m
libav: avdemux_yuv4mpegpipe: libav YUV4MPEG pipe demuxer
libav: avtype_wsvqa: no extensions
libav: avdemux_wsvqa: libav Westwood Studios VQA demuxer
libav: avtype_wsaud: no extensions
libav: avdemux_wsaud: libav Westwood Studios audio demuxer
libav: avtype_wc3movie: no extensions
libav: avdemux_wc3movie: libav Wing Commander III movie demuxer
libav: avdemux_voc: libav Creative Voice demuxer
libav: avtype_vmd: no extensions
libav: avdemux_vmd: libav Sierra VMD demuxer
libav: avdemux_tta: libav TTA (True Audio) demuxer
libav: avtype_psxstr: no extensions
libav: avdemux_psxstr: libav Sony Playstation STR demuxer
libav: avtype_sol: no extensions
libav: avdemux_sol: libav Sierra SOL demuxer
libav: avtype_smk: no extensions
libav: avdemux_smk: libav Smacker demuxer
libav: avtype_film_cpk: no extensions
libav: avdemux_film_cpk: libav Sega FILM / CPK demuxer
libav: avdemux_pva: libav TechnoTrend PVA demuxer
libav: avdemux_nuv: libav NuppelVideo demuxer
libav: avtype_nut: nut
libav: avdemux_nut: libav NUT demuxer
libav: avtype_nsv: no extensions
libav: avdemux_nsv: libav Nullsoft Streaming Video demuxer
libav: avdemux_mxf: libav MXF (Material eXchange Format) demuxer
libav: avdemux_mpc8: libav Musepack SV8 demuxer
libav: avdemux_mpc: libav Musepack demuxer
libav: avtype_mmf: no extensions
libav: avdemux_mmf: libav Yamaha SMAF demuxer
libav: avtype_mm: no extensions
libav: avdemux_mm: libav American Laser Games MM demuxer
libav: avdemux_ivf: libav On2 IVF demuxer
libav: avtype_ipmovie: no extensions
libav: avdemux_ipmovie: libav Interplay MVE demuxer
libav: avtype_iff: no extensions
libav: avdemux_iff: libav IFF (Interchange File Format) demuxer
libav: avtype_idcin: no extensions
libav: avdemux_idcin: libav id Cinematic demuxer
libav: avtype_gxf: no extensions
libav: avdemux_gxf: libav GXF (General eXchange Format) demuxer
libav: avdemux_gif: libav CompuServe Graphics Interchange Format (GIF) demuxer
libav: avtype_4xm: no extensions
libav: avdemux_4xm: libav 4X Technologies demuxer
libav: avtype_ea: no extensions
libav: avdemux_ea: libav Electronic Arts Multimedia demuxer
libav: avtype_dsf: no extensions
libav: avdemux_dsf: libav DSD Stream File (DSF) demuxer
libav: avtype_daud: 302, daud
libav: avdemux_daud: libav D-Cinema audio demuxer
libav: avtype_brstm: brstm
libav: avdemux_brstm: libav BRSTM (Binary Revolution Stream) demuxer
libav: avtype_bfstm: bfstm, bcstm
libav: avdemux_bfstm: libav BFSTM (Binary Cafe Stream) demuxer
libav: avtype_avs: no extensions
libav: avdemux_avs: libav Argonaut Games Creature Shock demuxer
libav: avdemux_ape: libav Monkey's Audio demuxer
libav: avdemux_aiff: libav Audio IFF demuxer
libav: avdec_idf: libav iCEDraw text decoder
libav: avdec_xbin: libav eXtended BINary text decoder
libav: avdec_bintext: libav Binary text decoder
libav: avdec_zmbv: libav Zip Motion Blocks Video decoder
libav: avdec_zerocodec: libav ZeroCodec Lossless Video decoder
libav: avdec_yop: libav Psygnosis YOP Video decoder
libav: avdec_ylc: libav YUY2 Lossless Codec decoder
libav: avdec_xwd: libav XWD (X Window Dump) image decoder
libav: avdec_xpm: libav XPM (X PixMap) image decoder
libav: avdec_xl: libav Miro VideoXL decoder
libav: avdec_xface: libav X-face image decoder
libav: avdec_xbm: libav XBM (X BitMap) image decoder
libav: avdec_xan_wc4: libav Wing Commander IV / Xxan decoder
libav: avdec_xan_wc3: libav Wing Commander III / Xan decoder
libav: avdec_wnv1: libav Winnov WNV1 decoder
libav: avdec_wmv3image: libav Windows Media Video 9 Image decoder
libav: avdec_wmv3: libav Windows Media Video 9 decoder
libav: avdec_wmv2: libav Windows Media Video 8 decoder
libav: avdec_wmv1: libav Windows Media Video 7 decoder
libav: avdec_wcmv: libav WinCAM Motion Video decoder
libav: avdec_webp: libav WebP image decoder
libav: avdec_vqavideo: libav Westwood Studios VQA (Vector Quantized Animation) video decoder
libav: avdec_vp9: libav Google VP9 decoder
libav: avdec_vp8: libav On2 VP8 decoder
libav: avdec_vp7: libav On2 VP7 decoder
libav: avdec_vp6f: libav On2 VP6 (Flash version) decoder
libav: avdec_vp6a: libav On2 VP6 (Flash version, with alpha channel) decoder
libav: avdec_vp6: libav On2 VP6 decoder
libav: avdec_vp5: libav On2 VP5 decoder
libav: avdec_vp4: libav On2 VP4 decoder
libav: avdec_vp3: libav On2 VP3 decoder
libav: avdec_vmnc: libav VMware Screen Codec / VMware Video decoder
libav: avdec_vmdvideo: libav Sierra VMD video decoder
libav: avdec_vcr1: libav ATI VCR1 decoder
libav: avdec_vc1image: libav Windows Media Video 9 Image v2 decoder
libav: avdec_vc1: libav SMPTE VC-1 decoder
libav: avdec_vble: libav VBLE Lossless Codec decoder
libav: avdec_vb: libav Beam Software VB decoder
libav: avdec_utvideo: libav Ut Video decoder
libav: avdec_ultimotion: libav IBM UltiMotion decoder
libav: avdec_txd: libav Renderware TXD (TeXture Dictionary) image decoder
libav: avdec_tscc2: libav TechSmith Screen Codec 2 decoder
libav: avdec_camtasia: libav TechSmith Screen Capture Codec decoder
libav: avdec_truemotion2rt: libav Duck TrueMotion 2.0 Real Time decoder
libav: avdec_truemotion2: libav Duck TrueMotion 2.0 decoder
libav: avdec_truemotion1: libav Duck TrueMotion 1.0 decoder
libav: avdec_tmv: libav 8088flex TMV decoder
libav: avdec_tiff: libav TIFF image decoder
libav: avdec_tiertexseqvideo: libav Tiertex Limited SEQ video decoder
libav: avdec_thp: libav Nintendo Gamecube THP video decoder
libav: avdec_tdsc: libav TDSC decoder
libav: avdec_targa_y216: libav Pinnacle TARGA CineWave YUV16 decoder
libav: avdec_targa: libav Truevision Targa image decoder
libav: avdec_svq3: libav Sorenson Vector Quantizer 3 / Sorenson Video 3 / SVQ3 decoder
libav: avdec_svq1: libav Sorenson Vector Quantizer 1 / Sorenson Video 1 / SVQ1 decoder
libav: avdec_sunrast: libav Sun Rasterfile image decoder
libav: avdec_srgc: libav Screen Recorder Gold Codec decoder
libav: avdec_speedhq: libav NewTek SpeedHQ decoder
libav: avdec_sp5x: libav Sunplus JPEG (SP5X) decoder
libav: avdec_snow: libav Snow decoder
libav: avdec_smvjpeg: libav SMV JPEG decoder
libav: avdec_smc: libav QuickTime Graphics (SMC) decoder
libav: avdec_smackvid: libav Smacker video decoder
libav: avdec_sheervideo: libav BitJazz SheerVideo decoder
libav: avdec_sgirle: libav Silicon Graphics RLE 8-bit video decoder
libav: avdec_sgi: libav SGI image decoder
libav: avdec_screenpresso: libav Screenpresso decoder
libav: avdec_scpr: libav ScreenPressor decoder
libav: avdec_sanm: libav LucasArts SANM/Smush video decoder
libav: avdec_rv40: libav RealVideo 4.0 decoder
libav: avdec_rv30: libav RealVideo 3.0 decoder
libav: avdec_rv20: libav RealVideo 2.0 decoder
libav: avdec_rv10: libav RealVideo 1.0 decoder
libav: avdec_rscc: libav innoHeim/Rsupport Screen Capture Codec decoder
libav: avdec_rpza: libav QuickTime video (RPZA) decoder
libav: avdec_roqvideo: libav id RoQ video decoder
libav: avdec_rl2: libav RL2 video decoder
libav: avdec_rasc: libav RemotelyAnywhere Screen Capture decoder
libav: avdec_r10k: libav AJA Kona 10-bit RGB Codec decoder
libav: avdec_qtrle: libav QuickTime Animation (RLE) video decoder
libav: avdec_qpeg: libav Q-team QPEG decoder
libav: avdec_qdraw: libav Apple QuickDraw decoder
libav: avdec_ptx: libav V.Flash PTX image decoder
libav: avdec_psd: libav Photoshop PSD file decoder
libav: avdec_prosumer: libav Brooktree ProSumer Video decoder
libav: avdec_prores: libav ProRes (iCodec Pro) decoder
libav: avdec_ppm: libav PPM (Portable PixelMap) image decoder
libav: avdec_png: libav PNG (Portable Network Graphics) image decoder
libav: avdec_pixlet: libav Apple Pixlet decoder
libav: avdec_pictor: libav Pictor/PC Paint decoder
libav: avdec_pgmyuv: libav PGMYUV (Portable GrayMap YUV) image decoder
libav: avdec_pgm: libav PGM (Portable GrayMap) image decoder
libav: avdec_pcx: libav PC Paintbrush PCX image decoder
libav: avdec_pbm: libav PBM (Portable BitMap) image decoder
libav: avdec_pam: libav PAM (Portable AnyMap) image decoder
libav: avdec_paf_video: libav Amazing Studio Packed Animation File Video decoder
libav: avdec_nuv: libav NuppelVideo/RTJPEG decoder
libav: avdec_mxpeg: libav Mobotix MxPEG video decoder
libav: avdec_mwsc: libav MatchWare Screen Capture Codec decoder
libav: avdec_mvc2: libav Silicon Graphics Motion Video Compressor 2 decoder
libav: avdec_mvc1: libav Silicon Graphics Motion Video Compressor 1 decoder
libav: avdec_mts2: libav MS Expression Encoder Screen decoder
libav: avdec_mszh: libav LCL (LossLess Codec Library) MSZH decoder
libav: avdec_msvideo1: libav Microsoft Video 1 decoder
libav: avdec_mss2: libav MS Windows Media Video V9 Screen decoder
libav: avdec_mss1: libav MS Screen 1 decoder
libav: avdec_msrle: libav Microsoft RLE decoder
libav: avdec_msmpeg4: libav MPEG-4 part 2 Microsoft variant version 3 decoder
libav: avdec_msmpeg4v2: libav MPEG-4 part 2 Microsoft variant version 2 decoder
libav: avdec_msmpeg4v1: libav MPEG-4 part 2 Microsoft variant version 1 decoder
libav: avdec_mscc: libav Mandsoft Screen Capture Codec decoder
libav: avdec_msa1: libav MS ATC Screen decoder
libav: avdec_mpegvideo: libav MPEG-1 video decoder
libav: avdec_mpeg4: libav MPEG-4 part 2 decoder
libav: avdec_mpeg2video: libav MPEG-2 video decoder
libav: avdec_motionpixels: libav Motion Pixels video decoder
libav: avdec_mmvideo: libav American Laser Games MM Video decoder
libav: avdec_mjpegb: libav Apple MJPEG-B decoder
libav: avdec_mjpeg: libav MJPEG (Motion JPEG) decoder
libav: avdec_mimic: libav Mimic decoder
libav: avdec_mdec: libav Sony PlayStation MDEC (Motion DECoder) decoder
libav: avdec_magicyuv: libav MagicYUV video decoder
libav: avdec_m101: libav Matrox Uncompressed SD decoder
libav: avdec_lscr: libav LEAD Screen Capture decoder
libav: avdec_loco: libav LOCO decoder
libav: avdec_lagarith: libav Lagarith lossless decoder
libav: avdec_kmvc: libav Karl Morton's video codec decoder
libav: avdec_kgv1: libav Kega Game Video decoder
libav: avdec_jv: libav Bitmap Brothers JV video decoder
libav: avdec_jpegls: libav JPEG-LS decoder
libav: avdec_jpeg2000: libav JPEG 2000 decoder
libav: avdec_interplayvideo: libav Interplay MVE video decoder
libav: avdec_indeo5: libav Intel Indeo Video Interactive 5 decoder
libav: avdec_indeo4: libav Intel Indeo Video Interactive 4 decoder
libav: avdec_indeo3: libav Intel Indeo 3 decoder
libav: avdec_indeo2: libav Intel Indeo 2 decoder
libav: avdec_imm4: libav Infinity IMM4 decoder
libav: avdec_iff: libav IFF ACBM/ANIM/DEEP/ILBM/PBM/RGB8/RGBN decoder
libav: avdec_idcinvideo: libav id Quake II CIN video decoder
libav: avdec_hymt: libav HuffYUV MT decoder
libav: avdec_huffyuv: libav Huffyuv / HuffYUV decoder
libav: avdec_hqx: libav Canopus HQX decoder
libav: avdec_hq_hqa: libav Canopus HQ/HQA decoder
libav: avdec_hnm4video: libav HNM 4 video decoder
libav: avdec_h265: libav HEVC (High Efficiency Video Coding) decoder
libav: avdec_hap: libav Vidvox Hap decoder
libav: avdec_h264: libav H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 decoder
libav: avdec_h263p: libav H.263 / H.263-1996, H.263+ / H.263-1998 / H.263 version 2 decoder
libav: avdec_h263i: libav Intel H.263 decoder
libav: avdec_h263: libav H.263 / H.263-1996, H.263+ / H.263-1998 / H.263 version 2 decoder
libav: avdec_h261: libav H.261 decoder
libav: avdec_gif: libav GIF (Graphics Interchange Format) decoder
libav: avdec_gdv: libav Gremlin Digital Video decoder
libav: avdec_g2m: libav Go2Meeting decoder
libav: avdec_frwu: libav Forward Uncompressed decoder
libav: avdec_fraps: libav Fraps decoder
libav: avdec_4xm: libav 4X Movie decoder
libav: avdec_fmvc: libav FM Screen Capture Codec decoder
libav: avdec_flv: libav FLV / Sorenson Spark / Sorenson H.263 (Flash Video) decoder
libav: avdec_flic: libav Autodesk Animator Flic video decoder
libav: avdec_flashsv2: libav Flash Screen Video v2 decoder
libav: avdec_flashsv: libav Flash Screen Video v1 decoder
libav: avdec_fits: libav Flexible Image Transport System decoder
libav: avdec_fic: libav Mirillis FIC decoder
libav: avdec_ffvhuff: libav Huffyuv FFmpeg variant decoder
libav: avdec_ffv1: libav FFmpeg video codec #1 decoder
libav: avdec_exr: libav OpenEXR image decoder
libav: avdec_escape130: libav Escape 130 decoder
libav: avdec_escape124: libav Escape 124 decoder
libav: avdec_8bps: libav QuickTime 8BPS video decoder
libav: avdec_eatqi: libav Electronic Arts TQI Video decoder
libav: avdec_eatgv: libav Electronic Arts TGV video decoder
libav: avdec_eatgq: libav Electronic Arts TGQ video decoder
libav: avdec_eamad: libav Electronic Arts Madcow Video decoder
libav: avdec_eacmv: libav Electronic Arts CMV video decoder
libav: avdec_dxv: libav Resolume DXV decoder
libav: avdec_dxtory: libav Dxtory decoder
libav: avdec_dxa: libav Feeble Files/ScummVM DXA decoder
libav: avdec_dvvideo: libav DV (Digital Video) decoder
libav: avdec_dsicinvideo: libav Delphine Software International CIN video decoder
libav: avdec_dpx: libav DPX (Digital Picture Exchange) image decoder
libav: avdec_dnxhd: libav VC3/DNxHD decoder
libav: avdec_dirac: libav BBC Dirac VC-2 decoder
libav: avdec_dfa: libav Chronomaster DFA decoder
libav: avdec_dds: libav DirectDraw Surface image decoder decoder
libav: avdec_cyuv: libav Creative YUV (CYUV) decoder
libav: avdec_camstudio: libav CamStudio decoder
libav: avdec_cpia: libav CPiA video format decoder
libav: avdec_cllc: libav Canopus Lossless Codec decoder
libav: avdec_cljr: libav Cirrus Logic AccuPak decoder
libav: avdec_clearvideo: libav Iterated Systems ClearVideo decoder
libav: avdec_cinepak: libav Cinepak decoder
libav: avdec_cfhd: libav Cineform HD decoder
libav: avdec_cdxl: libav Commodore CDXL video decoder
libav: avdec_cdgraphics: libav CD Graphics video decoder
libav: avdec_cavs: libav Chinese AVS (Audio Video Standard) (AVS1-P2, JiZhun profile) decoder
libav: avdec_c93: libav Interplay C93 decoder
libav: avdec_brender_pix: libav BRender PIX image decoder
libav: avdec_bmv_video: libav Discworld II BMV video decoder
libav: avdec_bmp: libav BMP (Windows and OS/2 bitmap) decoder
libav: avdec_bitpacked: libav Bitpacked decoder
libav: avdec_binkvideo: libav Bink video decoder
libav: avdec_bfi: libav Brute Force & Ignorance decoder
libav: avdec_bethsoftvid: libav Bethesda VID video decoder
libav: avdec_avui: libav Avid Meridien Uncompressed decoder
libav: avdec_avs: libav AVS (Audio Video Standard) video decoder
libav: avdec_avrn: libav Avid AVI Codec decoder
libav: avdec_avrp: libav Avid 1:1 10-bit RGB Packer decoder
libav: avdec_aura2: libav Auravision Aura 2 decoder
libav: avdec_aura: libav Auravision AURA decoder
libav: avdec_asv2: libav ASUS V2 decoder
libav: avdec_asv1: libav ASUS V1 decoder
libav: avdec_arbc: libav Gryphon's Anim Compressor decoder
libav: avdec_apng: libav APNG (Animated Portable Network Graphics) image decoder
libav: avdec_ansi: libav ASCII/ANSI art decoder
libav: avdec_anm: libav Deluxe Paint Animation decoder
libav: avdec_amv: libav AMV Video decoder
libav: avdec_agm: libav Amuse Graphics Movie decoder
libav: avdec_alias_pix: libav Alias/Wavefront PIX image decoder
libav: avdec_aic: libav Apple Intermediate Codec decoder
libav: avdec_aasc: libav Autodesk RLE decoder
libav: avdec_adpcm_yamaha: libav ADPCM Yamaha decoder
libav: avdec_adpcm_xa: libav ADPCM CDROM XA decoder
libav: avdec_adpcm_vima: libav LucasArts VIMA audio decoder
libav: avdec_adpcm_thp_le: libav ADPCM Nintendo THP (little-endian) decoder
libav: avdec_adpcm_thp: libav ADPCM Nintendo THP decoder
libav: avdec_adpcm_swf: libav ADPCM Shockwave Flash decoder
libav: avdec_adpcm_sbpro_4: libav ADPCM Sound Blaster Pro 4-bit decoder
libav: avdec_adpcm_sbpro_3: libav ADPCM Sound Blaster Pro 2.6-bit decoder
libav: avdec_adpcm_sbpro_2: libav ADPCM Sound Blaster Pro 2-bit decoder
libav: avdec_adpcm_psx: libav ADPCM Playstation decoder
libav: avdec_adpcm_mtaf: libav ADPCM MTAF decoder
libav: avdec_adpcm_ms: libav ADPCM Microsoft decoder
libav: avdec_adpcm_ima_ws: libav ADPCM IMA Westwood decoder
libav: avdec_adpcm_ima_wav: libav ADPCM IMA WAV decoder
libav: avdec_adpcm_ima_smjpeg: libav ADPCM IMA Loki SDL MJPEG decoder
libav: avdec_adpcm_ima_rad: libav ADPCM IMA Radical decoder
libav: avdec_adpcm_ima_qt: libav ADPCM IMA QuickTime decoder
libav: avdec_adpcm_ima_oki: libav ADPCM IMA Dialogic OKI decoder
libav: avdec_adpcm_ima_iss: libav ADPCM IMA Funcom ISS decoder
libav: avdec_adpcm_ima_ea_sead: libav ADPCM IMA Electronic Arts SEAD decoder
libav: avdec_adpcm_ima_ea_eacs: libav ADPCM IMA Electronic Arts EACS decoder
libav: avdec_adpcm_ima_dk4: libav ADPCM IMA Duck DK4 decoder
libav: avdec_adpcm_ima_dk3: libav ADPCM IMA Duck DK3 decoder
libav: avdec_adpcm_ima_dat4: libav ADPCM IMA Eurocom DAT4 decoder
libav: avdec_adpcm_ima_apc: libav ADPCM IMA CRYO APC decoder
libav: avdec_adpcm_ima_amv: libav ADPCM IMA AMV decoder
libav: avdec_g726le: libav G.726 ADPCM little-endian decoder
libav: avdec_g726: libav G.726 ADPCM decoder
libav: avdec_g722: libav G.722 ADPCM decoder
libav: avdec_adpcm_ea_xas: libav ADPCM Electronic Arts XAS decoder
libav: avdec_adpcm_ea_r3: libav ADPCM Electronic Arts R3 decoder
libav: avdec_adpcm_ea_r2: libav ADPCM Electronic Arts R2 decoder
libav: avdec_adpcm_ea_r1: libav ADPCM Electronic Arts R1 decoder
libav: avdec_adpcm_ea_maxis_xa: libav ADPCM Electronic Arts Maxis CDROM XA decoder
libav: avdec_adpcm_ea: libav ADPCM Electronic Arts decoder
libav: avdec_adpcm_dtk: libav ADPCM Nintendo Gamecube DTK decoder
libav: avdec_adpcm_ct: libav ADPCM Creative Technology decoder
libav: avdec_adpcm_aica: libav ADPCM Yamaha AICA decoder
libav: avdec_adpcm_agm: libav ADPCM AmuseGraphics Movie decoder
libav: avdec_adpcm_afc: libav ADPCM Nintendo Gamecube AFC decoder
libav: avdec_adpcm_adx: libav SEGA CRI ADX ADPCM decoder
libav: avdec_adpcm_4xm: libav ADPCM 4X Movie decoder
libav: avdec_xan_dpcm: libav DPCM Xan decoder
libav: avdec_sol_dpcm: libav DPCM Sol decoder
libav: avdec_roq_dpcm: libav DPCM id RoQ decoder
libav: avdec_interplay_dpcm: libav DPCM Interplay decoder
libav: avdec_gremlin_dpcm: libav DPCM Gremlin decoder
libav: avdec_pcm_vidc: libav PCM Archimedes VIDC decoder
libav: avdec_pcm_lxf: libav PCM signed 20-bit little-endian planar decoder
libav: avdec_xma2: libav Xbox Media Audio 2 decoder
libav: avdec_xma1: libav Xbox Media Audio 1 decoder
libav: avdec_ws_snd1: libav Westwood Audio (SND1) decoder
libav: avdec_wmavoice: libav Windows Media Audio Voice decoder
libav: avdec_wmav2: libav Windows Media Audio 2 decoder
libav: avdec_wmav1: libav Windows Media Audio 1 decoder
libav: avdec_wmapro: libav Windows Media Audio 9 Professional decoder
libav: avdec_wmalossless: libav Windows Media Audio Lossless decoder
libav: avdec_vmdaudio: libav Sierra VMD audio decoder
libav: avdec_twinvq: libav VQF TwinVQ decoder
libav: avdec_tta: libav TTA (True Audio) decoder
libav: avdec_truespeech: libav DSP Group TrueSpeech decoder
libav: avdec_truehd: libav TrueHD decoder
libav: avdec_tak: libav TAK (Tom's lossless Audio Kompressor) decoder
libav: avdec_sonic: libav Sonic decoder
libav: avdec_smackaud: libav Smacker audio decoder
libav: avdec_sipr: libav RealAudio SIPR / ACELP.NET decoder
libav: avdec_shorten: libav Shorten decoder
libav: avdec_sbc: libav SBC (low-complexity subband codec) decoder
libav: avdec_ralf: libav RealAudio Lossless decoder
libav: avdec_real_288: libav RealAudio 2.0 (28.8K) decoder
libav: avdec_real_144: libav RealAudio 1.0 (14.4K) decoder
libav: avdec_qdmc: libav QDesign Music Codec 1 decoder
libav: avdec_qdm2: libav QDesign Music Codec 2 decoder
libav: avdec_qcelp: libav QCELP / PureVoice decoder
libav: avdec_paf_audio: libav Amazing Studio Packed Animation File Audio decoder
libav: avdec_opus: libav Opus decoder
libav: avdec_on2avc: libav On2 Audio for Video Codec decoder
libav: avdec_nellymoser: libav Nellymoser Asao decoder
libav: avdec_mpc8: libav Musepack SV8 decoder
libav: avdec_mpc7: libav Musepack SV7 decoder
libav: avdec_mp3on4: libav MP3onMP4 decoder
libav: avdec_mp3on4float: libav MP3onMP4 decoder
libav: avdec_mp3adu: libav ADU (Application Data Unit) MP3 (MPEG audio layer 3) decoder
libav: avdec_mp3adufloat: libav ADU (Application Data Unit) MP3 (MPEG audio layer 3) decoder
libav: avdec_mp3: libav MP3 (MPEG audio layer 3) decoder
libav: avdec_mp3float: libav MP3 (MPEG audio layer 3) decoder
libav: avdec_mp2float: libav MP2 (MPEG audio layer 2) decoder
libav: avdec_mp1float: libav MP1 (MPEG audio layer 1) decoder
libav: avdec_mlp: libav MLP (Meridian Lossless Packing) decoder
libav: avdec_metasound: libav Voxware MetaSound decoder
libav: avdec_mace6: libav MACE (Macintosh Audio Compression/Expansion) 6:1 decoder
libav: avdec_mace3: libav MACE (Macintosh Audio Compression/Expansion) 3:1 decoder
libav: avdec_interplayacm: libav Interplay ACM decoder
libav: avdec_imc: libav IMC (Intel Music Coder) decoder
libav: avdec_ilbc: libav iLBC (Internet Low Bitrate Codec) decoder
libav: avdec_iac: libav IAC (Indeo Audio Coder) decoder
libav: avdec_hcom: libav HCOM Audio decoder
libav: avdec_gsm_ms: libav GSM Microsoft variant decoder
libav: avdec_gsm: libav GSM decoder
libav: avdec_g729: libav G.729 decoder
libav: avdec_g723_1: libav G.723.1 decoder
libav: avdec_flac: libav FLAC (Free Lossless Audio Codec) decoder
libav: avdec_wavesynth: libav Wave synthesis pseudo-codec decoder
libav: avdec_evrc: libav EVRC (Enhanced Variable Rate Codec) decoder
libav: avdec_eac3: libav ATSC A/52B (AC-3, E-AC-3) decoder
libav: avdec_dst: libav DST (Digital Stream Transfer) decoder
libav: avdec_dss_sp: libav Digital Speech Standard - Standard Play mode (DSS SP) decoder
libav: avdec_dsicinaudio: libav Delphine Software International CIN audio decoder
libav: avdec_dsd_msbf_planar: libav DSD (Direct Stream Digital), most significant bit first, planar decoder
libav: avdec_dsd_lsbf_planar: libav DSD (Direct Stream Digital), least significant bit first, planar decoder
libav: avdec_dsd_msbf: libav DSD (Direct Stream Digital), most significant bit first decoder
libav: avdec_dsd_lsbf: libav DSD (Direct Stream Digital), least significant bit first decoder
libav: avdec_dolby_e: libav Dolby E decoder
libav: avdec_dca: libav DCA (DTS Coherent Acoustics) decoder
libav: avdec_cook: libav Cook / Cooker / Gecko (RealAudio G2) decoder
libav: avdec_bmv_audio: libav Discworld II BMV audio decoder
libav: avdec_binkaudio_rdft: libav Bink Audio (RDFT) decoder
libav: avdec_binkaudio_dct: libav Bink Audio (DCT) decoder
libav: avdec_atrac9: libav ATRAC9 (Adaptive TRansform Acoustic Coding 9) decoder
libav: avdec_atrac3plusal: libav ATRAC3+ AL (Adaptive TRansform Acoustic Coding 3+ Advanced Lossless) decoder
libav: avdec_atrac3plus: libav ATRAC3+ (Adaptive TRansform Acoustic Coding 3+) decoder
libav: avdec_atrac3al: libav ATRAC3 AL (Adaptive TRansform Acoustic Coding 3 Advanced Lossless) decoder
libav: avdec_atrac3: libav ATRAC3 (Adaptive TRansform Acoustic Coding 3) decoder
libav: avdec_atrac1: libav ATRAC1 (Adaptive TRansform Acoustic Coding) decoder
libav: avdec_aptx_hd: libav aptX HD (Audio Processing Technology for Bluetooth) decoder
libav: avdec_aptx: libav aptX (Audio Processing Technology for Bluetooth) decoder
libav: avdec_ape: libav Monkey's Audio decoder
libav: avdec_amrwb: libav AMR-WB (Adaptive Multi-Rate WideBand) decoder
libav: avdec_amrnb: libav AMR-NB (Adaptive Multi-Rate NarrowBand) decoder
libav: avdec_als: libav MPEG-4 Audio Lossless Coding (ALS) decoder
libav: avdec_alac: libav ALAC (Apple Lossless Audio Codec) decoder
libav: avdec_ac3_fixed: libav ATSC A/52A (AC-3) decoder
libav: avdec_ac3: libav ATSC A/52A (AC-3) decoder
libav: avdec_aac_latm: libav AAC LATM (Advanced Audio Coding LATM syntax) decoder
libav: avdec_aac_fixed: libav AAC (Advanced Audio Coding) decoder
libav: avdec_aac: libav AAC (Advanced Audio Coding) decoder
libav: avdec_sdx2_dpcm: libav DPCM Squareroot-Delta-Exact decoder
libav: avdec_s302m: libav SMPTE 302M decoder
libav: avdec_8svx_fib: libav 8SVX fibonacci decoder
libav: avdec_8svx_exp: libav 8SVX exponential decoder
libav: avdec_dvaudio: libav Ulead DV Audio decoder
libav: avdec_comfortnoise: libav RFC 3389 comfort noise generator decoder
libav: avenc_h264_omx: libav OpenMAX IL H.264 video encoder encoder
libav: avenc_zmbv: libav Zip Motion Blocks Video encoder
libav: avenc_xwd: libav XWD (X Window Dump) image encoder
libav: avenc_xface: libav X-face image encoder
libav: avenc_xbm: libav XBM (X BitMap) image encoder
libav: avenc_wmv2: libav Windows Media Video 8 encoder
libav: avenc_wmv1: libav Windows Media Video 7 encoder
libav: avenc_vc2: libav SMPTE VC-2 encoder
libav: avenc_utvideo: libav Ut Video encoder
libav: avenc_tiff: libav TIFF image encoder
libav: avenc_targa: libav Truevision Targa image encoder
libav: avenc_svq1: libav Sorenson Vector Quantizer 1 / Sorenson Video 1 / SVQ1 encoder
libav: avenc_sunrast: libav Sun Rasterfile image encoder
libav: avenc_snow: libav Snow encoder
libav: avenc_sgi: libav SGI image encoder
libav: avenc_rv20: libav RealVideo 2.0 encoder
libav: avenc_rv10: libav RealVideo 1.0 encoder
libav: avenc_roqvideo: libav id RoQ video encoder
libav: avenc_r10k: libav AJA Kona 10-bit RGB Codec encoder
libav: avenc_qtrle: libav QuickTime Animation (RLE) video encoder
libav: avenc_prores_ks: libav Apple ProRes (iCodec Pro) encoder
libav: avenc_prores_aw: libav Apple ProRes encoder
libav: avenc_prores: libav Apple ProRes encoder
libav: avenc_ppm: libav PPM (Portable PixelMap) image encoder
libav: avenc_png: libav PNG (Portable Network Graphics) image encoder
libav: avenc_pgmyuv: libav PGMYUV (Portable GrayMap YUV) image encoder
libav: avenc_pgm: libav PGM (Portable GrayMap) image encoder
libav: avenc_pcx: libav PC Paintbrush PCX image encoder
libav: avenc_pbm: libav PBM (Portable BitMap) image encoder
libav: avenc_pam: libav PAM (Portable AnyMap) image encoder
libav: avenc_msvideo1: libav Microsoft Video-1 encoder
libav: avenc_msmpeg4: libav MPEG-4 part 2 Microsoft variant version 3 encoder
libav: avenc_msmpeg4v2: libav MPEG-4 part 2 Microsoft variant version 2 encoder
libav: avenc_mpeg4: libav MPEG-4 part 2 encoder
libav: avenc_mpeg2video: libav MPEG-2 video encoder
libav: avenc_mpeg1video: libav MPEG-1 video encoder
libav: avenc_mjpeg: libav MJPEG (Motion JPEG) encoder
libav: avenc_magicyuv: libav MagicYUV video encoder
libav: avenc_ljpeg: libav Lossless JPEG encoder
libav: avenc_jpegls: libav JPEG-LS encoder
libav: avenc_jpeg2000: libav JPEG 2000 encoder
libav: avenc_huffyuv: libav Huffyuv / HuffYUV encoder
libav: avenc_hap: libav Vidvox Hap encoder
libav: avenc_h263p: libav H.263+ / H.263-1998 / H.263 version 2 encoder
libav: avenc_h263: libav H.263 / H.263-1996 encoder
libav: avenc_h261: libav H.261 encoder
libav: avenc_flv: libav FLV / Sorenson Spark / Sorenson H.263 (Flash Video) encoder
libav: avenc_flashsv2: libav Flash Screen Video Version 2 encoder
libav: avenc_flashsv: libav Flash Screen Video encoder
libav: avenc_fits: libav Flexible Image Transport System encoder
libav: avenc_ffvhuff: libav Huffyuv FFmpeg variant encoder
libav: avenc_ffv1: libav FFmpeg video codec #1 encoder
libav: avenc_dvvideo: libav DV (Digital Video) encoder
libav: avenc_dpx: libav DPX (Digital Picture Exchange) image encoder
libav: avenc_dnxhd: libav VC3/DNxHD encoder
libav: avenc_cljr: libav Cirrus Logic AccuPak encoder
libav: avenc_cinepak: libav Cinepak encoder
libav: avenc_bmp: libav BMP (Windows and OS/2 bitmap) encoder
libav: avenc_avui: libav Avid Meridien Uncompressed encoder
libav: avenc_avrp: libav Avid 1:1 10-bit RGB Packer encoder
libav: avenc_asv2: libav ASUS V2 encoder
libav: avenc_asv1: libav ASUS V1 encoder
libav: avenc_apng: libav APNG (Animated Portable Network Graphics) image encoder
libav: avenc_amv: libav AMV Video encoder
libav: avenc_alias_pix: libav Alias/Wavefront PIX image encoder
libav: avenc_a64multi5: libav Multicolor charset for Commodore 64, extended with 5th color (colram) encoder
libav: avenc_a64multi: libav Multicolor charset for Commodore 64 encoder
libav: avenc_adpcm_yamaha: libav ADPCM Yamaha encoder
libav: avenc_adpcm_swf: libav ADPCM Shockwave Flash encoder
libav: avenc_adpcm_ms: libav ADPCM Microsoft encoder
libav: avenc_adpcm_ima_wav: libav ADPCM IMA WAV encoder
libav: avenc_adpcm_ima_qt: libav ADPCM IMA QuickTime encoder
libav: avenc_g726le: libav G.726 little endian ADPCM ("right-justified") encoder
libav: avenc_g726: libav G.726 ADPCM encoder
libav: avenc_g722: libav G.722 ADPCM encoder
libav: avenc_adpcm_adx: libav SEGA CRI ADX ADPCM encoder
libav: avenc_roq_dpcm: libav id RoQ DPCM encoder
libav: avenc_pcm_vidc: libav PCM Archimedes VIDC encoder
libav: avenc_wmav2: libav Windows Media Audio 2 encoder
libav: avenc_wmav1: libav Windows Media Audio 1 encoder
libav: avenc_wavpack: libav WavPack encoder
libav: avenc_tta: libav TTA (True Audio) encoder
libav: avenc_truehd: libav TrueHD encoder
libav: avenc_sonicls: libav Sonic lossless encoder
libav: avenc_sonic: libav Sonic encoder
libav: avenc_sbc: libav SBC (low-complexity subband codec) encoder
libav: avenc_real_144: libav RealAudio 1.0 (14.4K) encoder
libav: avenc_opus: libav Opus encoder
libav: avenc_nellymoser: libav Nellymoser Asao encoder
libav: avenc_mp2fixed: libav MP2 fixed point (MPEG audio layer 2) encoder
libav: avenc_mp2: libav MP2 (MPEG audio layer 2) encoder
libav: avenc_mlp: libav MLP (Meridian Lossless Packing) encoder
libav: avenc_g723_1: libav G.723.1 encoder
libav: avenc_eac3: libav ATSC A/52 E-AC-3 encoder
libav: avenc_dca: libav DCA (DTS Coherent Acoustics) encoder
libav: avenc_aptx_hd: libav aptX HD (Audio Processing Technology for Bluetooth) encoder
libav: avenc_aptx: libav aptX (Audio Processing Technology for Bluetooth) encoder
libav: avenc_alac: libav ALAC (Apple Lossless Audio Codec) encoder
libav: avenc_ac3_fixed: libav ATSC A/52A (AC-3) encoder
libav: avenc_ac3: libav ATSC A/52A (AC-3) encoder
libav: avenc_aac: libav AAC (Advanced Audio Coding) encoder
libav: avenc_s302m: libav SMPTE 302M encoder
libav: avenc_comfortnoise: libav RFC 3389 comfort noise generator encoder
faad: faad: AAC audio decoder
videoscale: videoscale: Video scaler
fluidsynthmidi: fluiddec: Fluidsynth
ivtc: combdetect: Comb Detect
ivtc: ivtc: Inverse Telecine
videomixer: videomixer: Video mixer 2
dv: dvdec: DV video decoder
dv: dvdemux: DV system stream demuxer
coreelements: streamiddemux: Streamid Demux
coreelements: valve: Valve element
coreelements: multiqueue: MultiQueue
coreelements: typefind: TypeFind
coreelements: tee: Tee pipe fitting
coreelements: filesink: File Sink
coreelements: queue2: Queue 2
coreelements: queue: Queue
coreelements: output-selector: Output selector
coreelements: input-selector: Input selector
coreelements: identity: Identity
coreelements: funnel: Funnel pipe fitting
coreelements: filesrc: File Source
coreelements: fdsink: Filedescriptor Sink
coreelements: fdsrc: Filedescriptor Source
coreelements: fakesink: Fake Sink
coreelements: fakesrc: Fake Source
coreelements: downloadbuffer: DownloadBuffer
coreelements: dataurisrc: data: URI source element
coreelements: concat: Concat
coreelements: capsfilter: CapsFilter
adder: adder: Adder
aasink: aasink: ASCII art video sink
videoparsersbad: vc1parse: VC1 parser
videoparsersbad: h265parse: H.265 parser
videoparsersbad: jpeg2000parse: JPEG 2000 parser
videoparsersbad: pngparse: PNG parser
videoparsersbad: mpeg4videoparse: MPEG 4 video elementary stream parser
videoparsersbad: mpegvideoparse: MPEG video elementary stream parser
videoparsersbad: diracparse: Dirac parser
videoparsersbad: h264parse: H.264 parser
videoparsersbad: h263parse: H.263 parser
pcapparse: irtspparse: IRTSPParse
pcapparse: pcapparse: PCapParse
a52dec: a52dec: ATSC A/52 audio decoder
webp: webpenc: WEBP image encoder
webp: webpdec: WebP image decoder
wavpack: wavpackenc: Wavpack audio encoder
wavpack: wavpackdec: Wavpack audio decoder
alaw: alawdec: A Law audio decoder
alaw: alawenc: A Law audio encoder
audiorate: audiorate: Audio rate adjuster
gaudieffects: gaussianblur: GstGaussianBlur
gaudieffects: solarize: Solarize
gaudieffects: exclusion: Exclusion
gaudieffects: dodge: Dodge
gaudieffects: dilate: Dilate
gaudieffects: chromium: Chromium
gaudieffects: burn: Burn
sdpelem: sdpsrc: SDP Source
sdpelem: sdpdemux: SDP session setup
dvdsub: dvdsubparse: DVD subtitle parser
dvdsub: dvdsubdec: DVD subtitle decoder
voaacenc: voaacenc: AAC audio encoder
goom2k1: goom2k1: GOOM: what a GOOM! 2k1 edition
gdkpixbuf: gdkpixbufsink: GdkPixbuf sink
gdkpixbuf: gdkpixbufoverlay: GdkPixbuf Overlay
gdkpixbuf: gdkpixbufdec: GdkPixbuf image decoder
opusparse: opusparse: Opus audio parser
amrnb: amrnbenc: AMR-NB audio encoder
amrnb: amrnbdec: AMR-NB audio decoder
timecode: avwait: Timecode Wait
timecode: timecodestamper: Timecode stamper
apetag: apedemux: APE tag demuxer
resindvd: rsndvdbin: rsndvdbin
1394: hdv1394src: Firewire (1394) HDV video source
1394: dv1394src: Firewire (1394) DV video source
cacasink: cacasink: A colored ASCII art video sink
adpcmenc: adpcmenc: ADPCM encoder
videotestsrc: videotestsrc: Video test source
spandsp: tonegeneratesrc: Telephony Tone Generator source
spandsp: dtmfdetect: DTMF detector element
spandsp: spanplc: SpanDSP PLC
audiobuffersplit: audiobuffersplit: Audio Buffer Split
coloreffects: chromahold: Chroma hold filter
coloreffects: coloreffects: Color Look-up Table filter
autodetect: autoaudiosrc: Auto audio source
autodetect: autoaudiosink: Auto audio sink
autodetect: autovideosrc: Auto video source
autodetect: autovideosink: Auto video sink
accurip: accurip: AccurateRip(TM) CRC element
openmpt: openmptdec: OpenMPT-based module music decoder
imagefreeze: imagefreeze: Still frame stream generator
flxdec: flxdec: FLX video decoder
dtsdec: dtsdec: DTS audio decoder
bs2b: bs2b: Crossfeed effect
freeverb: freeverb: Reverberation/room effect
mpegtsdemux: tsdemux: MPEG transport stream demuxer
mpegtsdemux: tsparse: MPEG transport stream parser
matroska: webmmux: WebM muxer
matroska: matroskamux: Matroska muxer
matroska: matroskaparse: Matroska parser
matroska: matroskademux: Matroska demuxer
segmentclip: videosegmentclip: Video buffer segment clipper
segmentclip: audiosegmentclip: Audio buffer segment clipper
wavenc: wavenc: WAV audio muxer
smooth: smooth: Smooth effect
speex: speexdec: Speex audio decoder
speex: speexenc: Speex audio encoder
voamrwbenc: voamrwbenc: AMR-WB audio encoder
ivfparse: ivfparse: IVF parser
lame: lamemp3enc: L.A.M.E. mp3 encoder
openal: openalsrc: OpenAL Audio Source
openal: openalsink: OpenAL Audio Sink
x265: x265enc: x265enc
fieldanalysis: fieldanalysis: Video field analysis
chromaprint: chromaprint: Chromaprint fingerprinting element
asf: rtpasfdepay: RTP ASF packet depayloader
asf: rtspwms: WMS RTSP Extension
asf: asfdemux: ASF Demuxer
oss4: oss4src: OSS v4 Audio Source
oss4: oss4sink: OSS v4 Audio Sink
rtponvif: rtponvifparse: ONVIF NTP timestamps RTP extension
rtponvif: rtponviftimestamp: ONVIF NTP timestamps RTP extension
audiolatency: audiolatency: AudioLatency
id3tag: id3mux: ID3 v1 and v2 Muxer
theora: theoraparse: Theora video parser
theora: theoraenc: Theora video encoder
theora: theoradec: Theora video decoder
dc1394: dc1394src: 1394 IIDC Video Source
vmnc: vmncdec: VMnc video decoder
rtpmanager: rtpfunnel: RTP funnel
rtpmanager: rtpdtmfmux: RTP muxer
rtpmanager: rtpmux: RTP muxer
rtpmanager: rtpssrcdemux: RTP SSRC Demux
rtpmanager: rtprtxsend: RTP Retransmission Sender
rtpmanager: rtprtxreceive: RTP Retransmission receiver
rtpmanager: rtprtxqueue: RTP Retransmission Queue
rtpmanager: rtpsession: RTP Session
rtpmanager: rtpptdemux: RTP Demux
rtpmanager: rtpjitterbuffer: RTP packet jitter-buffer
rtpmanager: rtpbin: RTP Bin
flv: flvmux: FLV muxer
flv: flvdemux: FLV Demuxer
openjpeg: openjpegenc: OpenJPEG JPEG2000 encoder
openjpeg: openjpegdec: OpenJPEG JPEG2000 decoder
level: level: Level
jpegformat: jifmux: JPEG stream muxer
jpegformat: jpegparse: JPEG stream parser
rtp: rtpstorage: RTP storage
rtp: rtpulpfecenc: RTP FEC Encoder
rtp: rtpulpfecdec: RTP FEC Decoder
rtp: rtpreddec: Redundant Audio Data (RED) Decoder
rtp: rtpredenc: Redundant Audio Data (RED) Encoder
rtp: rtpstreamdepay: RTP Stream Depayloading
rtp: rtpstreampay: RTP Stream Payloading
rtp: rtpvrawpay: RTP Raw Video payloader
rtp: rtpvrawdepay: RTP Raw Video depayloader
rtp: rtpvp9pay: RTP VP9 payloader
rtp: rtpvp9depay: RTP VP9 depayloader
rtp: rtpvp8pay: RTP VP8 payloader
rtp: rtpvp8depay: RTP VP8 depayloader
rtp: rtpvorbispay: RTP Vorbis payloader
rtp: rtpvorbisdepay: RTP Vorbis depayloader
rtp: rtptheorapay: RTP Theora payloader
rtp: rtptheoradepay: RTP Theora depayloader
rtp: rtpsv3vdepay: RTP SVQ3 depayloader
rtp: rtpspeexdepay: RTP Speex depayloader
rtp: rtpspeexpay: RTP Speex payloader
rtp: rtpsirendepay: RTP Siren packet depayloader
rtp: rtpsirenpay: RTP Payloader for Siren Audio
rtp: rtpsbcpay: RTP packet payloader
rtp: rtpsbcdepay: RTP SBC audio depayloader
rtp: rtpqdm2depay: RTP QDM2 depayloader
rtp: rtpqcelpdepay: RTP QCELP depayloader
rtp: rtpmp4gpay: RTP MPEG4 ES payloader
rtp: rtpmp4gdepay: RTP MPEG4 ES depayloader
rtp: rtpmp4adepay: RTP MPEG4 audio depayloader
rtp: rtpmp4apay: RTP MPEG4 audio payloader
rtp: rtpmp4vdepay: RTP MPEG4 video depayloader
rtp: rtpmp4vpay: RTP MPEG4 Video payloader
rtp: rtpmp2tpay: RTP MPEG2 Transport Stream payloader
rtp: rtpmp2tdepay: RTP MPEG Transport Stream depayloader
rtp: rtpmp1sdepay: RTP MPEG1 System Stream depayloader
rtp: asteriskh263: RTP Asterisk H263 depayloader
rtp: rtpL24depay: RTP audio depayloader
rtp: rtpL24pay: RTP audio payloader
rtp: rtpL16depay: RTP audio depayloader
rtp: rtpL16pay: RTP audio payloader
rtp: rtpL8depay: RTP audio depayloader
rtp: rtpL8pay: RTP audio payloader
rtp: rtpklvpay: RTP KLV Payloader
rtp: rtpklvdepay: RTP KLV Depayloader
rtp: rtpjpegpay: RTP JPEG payloader
rtp: rtpjpegdepay: RTP JPEG depayloader
rtp: rtpj2kpay: RTP JPEG 2000 payloader
rtp: rtpj2kdepay: RTP JPEG 2000 depayloader
rtp: rtph265pay: RTP H265 payloader
rtp: rtph265depay: RTP H265 depayloader
rtp: rtph264pay: RTP H264 payloader
rtp: rtph264depay: RTP H264 depayloader
rtp: rtph263pay: RTP H263 packet payloader
rtp: rtph263depay: RTP H263 depayloader
rtp: rtph263pdepay: RTP H263 depayloader
rtp: rtph263ppay: RTP H263 payloader
rtp: rtph261depay: RTP H261 depayloader
rtp: rtph261pay: RTP H261 packet payloader
rtp: rtpopuspay: RTP Opus payloader
rtp: rtpopusdepay: RTP Opus packet depayloader
rtp: rtpmpvpay: RTP MPEG2 ES video payloader
rtp: rtpmpvdepay: RTP MPEG video depayloader
rtp: rtpmparobustdepay: RTP MPEG audio depayloader
rtp: rtpmpapay: RTP MPEG audio payloader
rtp: rtpmpadepay: RTP MPEG audio depayloader
rtp: rtppcmapay: RTP PCMA payloader
rtp: rtppcmupay: RTP PCMU payloader
rtp: rtppcmudepay: RTP PCMU depayloader
rtp: rtppcmadepay: RTP PCMA depayloader
rtp: rtpamrpay: RTP AMR payloader
rtp: rtpamrdepay: RTP AMR depayloader
rtp: rtpgsmpay: RTP GSM payloader
rtp: rtpgsmdepay: RTP GSM depayloader
rtp: rtpg729pay: RTP G.729 payloader
rtp: rtpg729depay: RTP G.729 depayloader
rtp: rtpg726pay: RTP G.726 payloader
rtp: rtpg726depay: RTP G.726 depayloader
rtp: rtpg723pay: RTP G.723 payloader
rtp: rtpg723depay: RTP G.723 depayloader
rtp: rtpg722pay: RTP audio payloader
rtp: rtpg722depay: RTP audio depayloader
rtp: rtpilbcdepay: RTP iLBC depayloader
rtp: rtpilbcpay: RTP iLBC Payloader
rtp: rtpgstpay: RTP GStreamer payloader
rtp: rtpgstdepay: GStreamer depayloader
rtp: rtpdvpay: RTP DV Payloader
rtp: rtpdvdepay: RTP DV Depayloader
rtp: rtpceltpay: RTP CELT payloader
rtp: rtpceltdepay: RTP CELT depayloader
rtp: rtpbvpay: RTP BV Payloader
rtp: rtpbvdepay: RTP BroadcomVoice depayloader
rtp: rtpac3pay: RTP AC3 audio payloader
rtp: rtpac3depay: RTP AC3 depayloader
videofilter: videomedian: Median effect
videofilter: videoflip: Video flipper
videofilter: videobalance: Video balance
videofilter: gamma: Video gamma correction
adpcmdec: adpcmdec: ADPCM decoder
app: appsink: AppSink
app: appsrc: AppSrc
kms: kmssink: KMS video sink
cairo: cairooverlay: Cairo overlay
openexr: openexrdec: OpenEXR decoder
dvbsuboverlay: dvbsuboverlay: DVB Subtitles Overlay
faceoverlay: faceoverlay: faceoverlay
mxf: mxfmux: MXF muxer
mxf: mxfdemux: MXF Demuxer
dvdread: dvdreadsrc: DVD Source
overlaycomposition: overlaycomposition: Overlay Composition
proxy: proxysink: Proxy Sink
proxy: proxysrc: Proxy source
mpeg2enc: mpeg2enc: mpeg2enc video encoder
modplug: modplug: ModPlug
ipcpipeline: ipcslavepipeline: Inter-process slave pipeline
ipcpipeline: ipcpipelinesink: Inter-process Pipeline Sink
ipcpipeline: ipcpipelinesrc: Inter-process Pipeline Source
videoframe_audiolevel: videoframe-audiolevel: Video-frame audio level
realmedia: pnmsrc: PNM packet receiver
realmedia: rtspreal: RealMedia RTSP Extension
realmedia: rdtmanager: RTP Decoder
realmedia: rdtdepay: RDT packet parser
realmedia: rademux: RealAudio Demuxer
realmedia: rmdemux: RealMedia Demuxer
aom: av1dec: AV1 Decoder
aom: av1enc: AV1 Encoder
y4menc: y4menc: YUV4MPEG video encoder
audioconvert: audioconvert: Audio converter
mms: mmssrc: MMS streaming source
bluez: avdtpsrc: Bluetooth AVDTP Source
bluez: avdtpsink: Bluetooth AVDTP sink
bluez: a2dpsink: Bluetooth A2DP sink
replaygain: rgvolume: ReplayGain volume
replaygain: rglimiter: ReplayGain limiter
replaygain: rganalysis: ReplayGain analysis
removesilence: removesilence: RemoveSilence
debugutilsbad: testsrcbin: Generic bin
debugutilsbad: fakevideosink: Fake Video Sink
debugutilsbad: errorignore: Convert some GstFlowReturn types into others
debugutilsbad: watchdog: Watchdog
debugutilsbad: debugspy: DebugSpy
debugutilsbad: compare: Compare buffers
debugutilsbad: chopmydata: FIXME
debugutilsbad: fpsdisplaysink: Measure and show framerate on videosink
debugutilsbad: checksumsink: Checksum sink
jp2kdecimator: jp2kdecimator: JPEG2000 decimator
interleave: deinterleave: Audio deinterleaver
interleave: interleave: Audio interleaver
audiovisualizers: wavescope: Waveform oscilloscope
audiovisualizers: synaescope: Synaescope
audiovisualizers: spectrascope: Frequency spectrum scope
audiovisualizers: spacescope: Stereo visualizer
vulkan: vulkanupload: Vulkan Uploader
vulkan: vulkansink: Vulkan video sink
mpg123: mpg123audiodec: mpg123 mp3 decoder
sctp: sctpdec: SCTP Decoder
sctp: sctpenc: SCTP Encoder
goom: goom: GOOM: what a GOOM!
musepack: musepackdec: Musepack decoder
icydemux: icydemux: ICY tag demuxer
vpx: vp9enc: On2 VP9 Encoder
vpx: vp9dec: On2 VP9 Decoder
vpx: vp8enc: On2 VP8 Encoder
vpx: vp8dec: On2 VP8 Decoder
typefindfunctions: audio/x-tap-dmp: dmp
typefindfunctions: audio/x-tap-tap: tap
typefindfunctions: audio/audible: aa, aax
typefindfunctions: audio/x-xi: xi
typefindfunctions: video/x-pva: pva
typefindfunctions: application/x-ssa: ssa, ass
typefindfunctions: application/octet-stream: no extensions
typefindfunctions: image/x-degas: no extensions
typefindfunctions: image/x-icon: no extensions
typefindfunctions: application/x-yuv4mpeg: no extensions
typefindfunctions: image/vnd.wap.wbmp: no extensions
typefindfunctions: image/vnd.adobe.photoshop: psd
typefindfunctions: application/msword: doc
typefindfunctions: application/pdf: pdf
typefindfunctions: audio/x-kss: kss
typefindfunctions: video/x-ivf: ivf
typefindfunctions: audio/x-sap: sap
typefindfunctions: audio/x-vgm: vgm
typefindfunctions: audio/x-gbs: gbs
typefindfunctions: audio/x-ay: ay
typefindfunctions: audio/x-gym: gym
typefindfunctions: audio/x-nsf: nsf
typefindfunctions: video/vivo: viv
typefindfunctions: application/x-mmsh: no extensions
typefindfunctions: multipart/x-mixed-replace: no extensions
typefindfunctions: video/x-dirac: no extensions
typefindfunctions: application/x-ms-dos-executable: dll, exe, ocx, sys, scr, msstyles, cpl
typefindfunctions: application/x-ar: a
typefindfunctions: application/x-tar: tar
typefindfunctions: application/x-rar: rar
typefindfunctions: image/svg+xml: svg
typefindfunctions: application/postscript: ps
typefindfunctions: audio/x-caf: caf
typefindfunctions: audio/x-wavpack-correction: wvc
typefindfunctions: audio/x-wavpack: wv, wvp
typefindfunctions: audio/x-spc: spc
typefindfunctions: audio/aac: aac, adts, adif, loas
typefindfunctions: application/x-executable: no extensions
typefindfunctions: text/x-cmml: no extensions
typefindfunctions: application/x-ogg-skeleton: no extensions
typefindfunctions: audio/x-celt: no extensions
typefindfunctions: audio/x-speex: no extensions
typefindfunctions: application/x-ogm-text: no extensions
typefindfunctions: application/x-ogm-audio: no extensions
typefindfunctions: application/x-ogm-video: no extensions
typefindfunctions: video/x-theora: no extensions
typefindfunctions: audio/x-vorbis: no extensions
typefindfunctions: audio/x-flac: flac
typefindfunctions: application/x-subtitle-vtt: vtt
typefindfunctions: subtitle/x-kate: no extensions
typefindfunctions: application/x-compress: Z
typefindfunctions: application/zip: zip
typefindfunctions: application/x-gzip: gz
typefindfunctions: application/x-bzip: bz2
typefindfunctions: image/x-sun-raster: ras
typefindfunctions: image/x-xpixmap: xpm
typefindfunctions: image/x-jng: jng
typefindfunctions: video/x-mng: mng
typefindfunctions: image/x-xcf: xcf
typefindfunctions: audio/x-sid: sid
typefindfunctions: audio/x-sbc: sbc
typefindfunctions: audio/iLBC-sh: ilbc
typefindfunctions: audio/x-amr-wb-sh: amr
typefindfunctions: audio/x-amr-nb-sh: amr
typefindfunctions: video/x-dv: dv, dif
typefindfunctions: video/x-mve: mve
typefindfunctions: application/mxf: mxf
typefindfunctions: video/x-matroska: mkv, mka, mk3d, webm
typefindfunctions: image/x-portable-pixmap: pnm, ppm, pgm, pbm
typefindfunctions: image/x-exr: exr
typefindfunctions: image/webp: webp
typefindfunctions: image/tiff: tif, tiff
typefindfunctions: image/bmp: bmp
typefindfunctions: image/png: png
typefindfunctions: image/gif: gif
typefindfunctions: image/jpeg: jpg, jpe, jpeg
typefindfunctions: application/x-ape: ape
typefindfunctions: audio/x-shorten: shn
typefindfunctions: audio/x-rf64: rf64
typefindfunctions: audio/x-w64: w64
typefindfunctions: audio/x-ircam: sf
typefindfunctions: audio/x-sds: sds
typefindfunctions: audio/x-voc: voc
typefindfunctions: audio/x-nist: nist
typefindfunctions: audio/x-paris: paf
typefindfunctions: audio/x-svx: iff, svx
typefindfunctions: audio/x-aiff: aiff, aif, aifc
typefindfunctions: audio/x-wav: wav
typefindfunctions: application/xml: xml
typefindfunctions: application/ttml+xml: ttml+xml
typefindfunctions: application/smil: smil
typefindfunctions: application/sdp: sdp
typefindfunctions: application/x-hls: m3u8
typefindfunctions: application/itc: itc
typefindfunctions: text/uri-list: ram
typefindfunctions: text/utf-32: txt
typefindfunctions: text/utf-16: txt
typefindfunctions: text/plain: txt
typefindfunctions: video/x-flv: flv
typefindfunctions: application/vnd.ms-sstr+xml: no extensions
typefindfunctions: application/dash+xml: mpd, MPD
typefindfunctions: application/xges: xges
typefindfunctions: application/x-shockwave-flash: swf, swfl
typefindfunctions: application/x-pn-realaudio: ra, ram, rm, rmvb
typefindfunctions: application/vnd.rn-realmedia: ra, ram, rm, rmvb
typefindfunctions: text/html: htm, html
typefindfunctions: video/mj2: mj2
typefindfunctions: image/x-jpc: jpc, j2k
typefindfunctions: image/jp2: jp2
typefindfunctions: image/x-quicktime: qif, qtif, qti
typefindfunctions: video/quicktime: mov, mp4
typefindfunctions: application/x-3gp: 3gp
typefindfunctions: audio/x-m4a: m4a
typefindfunctions: video/x-nuv: nuv
typefindfunctions: video/x-h265: h265, x265, 265
typefindfunctions: video/x-h264: h264, x264, 264
typefindfunctions: video/x-h263: h263, 263
typefindfunctions: video/mpeg4: m4v
typefindfunctions: video/mpeg-elementary: mpv, mpeg, mpg
typefindfunctions: application/ogg: ogg, oga, ogv, ogm, ogx, spx, anx, axa, axv
typefindfunctions: video/mpegts: ts, mts
typefindfunctions: video/mpeg-sys: mpe, mpeg, mpg
typefindfunctions: audio/x-gsm: gsm
typefindfunctions: audio/x-dts: dts
typefindfunctions: audio/x-ac3: ac3, eac3
typefindfunctions: audio/mpeg: mp3, mp2, mp1, mpga
typefindfunctions: audio/x-mod: 669, amf, ams, dbm, digi, dmf, dsm, gdm, far, imf, it, j2b, mdl, med, mod, mt2, mtm, okt, psm, ptm, sam, s3m, stm, stx, ult, umx, xm
typefindfunctions: audio/x-ttafile: tta
typefindfunctions: application/x-apetag: mp3, ape, mpc, wv
typefindfunctions: application/x-id3v1: mp3, mp2, mp1, mpga, ogg, flac, tta
typefindfunctions: application/x-id3v2: mp3, mp2, mp1, mpga, ogg, flac, tta
typefindfunctions: video/x-fli: flc, fli
typefindfunctions: audio/mobile-xmf: mxmf
typefindfunctions: audio/riff-midi: mid, midi
typefindfunctions: audio/midi: mid, midi
typefindfunctions: application/x-mcc: mcc
typefindfunctions: application/x-scc: scc
typefindfunctions: audio/x-imelody: imy, ime, imelody
typefindfunctions: video/x-vcd: dat
typefindfunctions: video/x-cdxa: dat
typefindfunctions: audio/qcelp: qcp
typefindfunctions: video/x-msvideo: avi
typefindfunctions: audio/x-au: au, snd
typefindfunctions: audio/x-musepack: mpc, mpp, mp+
typefindfunctions: video/x-ms-asf: asf, wm, wma, wmv
wildmidi: wildmididec: WildMidi-based MIDI music decoder
shapewipe: shapewipe: Shape Wipe transition filter
ofa: ofa: OFA
mpegtsmux: mpegtsmux: MPEG Transport Stream Muxer
png: pngenc: PNG image encoder
png: pngdec: PNG image decoder
twolame: twolamemp2enc: TwoLAME mp2 encoder
rawparse: rawvideoparse: rawvideoparse
rawparse: rawaudioparse: rawaudioparse
rawparse: unalignedvideoparse: unalignedvideoparse
rawparse: unalignedaudioparse: unalignedaudioparse
tcp: multisocketsink: Multi socket sink
tcp: multifdsink: Multi filedescriptor sink
tcp: tcpserversrc: TCP server source
tcp: tcpserversink: TCP server sink
tcp: tcpclientsrc: TCP client source
tcp: tcpclientsink: TCP client sink
tcp: socketsrc: socket source
hls: hlssink2: HTTP Live Streaming sink
hls: hlssink: HTTP Live Streaming sink
hls: hlsdemux: HLS Demuxer
rsvg: rsvgdec: SVG image decoder
rsvg: rsvgoverlay: RSVG overlay
dtmf: rtpdtmfdepay: RTP DTMF packet depayloader
dtmf: rtpdtmfsrc: RTP DTMF packet generator
dtmf: dtmfsrc: DTMF tone generator
webrtc: webrtcbin: WebRTC Bin
srtp: srtpdec: SRTP decoder
srtp: srtpenc: SRTP encoder
rtmp: rtmpsink: RTMP output sink
rtmp: rtmpsrc: RTMP Source
dvdspu: dvdspu: Sub-picture Overlay
coretracers: leaks (GstTracerFactory)
coretracers: stats (GstTracerFactory)
coretracers: rusage (GstTracerFactory)
coretracers: log (GstTracerFactory)
coretracers: latency (GstTracerFactory)
webrtcdsp: webrtcechoprobe: Accoustic Echo Canceller probe
webrtcdsp: webrtcdsp: Voice Processor (AGC, AEC, filters, etc.)
legacyrawparse: audioparse: Audio Parse
legacyrawparse: videoparse: Video Parse
opus: opusdec: Opus audio decoder
opus: opusenc: Opus audio encoder
auparse: auparse: AU audio demuxer
x264: x264enc: x264enc
soup: souphttpclientsink: HTTP client sink
soup: souphttpsrc: HTTP client source
cutter: cutter: Audio cutter
midi: midiparse: MidiParse
shm: shmsink: Shared Memory Sink
shm: shmsrc: Shared Memory Source
isomp4: qtmoovrecover: QT Moov Recover
isomp4: mj2mux: MJ2 Muxer
isomp4: 3gppmux: 3GPP Muxer
isomp4: ismlmux: ISML Muxer
isomp4: mp4mux: MP4 Muxer
isomp4: qtmux: QuickTime Muxer
isomp4: rtpxqtdepay: RTP packet depayloader
isomp4: qtdemux: QuickTime demuxer
jack: jackaudiosink: Audio Sink (Jack)
jack: jackaudiosrc: Audio Source (Jack)
siren: sirenenc: Siren Encoder element
siren: sirendec: Siren Decoder element
flite: flitetestsrc: Flite speech test source
smoothstreaming: mssdemux: Smooth Streaming demuxer
ossaudio: osssink: Audio Sink (OSS)
ossaudio: osssrc: Audio Source (OSS)
geometrictransform: perspective: perspective
geometrictransform: fisheye: fisheye
geometrictransform: mirror: mirror
geometrictransform: square: square
geometrictransform: tunnel: tunnel
geometrictransform: bulge: bulge
geometrictransform: stretch: stretch
geometrictransform: waterripple: waterripple
geometrictransform: twirl: twirl
geometrictransform: sphere: sphere
geometrictransform: rotate: rotate
geometrictransform: pinch: pinch
geometrictransform: marble: marble
geometrictransform: kaleidoscope: kaleidoscope
geometrictransform: diffuse: diffuse
geometrictransform: circle: circle
spectrum: spectrum: Spectrum analyzer
cdparanoia: cdparanoiasrc: CD Audio (cdda) Source, Paranoia IV
equalizer: equalizer-10bands: 10 Band Equalizer
equalizer: equalizer-3bands: 3 Band Equalizer
equalizer: equalizer-nbands: N Band Equalizer
assrender: assrender: ASS/SSA Render
waylandsink: waylandsink: wayland video sink
soundtouch: bpmdetect: BPM Detector
soundtouch: pitch: Pitch controller
audiomixer: audiointerleave: AudioInterleave
audiomixer: liveadder: AudioMixer
audiomixer: audiomixer: AudioMixer
volume: volume: Volume
video4linux2: v4l2deviceprovider (GstDeviceProviderFactory)
video4linux2: v4l2radio: Radio (video4linux2) Tuner
video4linux2: v4l2sink: Video (video4linux2) Sink
video4linux2: v4l2src: Video (video4linux2) Source
gsm: gsmdec: GSM audio decoder
gsm: gsmenc: GSM audio encoder
audiotestsrc: audiotestsrc: Audio test source
gio: giostreamsrc: GIO stream source
gio: giostreamsink: GIO stream sink
gio: giosrc: GIO source
gio: giosink: GIO sink
bz2: bz2dec: BZ2 decoder
bz2: bz2enc: BZ2 encoder
effectv: rippletv: RippleTV effect
effectv: streaktv: StreakTV effect
effectv: radioactv: RadioacTV effect
effectv: optv: OpTV effect
effectv: quarktv: QuarkTV effect
effectv: revtv: RevTV effect
effectv: vertigotv: VertigoTV effect
effectv: shagadelictv: ShagadelicTV
effectv: warptv: WarpTV effect
effectv: dicetv: DiceTV effect
effectv: agingtv: AgingTV effect
effectv: edgetv: EdgeTV effect
multipart: multipartmux: Multipart muxer
multipart: multipartdemux: Multipart demuxer
decklink: decklinkvideosrc: Decklink Video Source
decklink: decklinkaudiosrc: Decklink Audio Source
decklink: decklinkvideosink: Decklink Video Sink
decklink: decklinkaudiosink: Decklink Audio Sink
debug: cpureport: CPU report
debug: testsink: Test plugin
debug: taginject: TagInject
debug: progressreport: Progress report
debug: pushfilesrc: Push File Source
debug: navseek: Seek based on left-right arrows
debug: rndbuffersize: Random buffer size
debug: capssetter: CapsSetter
debug: breakmydata: Break my data
udp: udpsrc: UDP packet receiver
udp: dynudpsink: UDP packet sender
udp: multiudpsink: UDP packet sender
udp: udpsink: UDP packet sender
yadif: yadif: YADIF deinterlacer
rfbsrc: rfbsrc: Rfb source
uvch264: uvch264src: UVC H264 Source
uvch264: uvch264mjpgdemux: UVC H264 MJPG Demuxer
y4mdec: y4mdec: YUV4MPEG demuxer/decoder
pnm: pnmenc: PNM image encoder
pnm: pnmdec: PNM image decoder
staticelements: bin: Generic bin
staticelements: pipeline: Pipeline object
Total count: 273 plugins (14 blacklist entries not shown), 1408 features
The blacklisted plugins are:
root@8a6245b5d731:/opt/nvidia/deepstream/deepstream-6.1# gst-inspect-1.0 -b
Blacklisted files:
libnvdsgst_udp.so
libnvdsgst_nvblender.so
libnvdsgst_infer.so
libgstnvvideoconvert.so
libnvdsgst_tracker.so
libnvdsgst_dsexample.so
libnvdsgst_dewarper.so
libnvdsgst_deepstream_bins.so
libnvdsgst_multistreamtiler.so
libnvdsgst_ucx.so
libnvdsgst_multistream.so
libcustom2d_preprocess.so
libnvdsgst_preprocess.so
libnvdsgst_inferserver.so
Total count: 14 blacklisted files
Can someone help me with these problems?
